Question about Building Materials
I noticed now that my Garage Door light does not turn off.
Light remains on after opening and closing the garage door
    New Friend:
  • 130 Answers
Check and make sure your wall switch doesn't have motion detector on it.. If so turn it off and see if that solves your problem.
Posted on May 07, 2014
SOURCE: Garage door won't close
your door travel screw is set to go too far on the downward travel. you need to set the down travel. It is set to go too far down. find the screw adjustment on the unit that says close and back off the screw a full turn until door stops short of floor. then start turning screw other way until door just touvhes floor.
Posted on Mar 06, 2008
SOURCE: garage door opener troubleshooting
Try backing off door travel ajustment,
Posted on Apr 14, 2008
  • 244 Answers
SOURCE: Garage door opens but does not close
check that lenses on safety beams are clean and that they are aimed at each other so that both have led light on.
Posted on Jan 15, 2009
  • 3197 Answers
SOURCE: My garage door opener won't close the garage door.
Most likely your door sensors have been bumped and are not aligned properly. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
Posted on Apr 30, 2009
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
How to get my garage door to open all the way?
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Jun 15, 2014 | liftmaster Garage Door 1/2 Hp
Garage door light blinks but doesn't stay on
(Winston-Salem, NC)
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Craftsman 139.53673SRT1 garage door opener seems to hit that screw near the light ending at the up position pretty hard. Is ther a way to adjust that? maybe it always has, but noticed it more lately?
Close the door and while it is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover.
Aug 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
Our Sears garage door opener closes the door, but it immediately reopenes. We have also noticed that the light bulb on the motor (on the ceiling) flashes five times when this happens. The only way to...
Make sure the door sensors are pointed at one another. Each of them has a small light that should come on when they are correctly pointed at one another. If you cannot get both light to come on you have bad sensors.
Aug 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door is a craftman . The problem is the door opens fine but won't close unless u hold the button till its completely closed. I noticed this only happens when its cold out any suggestions !!!
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit.
Dec 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door will open with remotes, but not with the wall switch
Sure sounds like the wall control is bad. Very common problem.
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close with remotes
Yeh, read manual. Do both sensors have led lit. try aligning. you have safety beam problem,
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Dec 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
42 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
