Question about Proteam ProCare 15 Upright Vacuum
Red light is on vacumn
Doesn't **** as well
Can u put a video on how to put a belt on a Kirby vacumn
Try this YouTube video: http://youtu.be/At7tqnjD-Kc
Mar 01, 2015 | Kirby Vacuums
Vacumn cleaner does not start green light indicates power goes to the vacumn cleaner
the top part of the cage where the bag goes in has a tiny switch that goes down when the bag is in.Sometimes the cardboard top of the bag does not depress the switch.Check thast first.
Sep 13, 2014 | Electrolux hose 2100 series diplomat
Vacumn motor does not start with the switch. Light indicates the vacumn is on
check the top area of where the bag goes in.There is a tiny switch that get pushed down by the cardboard top of the bag.This is to protect the motor by not allowing the motor to engage without a bag
Sep 13, 2014 | Electrolux electric hose models 2100
I bought a Kenmore 30012 Quick Clean Vacuum on 7/5/2011 it was working fine till just recently. Its not picking up anything off my rug, I've cleaned the filters, the belt is fine. It was blowing dust...
A clogged inlet. Something is likely clogging the opening where the dirt goes in. Paper, cellophane, or anything else light enough to get sucked in but too large to pass through.
Aug 18, 2011 | Kenmore Quick Clean 30012 Vacuum
My Kenmore vacumn won`t turn on . worked fine one minute then stopped. The light works on the handle but no vacumn
You probably have a sensor that needs attention and is clogged up so unclog and see if that takes care of it
Jan 12, 2011 | Kenmore Vacuums
Odd noise coming from central vacumn cleaner
The rattling noise, will likely increase when the head is flipped upside down. Generally means you have a stone caught in the belt or a blown or stripped tooth on the belt.
If you gently squeeze the outside edges of the light housing it will pop off to reveal two screws to remove the lid. Check for other screws at the neck of the power head. Once removed your belt and brush will be visible. Remove the brush roll with end caps and flip the belt inside out rolling it between your finger , look for cracks or a floppy or missing tooth. Replace if any sign of wear.
Inspect the dust caps on your brush. There is a washer under each, likely buried in lint. Do not lose as these are a spacers for each end of the brush. Clean shaft and lube with WD40. Spray caps with the same. vacuum loose grit and dust bunnies away from motor and reinstall, your red button must align with the lid when replacing
Jul 19, 2009 | Hayden Industries SuperVac 2400 Central...
Fantom twister wont work light is on
When you say, "just stopped", did the MOTOR stop operating and there's no sound from it at all? Or, is the motor still working or sounds like it does, and it stopped vacumning?
If the MOTOR stopped, most likely there is a short somewhere in the connection at the motor. Think 'repair shop'.
If the motor still runs and there's no VACUMN ACTION, think Roller Brush which operates by virtue of a rubber belt. Turn the machine on its side and turn it ON, keeping FINGERS !AWAY! from the roller area. If the Roller Brush is not moving it may be that the belt has slipped off or is broken or simply too loose to turn the Roller. Also sometimes debris such as strings, long hair, carpet strands/fibers will become wrapped around the roller especially next to the roller bearing/brace points, to the point of binding so tightly that the roller will no longer be able to actually roll which would now prevent it from 'Vacumning' or sweeping dirt and such up into the vortex of the vacumn chamber. In which case, !!UNPLUG!! the machine, use small scissors to cut away the material wrapped around the roller paying particular attention to the brace point areas.
Apr 20, 2009 | Fantom Vacums FM780 Twister 700LX Upright...
Red light stays on
It sounds like the plates inside the vacuum that detect the dirt have become dirty. I don't remember where they are, but I think they're accessible if you remove a certain hose. Again, I don't know which hose it is.
Jan 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No vacumn action
Is the roller turning, if not you may need a new belt and/or brush roll. Did you check the inlet by the brush roll?
Feb 09, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Proteam ProCare 15 Upright Vacuum Logo
26 people viewed this question
Top Proteam Vacuums Experts
Ed60062
Level 1 Expert
Mike
Thatvacguy.com
Are you a Proteam Vacuum Expert? Answer questions, earn points and help others
