Question about Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
Ce error getting ce error
What is CE error code on LG TROMM WM1814CW
According to page 21 of the owner's manual, the following are known error codes: IE= Water Inlet Error, OE=Drain Error, UE=Unbalance Error, dE=Door Error, tE=Thermistor Error, FE=Overfill due to Faulty Water Valve, PE=Water Level Sensor Error, CE and LE=different Motor Errors, and PF=Power Failure.
its a motor error
check the brushes
Jan 03, 2015 | LG WM Washing Machines
How do I fix CF-Splash error for Windows 8 with CE 100 Futura machine
contact singer customer service and check with them about the error message
Sep 09, 2013 | Sewing Machines
CE error displays
hello there and thank you for choosing fixya
CE Communications Error If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Jul 31, 2011 | Washing Machines
My Washing machine has a fault code of CE - any ideas?
You will need to do troubleshooting.
CE Communications Error .If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
·Motor controller is not powered or fuse has opened. Replace motor controller.---------------------- If any part need to get replaced,then you can get required part from www.repairclinic.com .-------
Thank you.
Feb 09, 2011 | Washing Machines
Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
Feb 15, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
Error code CE When I turn the washer on it start then turn back off, then error code CE flashes on the display.
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 10, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
CE-02 error code when scanning on SHARP MX-M550U copier
ce error means not hooked up property to your email server
Feb 12, 2009 | Office Equipment & Supplies
Kenmore Elite Top Loader "CE" error code.
CE means communications error
If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Network Error CE-02
There is a Windows Port that is being blocked. First make sure the IP it's scanning to and IP on the machine are the same. disable the firewall. I'm working on narrowing down the port now and will post as soon as I find it.
-Mike
Oct 31, 2008 | Computers & Internet
KEEPS SHOWING A BROKEN TREAD ERROR MESSAGE. I CANOT FINISH A PROJECT! SINGER FURURA CE-150
I have a CE-250 and I was having problems getting this message. After doing some research, I discovered that it was the thread sensor not sensing the thread. Try rethreading it or cleaning out your sensor area. It works for me when I get this message
Apr 23, 2008 | Singer CE-100 Futura Computerized Sewing...
Electrolux EI26SS55GS Stainless Steel  Side by Side Refrigerator Logo
48 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
