Question about MBRP 2007 GMC Yukon - Denali, 6.2L V8 - Exhaust Systems
Torque What happens when the M8 cylinder head bolts are tightened down after the first pass of the M11 bolts?
Head bolt torque?
M11 bolts: 1st step; - 22 ft./lbs. 2nd step; - turn 150 degrees M8 bolts 9-10: 1st step; - 11 ft./lbs. 2nd step; - turn 75 degrees Note: Do not reuse cylinder head bolts. Do not allow oil on cylinder head, head bolt bosses.
Apr 27, 2016 | 2007 Suzuki XL-7
What are the torque specs and sequence for the intake and head gasket on a 1999 Chevy Silverado 6.0l V8 K2500
Cylinder Head Bolts (First Pass all M11 Bolts in Sequence)
30 N?·m
22 lb ft
Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence)
90 degrees
Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head)
90 degrees
Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence)
50 degrees
Cylinder Head Bolts (M8 Inner Bolts in Sequence)
30 N?·m
22 lb ft
Intake Manifold Bolts (First Pass in Sequence)
5 N?·m
44 lb in
Intake Manifold Bolts (Final Pass in Sequence)
10 N?·m
89 lb in
Intake Manifold Wiring Harness Stud
10 N?·m
89 lb in
Oct 27, 2015 | Cars & Trucks
Gmc 2003 yukon xl denali 6.0 v8 head cylinder bolts torque
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
· Tighten the cylinder head bolts.
Tighten
1.Tighten the M11 cylinder head bolts a first pass in sequence to 30 N·m (22 lb ft).
2.Tighten the M11 cylinder head bolts a second pass in sequence to 90 degrees .
3.Tighten the M11 cylinder head bolts (1, 2, 3, 4, 5, 6, 7, 8) to 90 degrees and the M11 cylinder head bolts (9 and 10) to 50 degrees a final pass in sequence Tighten the M8 cylinder head bolts (11, 12, 13, 14, 15) to 30 N·m (22 lb ft). Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts.
May 25, 2015 | 2003 GMC Yukon Denali
Torque specs and sequence of head bolts 2004 chevy silverado 2500hd with 6.0
Go to autozone.com and become a member of their web-site. It is FREE. You can then access repair info for your vehicle. There are repair manuals that show pictures and everything. I will look for your torque specs and picture.
  • Clean the cylinder head bolts, apply sealer to the threads, and hand-tighten.
  • Tighten the cylinder head bolts:
    1. M11 cylinder head bolts first pass in sequence to 30 Nm (22 ft. lbs.).
    2. M11 cylinder head bolts second pass in sequence + 90 degrees.
    3. M11 cylinder head bolts (1,2,3,4,5,6,7,8) + 90 degrees
    4. M11 cylinder head bolts (9 and 10) + 50 degrees
    5. M8 cylinder head bolts (11,12,13,14,15) to 30 Nm (22 ft. lbs.). Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts.
      NOTE The cylinder head gasket displacement can be verified by markings visible on the underside of the right gasket locating tab. Some 4.8/5.3L head gaskets may have 53 stamped onto the locating tab. Some 6.0L head gaskets may have 60 stamped onto the locating tab.
    Aug 28, 2014 | 2004 Chevrolet Silverado 2500HD
    I need head bolt torque specs for a 2000 cadillac deville dts..
    DeVille, Eldorado, Seville 1999-2005
    Cylinder Head
    Print
    Removal & Installation
    Left Side
    1. Before servicing the vehicle, refer to the Precautions Section.
    2. Drain the cooling system.
    3. Properly relieve the fuel system pressure.
    4. Remove or disconnect the following:
      Negative battery cable Exhaust manifold Alternator Water crossover Intake manifold Valve cover Timing cover Secondary camshaft drive chain Power steering return hose retaining bolt from the cylinder head 3 M6 external drive bolts from the front portion of the cylinder head 10 M11 internal drive cylinder head bolts Cylinder head and gasket.
    5. Clean the head mating surfaces.
    To install:
    Fig. Left cylinder head bolt torque sequence-4.6L engine
    1. Install the cylinder head with a new gasket. Lubricate the bolts with engine oil prior to installation.
    2. Torque the M11 bolts in sequence as follows:
      1. Step 1: 30 ft. lbs. (40 Nm), plus an additional 70 degrees
      2. Step 2: Turn an additional 60 degrees
      3. Step 3: Turn an additional 60 degrees (total 190 degrees)
    3. Torque the M6 bolts to 106 inch lbs. (12 Nm)
    4. Install or connect the following:
      Power steering return hose retaining bolt to the cylinder head and tighten to 37 ft. lbs. (50 Nm) Secondary camshaft drive chain Timing cover Valve cover Intake manifold Water crossover Exhaust manifold Negative battery cable
    5. Change the oil and filter.
    6. Fill the cooling system.
    Right Side
      Negative battery cable Exhaust manifold Water crossover Intake manifold Valve cover Timing cover Secondary camshaft drive chain Electrical connector from the Engine Coolant Temperature (ECT) sensor Nut attaching the coil cassette ground wire to the cylinder head Bolt attaching the exhaust crossover pipe to the cylinder head Bolt attaching the right transaxle mount bracket to the cylinder head Bolt attaching the rear transaxle brace to the transaxle Nuts attaching the rear transaxle brace to the cylinder head Rear transaxle brace 3 M6 external drive bolts from the front portion of the cylinder head 10 M11 internal drive cylinder head bolts Cylinder head and gasket
    To install:
    Fig. Right cylinder head bolt torque sequence- 4.6L engine
      1. Step 1: 30 ft. lbs. (40 Nm), plus an additional 70 degrees.
      2. Step 2: Turn an additional 60 degrees.
      3. Step 3: Turn an additional 60 degrees (total 190 degrees).
    3. Torque the M6 bolts to 106 inch lbs. (12 Nm).
      Rear transaxle brace over the studs located at the rear of the right cylinder head Nuts attaching the rear transaxle brace to the cylinder head, loosely Bolts attaching the rear transaxle braces to the transaxle and tighten to 37 ft. lbs. (50 Nm) Nuts attaching the rear transaxle brace to the cylinder head and tighten 37 ft. lbs. (50 Nm) Electrical connector to the ECT sensor Bolt attaching the exhaust crossover pipe to the cylinder head and tighten to 18 ft. lbs. (25 Nm) Nut attaching the coil cassette ground wire to the cylinder head and tighten to 13 ft. lbs. (17 Nm) Secondary camshaft drive chain Timing cover Valve cover Intake manifold Water crossover Exhaust manifold Negative battery cable
    Apr 16, 2013 | 2000 Cadillac DeVille DTS
    Torque specs for 3.2 1995 heads on my isuzu... I need to fix the car ASAP....
    Hi, to install follow the procedure below:
    1. Install new camshaft seals and retaining plates onto the cylinder. Tighten the right camshaft seal retaining plate 6mm bolts to 65 inch lbs. Tighten the left camshaft seal retaining plate 8mm bolts to 191 inch lbs.
    2. Thoroughly clean the cylinder head and engine block sealing surfaces.
    3. Place a new head gasket on the engine block and carefully position the cylinder head on top of the new gasket.
    Do not reuse or apply oil to the cylinder head bolts.
    1. Install new cylinder head bolts and torque them in sequence to 47 ft. lbs. (64 Nm) for the M11 bolts and 15 ft. lbs. (21 Nm) for the M8 bolts.
    2. Install the dipstick tube bracket to the cylinder head.
    3. Connect the front exhaust pipes to the exhaust manifolds. Tighten the exhaust bolts to 48 ft. lbs. (67 Nm).
    4. Install the power steering pump bracket. Torque the mounting bolts to 34 ft. lbs. (46 Nm).
    5. Install the cylinder head covers.
    6. Install the timing belt and the auto tensioner (pusher). Torque the mounting bolt to 14 ft. lbs. (19 Nm).
    7. Install the timing belt cover and oil cooler hoses and bracket.
    8. Install the crankshaft pulley. Torque the center bolt to 123 ft. lbs. (167 Nm).
    9. Install the fan pulley assembly.
    10. Install the power steering pump.
    11. Install the accessory drive belts.
    12. Install the engine coolant manifold and the heater hose.
    13. Install the intake manifold. Torque the nuts and bolts to 17 ft. lbs. (24 Nm) in a crisscross pattern.
    14. Install the fuel injector connectors and the fuel hoses to the fuel rail.
    15. Install the common chamber. Torque the nuts and bolts to 17 ft. lbs. (24 Nm).
    16. Install the EGR valve assembly. Torque the mounting bolts on the valve side to 69 inch lbs. (8 Nm) and the bolts on the exhaust side to 21 ft. lbs. (28 Nm).
    17. Connect the evaporative emission canister purge hose.
    18. Connect the fuel pressure control valve vacuum hose.
    19. Connect the positive crankcase ventilation hose.
    20. Install the throttle body assembly. Torque the mounting bolts to 14 ft. lbs. (19 Nm).
    21. Connect the vacuum hoses to the throttle body.
    22. Install the ignition control module and the spark plug wires.
    23. Connect the MAP sensor; Canister vacuum switching valve (VSV); Exhaust gas recirculation (VSV); Intake air temperature sensor and ground connectors.
    24. Connect the vacuum booster hose.
    25. Connect the air vacuum hose.
    26. Connect the accelerator cable. Adjust the accelerator cable by pulling the cable housing while closing the throttle valve and tightening the adjusting nut and screw cap by hand temporarily. Now loosen the adjusting nut by three turns and then tightening the screw cap. Make sure the throttle valve reaches the screw stop when the throttle is closed.
    27. Install the cooling fan assembly and the upper fan shroud.
    28. Install the air cleaner assembly.
    29. Connect the negative battery cable.
    30. Refill and bleed the cooling system.
    31. Refill and bleed the power steering pump if necessary.
    32. Refill the engine with fresh oil.
    33. Run the engine and check for leaks and proper compression.
    Best of luck............
    May 30, 2011 | 1995 Isuzu Trooper
    Torque specs for 3.2 1995 heads on isuzu rodeo heads
    To install:
    May 16, 2011 | 1995 Isuzu Rodeo
    What r the torque specifications on installing a head on a 1999 yukon and the tightening sequence
    Check this procedure...
    1. Tighten the first design cylinder head bolts as follows:
      1. M11 bolts 1st pass: in sequence to 22 ft. lbs. (30 Nm).
      2. M11 bolts 2nd pass: in sequence + 90 degrees.
      3. M11 bolts (1,2,3,4,5,6,7,8): + 90 degrees.
      4. M11 bolts (9 and 10): + 50 degrees.
      5. M8 cylinder head bolts (11,12,13,14,15) to 22 ft. lbs. (30 Nm). Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts.
    2. Tighten the second design cylinder head bolts as follows:
      1. M11 bolts (1-10) 1st pass: in sequence to 22 ft. lbs. (30 Nm).
      2. M11 bolts (1-10) 2nd pass: in sequence + 90 degrees.
      3. M11 bolts (1-10): + 70 degrees.
      4. M8 cylinder head bolts (11,12,13,14,15) to 22 ft. lbs. (30 Nm). Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts.
    Fig. Cylinder head bolt tightening sequence-4.8L, 5.3L and 6.0L engines (click for zoom)
    Install the cylinder head bolts in sequence to 22 ft. lbs. (30 Nm). The bolts must be tightened once, then be tightened again in sequence in the following order:
    1. Step 1: Short length bolt: (3, 4, 7, 8, 11, 12, 15, 16), plus 55 degrees.
    2. Step 2: Medium length bolt: (14, 17), plus 65 degrees.
    3. Step 3: Long length bolts: (1, 2, 5, 6, 9, 10, 13), plus 75 degrees.
    Fig. Cylinder head bolt tightening sequence-5.0L and 5.7L engines
    Aug 04, 2010 | 1999 GMC Yukon Denali
    What are the head bolt torque specs for a 93 isuzu 3.2 v6
    The specs.Are the m8 bolts 15 ft.lbs and the m11 bolts 47 ft.lbs.note:The m11 bolts cannot be reused and no oil on threads.
    Dec 02, 2009 | 1993 Isuzu Rodeo
    Tork on head bolts 05 5.3
    Cylinder Head M8 Bolts - in Sequence
    30 N·m
    22 lb ft
    Cylinder Head M11 Bolts - First Pass in Sequence
    30 N·m
    22 lb ft
    Cylinder Head M11 Bolts - Second Pass in Sequence
    90 degrees
    Cylinder Head M11 Bolts - Final Pass in Sequence
    70 degrees
    Nov 29, 2009 | 2005 Chevrolet Tahoe
    MBRP 2007 GMC Yukon - Denali, 6.2L V8 - Exhaust Systems Logo
    Top MBRP Wine & Spirits Experts
    Bill Boyd
    richie46
    Dave braun
    Dave braun
    Are you a MBRP Wine and Spirit Expert? Answer questions, earn points and help others
