Question about Video Game Consoles & Games
In dukes cave walking the slanted pipe can't find the vent needed to break to get lazer gun
Where is the vent to break what does the reactor look like?
Nails coming out of side of nail gun dont know why
are you using the correct nails for your nailer? some nailers use a 20 degree slant others dont. If slanted nails it could be that they are in backwards. If you use slanted and your gun requires straight nail strips this could be the reason as well.
Jan 30, 2015 | Tools & Hardware - Others
Toilet bowl will not refill
It is possible that the vent pipe behind the toilet is clogged (or was not installed properly). Some bathrooms are set up with one shared vent pipe, and a clog in one of the lines leading to it can cause similar problems.
The vent pipe in each bathroom does 2 things:
1: it lets the sewer gas go past the bathroom and up out the roof so you don't get sewer gas in the house.
2: It breaks the siphon as water goes from fixtures down to the big sewer pipes in the house. If it isn't working for a sink, it's not much of a problem because air gets mixed in with the water as it does down the sink, and this breaks the siphon. But in a toilet, it jsut keeps pulling water down the pipe until the water level in the toilet gets low enough to let air into the pipe, breaking the siphon.
It's not an easy problem to fix and often involves removing walls to get at pipes.
A plumber can bring a snake tool and try clearing the pipes from below or from the roof, and might even be able to bring a steerable snake that lets him control how it goes through the pipe.
Apr 19, 2014 | Kohler Home
I CAN NOT FIND WOLF CAVE
This is a website for solving issues about hardware and software, this is not a website for a walk-through in video games. If you would like to find a walk-through for any particular game, please visit www.gamefaqs.com.
Mar 29, 2014 | Microsoft Xbox 360 Console
Gas spills back out and pump shuts off when trying to pump gas
Tank vent pipe is blocked, causing pressure that can only vent via the filler neck. You will find that the pipe is caked in mud. Locate the pipe (it's like a snorkel on the tank near the filler neck) and insert a straightened paperclip into the hole to remove the mud.
Alternatively, fill slower with the gun nozzle slightly at a twist in the filler neck.
But you almost certainly have a blocked tank vent pipe.
Dec 19, 2012 | Jeep 1998 Grand Cherokee Laredo
2001 gsxr 750 wont hold a steady idle very jerky **** runs grate.
check for intake leaks generally this is the first thing you check for a erratic idle
Oct 15, 2012 | 2001 Suzuki GSX-R 750
Sewer smell in house since installing the new toliet and the toliet gurgles when the washing machine is on. It started with the new toliet now the gurgling and smell is also present in another bathroom.
It sounds like a vent problem.
On top of each house is a vent stack.
There should be a vent stack above each toilet, and above kitchen sink.
Look for pipes sticking out of roof.
These pipes are open to the sewer line.
When you run a column of water down a drain, the vent stack lets air flow in front of and behind the column of water.
This air flow prevents the gurgling sound.
The gurgling sound is the drain water pushing air in front of it because of a clogged vent.
If you have a two story house, there are vents that run between floors to prevent the air flow from gurgling or bubbling sewer air into each drain as water column moves down pipe.
http://www.bradyinspects.com/plumbing-vents.html
http://chestofbooks.com/home-improvement/construction/plumbing/Standard-Practical/Venting-Part-3.html
Look for bird nest over vent pipe on top of house.
Run a snake down into pipe from roof and see if the is a stoppage.
You many need to call plumber to track down each vent and the cause.
For example if there are quick-vents installed inside a wall and the quick vent is no longer working.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 25, 2010 | Kohler Bath Highline K-11492-96 Biscuit...
I have a 2000 gmc sierra 1500 2wheel drive engine code was p1415 what is it mean?
A P1415 indicates a problem with the A.I.R. system. This code is a common indicator of an electric a.i.r. injector reactor problem. Sounds complex but it's not. There are two of these reactors on your engine. They are the black things that the secondary air pipe plugs into at the exhaust pipe/or/exhaust manifold. It is worth changing both of them becauses if one fails the other is not far behind. It is also worth replacing the factory hose clamp with a regular one---you'll see what I mean.BTW--P1415 specificaly indicates a problem with Bank 1 of the A.I.R. system. Make sure both sides of the A.I.R. system are in order--meaning all the hoses are tight and secure--no leaks--cracked hoses ETC.
Aug 10, 2010 | 2000 GMC New Sierra 1500
Need to know how to operate milwaukee screw gun?
I hope you're talking screw gun and not drill/driver. Screw gun used specifically to set screws in drywall. Make sure you have proper tip in gun (usually #2 phillips). There should be a rotating collar on the gun to control screw depth. The screw should only "dimple" the drywall. It should not tear the paper but should be below the plane of the drywall. To check depth run a putty knife over the screw heads. If you hear it hit, screws need to go a bit deeper. To work quickly; lock the trigger on and place the screw on the gun. Apply steady pressure and let the screw walk into the board until gun breaks free. Takes a bit of practice but pretty soon you'll be flying.
Mar 02, 2010 | Milwaukee Tool Drills
Sapphire
This is my solution : To get the Regi's, you need a Relicanth and a Wailord. Go to Mosdeep City and Surf south until you can't surf any longer. Now go West and you'll be in Pacifilog Town. Go West from Pacifilog Town and go along the waves. Eventually you'll find an area where you can Dive. Dive down and follow the path down. You'll come across Braile. It just says to go up, so press B and go to the Surface. Walk to the wall and read the Braile. It says " First comes Wailord, Last comes Relicanth." This means to put Wailord in your lead postiton, and Relicanth in the last postition in your party. When you do that, the next door will unlock. Read the braile, it tells you to use Dig. Use Dig and the Regi caves will then be unlocked. When you go to each Regi cave, this is what you do:
Regirock: Walk up and read the Braille. Walk two steps Left, then two steps down. Use Rock Smash.
Regice: Run an entire lap all around the boarder of the cave.
Registeel: Walk to the center of the cave, then use Flash. Rate this answer: 1 2 3 4 5 6 7 8 9 10
Jan 02, 2008 | Nintendo Game Boy Advance Console
Picture Slant
You will have to adjust the yoke transformers on the necks of the color guns. this should clear up the slanted picture.
Sep 24, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Video Game Consoles & Games Logo
65 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
