Question about RCA DRC6309 9 in. Portable DVD Player with Screen
Tighten screen hing on 9" rca dvd player
The screen hinge is loose and falls backwards" how do I Tighten
How to tighten loose display hinges on toshiba pro a10
There ares no adjustments to tighten the hinges, they need to be replaced.
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site.
http://www.insidemylaptop.com/replace-br...
Jul 20, 2012 | Toshiba Satellite Computers & Internet
Loose screen hinges on lg laptop.
Yes, get on eBay and purchase LCD Hinges
Apr 20, 2012 | Computers & Internet
Tighten hinge on presario 700
There are no adjustment available to tighten the hinges on a laptop. They need to be replaced.
These WEB site will assist you in replacing hinges.
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/b>Laptop repair infohttp://www.laptoprepair101.com/
Mar 28, 2012 | Compaq Presario 700 470024-192 Notebook
Case loose round hinges
If the screws securing the hinges to the base of the laptop is loose then tighten these screws.
Hinges have no tightening adjustments and loose/faulty hinges need to be replaced.
These WEB sites can assist you to replace these hinges.
Feb 15, 2012 | Packard Bell Computers & Internet
My screen is loose, i would like to know how to tighten the screen..
You can take the laptop apart, and try to tighten the screws of the hinge. But i think the hinge is worn. You can try if the warranty covers it.
Good luck, and i hope this was helpful ;)
Apr 19, 2010 | Acer Aspire 5610-4648 Notebook
How do i tighten my screen on dv 1000 it is too loose with too much play
Hinges on laptops cannot be tighten, they need to be replaced.
For parts and details how to replace hinges please click on these WEB sites :-
Replacing Display hinges http://www.laptopparts101.com/display-screen-hinges/
Mar 11, 2010 | HP Pavilion dv1000 Notebook
Sony VGN AR630
If the lid has a small slack and then is firmer again when the lid/screen is in another position, then the hinge mounting screws is most likely loose and the mounting screws needs to be tighten.
If the hinges are loose no matter what the position of the lid/screen is in then, they need to be replaced, there is no adjustment to tighten the hinges.
Jul 23, 2009 | Sony VAIO VGN-AR630E Notebook
Screen falls back
Loose hinges or bad hinges. You can pop off the hinge cover (above the keyboard) and 'try' to tighten the hinges, but if that doesn't work, it's failing hinges and the only fix is to get them replaced mate.
Hope this hellps, be sure to rate!! :)
Jan 03, 2009 | Dell Latitude C610 Notebook
Loose hinges
I met this problem almost all brands of laptops. Depending on how the hinges being built (return spring, embedded lock notch, etc.) Some are easy to adjust and some need more precise tightenings due to wear and tear of the lock notch. However you can buy hinges too at ebay just specify the brand and models as well as the LCD screen part no. replacement. Hope this gives you hint.
Best regards,
Rosener
Feb 14, 2008 | Dell Inspiron 4100 Notebook
Screen hinge too loose
a the base of the screen you may see some scews that cover access panels, open them up and you can tighten the little nut that tensions the hinge. I had a laptop that was shaky and I tightened the hinges and it was OK after that.
Jan 24, 2008 | LG X-Note LM50 Notebook
RCA DRC6309 9 in. Portable DVD Player with Screen Logo
52 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
