Question about Motorola Mobility RAZR V3m Cellular Phone
Inside screen divided horizontly in 2
Once when turn phone on, the inside screen lighted and for my surprise, was divided in 2 horizontal screens (half+half) , bottom i could see from midle screem to top followed by the bottom to midle. any sugestion ?
    Brigadier General:
  • 7,752 Answers
Re: inside screen divided horizontly in 2
Take the phone to a mobile service repair center and have them replaced the LCD for you.
Posted on Feb 08, 2008
0 characters
3 Points
Change I-phone screen from vertical to horizontal
You can change your screen from vertical to horizontal by the way you hold it. If you have the vertical/horizontal turned off you just unlock your phone and slide up with your finger from the bottom to the top and the menu with brightness, sound, airplane mode, wireless,etc., will come up. Click on the last bottom in the first row that looks like a lock with a circle around it and make sure it says that its off (which will be black instead of white).
Oct 13, 2014 | Apple Iphone 4s I Phone 4 S Factory...
How do i get pantech swift screen from horizontal to verticle?
Have you tried to turn off the Auto screen rotation? Try that and let me know your response.
+1 (503) 583-2414
Oct 02, 2014 | Pantech Swift Mobile Phone - Purple at&t
Want to watch videos horizontally on iphone. Where is the setting for that?
Turn the screen. The video should be horizontally.
If not, pull up the setup screen by moving a finger over the screen from the bottom up and the logo on the right top, should be white now. Press it once and it will turn black. Now the lock screen in vertical position is free.
You know Apple has beautiful manuals online for free?
You could try getting one, so you can find out yourself. They even have tutorials to show the basic things about your phone and iOS7. Also for free.
Jun 29, 2014 | Cell Phones
When I turn my phone horizontal to type, the screen does NOT turn horizontal like it should. It was, but now it doesn't it.
Go into System Settings - Display - and check the box that says: Auto-rotate screen.
You may also want to follow that up with 2 aspirins and call me in the morning!
~ PC-Doctor
Oct 29, 2013 | Apple iPhone 5c
My nokia e52 screen suddendly rotated 90 degree to the right side what happened?
E52 has a giroscope inside, so when you turn to landscape mode it turns the screen automatically to be horizontal.
Jan 31, 2011 | Nokia E52 Smartphone
My nokia 6500 slide, has some problem with its screen. first it was a light brown symbol on the screen and later, two lines appeared to the left side of the symbol horizontally. and now, one more line...
Hi, You will need to unscrew the phone and see if the phone screen is not broken, if the screen is not broken, that means the fllex of the phone is damaged and will need to be replaced.
The flex controls the displaying of the screen.
Oct 08, 2010 | Nokia 6500 Slide Cellular Phone
LG Xenon keypad slid open will not turn horizontal on the screen
I read that you can rub a magnet on the backside of the slider and it makes the screen turn portrait and horizontal - you can see that when you rub the magnet on the backside. I just rubbed the magnet with the slider open on the horizontal side (only the right side) - if you rub the left side it makes it portrait. I did that a few times and my phone turns horizontal now when I open the keypad slider. It appears to have worked doing this at this point.
Nov 16, 2009 | LG Xenon GR500 Cell Phone
W580i most of screen taken up by vertical and horizontal lines help. already reinstalled the sw from the sony media mgr
More than likely you will need to replace the display screen. Those lines are a symptom of the LCD screen going bad. If you are still under warranty, see if you can get it replaced
If not, a new LCD screen runs about 15 dollars shipped from eBay and is pretty easy to replace.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony Ericsson W580i LCD Display Replacement
I hope that helps you out
May 31, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
No picture in horizontal mode
make sure u have enough light while taking your pic in horizontal mode because the camera is in a different form then usual.
Nov 04, 2007 | Samsung SCH-u740 Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
146 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
