Question about Harman Kardon FL8350 5-Disc CD Changer
Where can I get a belt for FL 8400 5-Disc CD Changer
One inch Belt broke
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya
www.fixya.com > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
Replacement parts
Take the broken belt to ace hardware and find an o-ring that is the same size.
Jan 10, 2015 | Technics SL-MC700 110-Disc CD Changer
The cd changer wheel if not turning anymore.
The belts last about 15 years, less depending on usage. Sounds like it's time for a belt replacement. Check out softduds on eBay, he can replace belts and adjust these players, he has lots of experience.
Aug 25, 2014 | Sony MegaStorage CDP-CX355 300-Disc CD...
Cd player indicates Table Error
The belt in the back of the player under the hood is either broke or has came off the rollers. You will need to take the top off and replace the belt a rubber band will work as a temporary fix till you can order a new belt.
May 28, 2014 | Sony MegaStorage CDP-CX355 300-Disc CD...
Player just stopped working.
There is definitely something either spring or belt related going on in there. You wont hear anything if a belt broke. I would take it apart and run it while it is open to see what is happening. Should be a relatively easy fix
Apr 02, 2014 | Sony MegaStorage CDP-CX355 300-Disc CD...
When i turn my technics cd player all i see is error
Technics CD Changer SL-MC400
The ERROR Is Cause By The Belt Drive
Remove The Cover And You Can See if
The Belt is Lose or slip of In Any Case
You Must Change That RUBBER DRIVE BELT.
Dec 31, 2013 | Technics SL-MC400 110-Disc CD Changer
FL 8350 CD Player. Disc drawer will not open. Getting error message
Most likely a belt has stretched and will not now move the tray. This happens of units more than 2 years old usually.
Dec 26, 2012 | Harman Kardon FL8350 5-Disc CD Changer
Our Sony 400 disc changer won't open. I can hear
If ure an expert, then open up the set, check for alignment balancing for the gears and see if the belting has worn out. Pioneer till today uses belt for ejecting. Belt usually the issue.
Jan 16, 2010 | Sony MegaStorage CDP-CX455 400-Disc CD...
Table Error--carousel will not turn
pull off changer cover, theres 9 screws .looking from the front of the changer, look to left side,thats where there are belts for drive mech. the back one is for the carosel, it might of broke or came off. had the same problem belt came off. works good as new. hope it solves your problem
Nov 27, 2009 | Sony CDP-CX400 400-Disc CD Changer
Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Jan 11, 2009 | Yamaha CDC-585 5-Disc CD Changer
Harman Kardon FL8350 5-Disc CD Changer Logo
98 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
