Question about Taylor Instruments 9840 Instant Read Pocket Thermometer
How to select Fahrenheit or Celsius
The read out is asking to select Celsius or Fahrenheit. How do I select it?
Hello, Can I change the dashboard and air condition from Fahrenheit to Celsus? 4Runner 2016
I don't think so. You will have to learn to read the Fahrenheit degree readings using the Celsius table. Maybe you can ask your dealer depending on what country you are from.
Oct 17, 2017 | Toyota 4Runner Cars & Trucks
Tip
C++ Source code for Celsius to Fahrenheit
#include <cstdio>
#include <cstdlib>
#include <iostream>
using namespace std;
int main(float nNumberofArgs, char* pszArgs[])
double celsius;
cout << "Enter the temperature in Celsius:";
cin >> celsius;
double factor;
factor = 212 - 32;
double fahrenheit;
fahrenheit = factor * celsius/100 + 32;
cout << "Fahrenheit value is:";
cout << fahrenheit << endl;
system("PAUSE");
return 0;
on Jun 16, 2010 | Computers & Internet
How to change from Celsius to Fahrenheit
To convert degrees C to degrees F, Multiply the Centigrade temperature by 9, then divide by 5, then add 32
Or, degrees F= (9/5 degrees C) + 32
Here's link to website which explains difference between Fahrenheit & Centigrade scales, & how to convert between them:
http://www.mathsisfun.com/temperature-conversion.html
Jul 11, 2014 | 1996 Buick Park Avenue
On the FAH125p2T the display is reading in celsius instead of fahrenheit
Good Afternoon Friend,
I understand you are trying to change the display from Celsius to Fahrenheit. To convert from one to the other and back, press and hold the " TEMP/TIMER" Up arrow and Down arrow buttons together for 3 seconds. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire Heating & Cooling
Changing the external temperature gauge from Fahrenheit to Celsius
If your temperature reads in climate control reads in degrees Celsius "C" instead of Fahrenheit "F", follow these steps to change to Fahrenheit.
  • Turn the ignition on.
  • With the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the off button in for 3 seconds or until you hear a beep.
The display should then change to "F". Follow these same steps to change your read-out to Celsius , if preferred.
Sep 21, 2012 | 2005 Land Rover LR3
How do I change the temperature reading from Celsius to Fahrenheit?
with the switch in the 'lock' position, hit the C/F button (also labeled as the 'min' & 'date' button)
Dec 30, 2011 | Elgin Travel Alarm Clock
How do you change the tempature reading for the air conditioner from Celsius to Farenheit?
You can switch the temperature mode between Fahrenheit to Celsius as follows:
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit.
Feb 03, 2010 | 2004 Kia Optima
The air temp reads in celsius, how do i change it back to read in fahrenheit?
thereshould be some buttons groupped together on thedash gas mileage is mph/kilo air temp cel /fer push the button until u find the readings readable foryou
Jan 24, 2010 | 2003 Hyundai Santa Fe
Taylor Instruments 9840 Instant Read Pocket Thermometer Logo
32 people viewed this question
Top Taylor Instruments Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Taylor Instruments Measuring Tool and Sensor Expert? Answer questions, earn points and help others
