Question about Xerox WorkCentre 220 All-In-One Laser Printer
How to enter The canon Pe220's tech mode?? - Xerox WorkCentre 220 All-In-One Laser Printer
2 Suggested Answers
SOURCE: xerox pe220 cannot copy
i have the same problem too with my pe220. fortunately, i just purchased a new one which i planned to give to it to a relative, and I was able to figure out that the cause of the "function impossible" displayed.
the problem just occured this morning and I have tried downloading and updating the firmware too, clearing the memories, etc but cannot get the copier to work (can't print thru the pc also).
i then borrowed the new toner cartridge of the new pe220 and installed on my old one and i was able to print and copy again. the problem then is due to the chip memory.
the problem now is how to reset the serial eeprom chip in order to reuse the toner cartridge again.
hope this helps.
Posted on Mar 10, 2009
Canon code E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Oct 21, 2015 | Canon Office Equipment & Supplies
How can i cancil error 0004 ?
To clear the error code you must enter service mode level 1 first. Once in service mode you choose in the following order Copier>Function>Clear select ERR and push ok. At this point it would apprear nothing has happened but in fact the error flag has been cleared. Shut the machine off. Now turn on. If your error was minor and your cleared the cause of your error E000004 then the machine will operate as it did before the flag went up. If you get the error code again look for a Canon trained tech in your area to correct the issue. If you do not know how to get in to the service mode level 1 your best to search for entering service mode canon. As I don't want to promote persons without expertise entering the machine service and adjusting things without any backgound. Good Luck
Jun 25, 2011 | Canon imageRUNNER 5000 Copier
LSU error in XEROX workcentre pe220. What is the
R/sir,
I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
Thanks and regards
PK Jain
(Pennywise)
Dec 15, 2010 | Xerox WorkCentre PE220 Series
Alert light on says to press ok button, nothing happensm always says check printer push ok
That's an older model, it gives no error code until you enter service mode and get the code. Service mode is only available to service techs since there several things you can do in there that could ruin your printer. You can find the nearest Canon service by calling 1-800-828-4040
Feb 04, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Xerox pe220 cannot copy
hope this helps.
Feb 24, 2009 | Xerox WorkCentre 220 All-In-One Laser...
E00002-0000 error code
clear the error from the service mode
Oct 25, 2008 | Canon ImageRUNNER 3570 Copier/Printer
ERROR: INSTALL TONER
Toner Empty Message If a Toner Empty Message is Still Displayed After a New Print Cartridge Has Been Installed, Enter the Tech Mode and Perform a Manual Reset CAUTION: Make sure to follow this solution carefully as incorrect settings made in the Tech mode can cause the machine to become inoperable. The Tech mode is intended to be used by service and support personnel only.
Before performing this solution, make sure a new Xerox PE220 SmartKit Print Cartridge has been installed into the machine. Other print cartridges are not compatible with the machine and a manual reset should not be attempted.
If necessary, see the Related Items below for additional information on ordering supplies, consumables, and parts.
To enter the Tech mode and perform a manual reset:
  1. Enter the Tech mode:
    1. Press the [Menu] button on the Control Panel.
    2. Press [#], [1], [9], [3], [4] using the numeric keypad. 'Tech' will be displayed on the Display Screen.
  2. Press the [Menu] button until 'Data Setup' is displayed.
  3. Press the [Enter] button on the Control Panel.
  4. Press the [Left] or [Right] arrow button on the Control Panel until 'Clear Counts' is displayed.
  5. Press the [Enter] button.
  6. Press [1], [9], [3], [4] using the numeric keypad.
  7. Press the [Enter] button.
  8. Press the [Left] or [Right] arrow button until 'Used Toner Cnt' is displayed.
  9. Press the [Enter] button.
  10. Power OFF the printer using the power switch on the rear, right side of the printer.
  11. Wait 30 seconds and then power ON the printer
Aug 28, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Xerox WorkCentre 220 All-In-One Laser Printer Logo
206 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
