Question about BEGO Gelovit 200 BEGO
E4 fault code
On switching on geologist fault code e4 displays on screen and bleeps all the time?
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
E4 displayed
What make / model? Look up Manufacturers Customer help on the internet. There may be a description of that fault. With so many different makes , its impossible to say what an E4 error is , as different makes use this code for different faults.
Sep 17, 2015 | Dishwashers
Dishwasher is beeping and showing code E4
There really isn't a standard for dishwasher error codes. Need to know the manufacturer and model number to proceed. This could be a fault with the float in the fill or overflow sensing that there's too much water. You might try removing the water and letting the machine dry out. Could be too much suds from combo cheap detergent and rinse agent.
Feb 27, 2015 | Washing Machines
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
Fault code e4
I found two loose wires, and tightened the screws, and the e4 went away, and it works now. The plastic cover on the bottom has to be removed to get to the wires and screws. Make sure it's unplugged
Mar 28, 2014 | Elite EPC607 Pressure Cooker
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
Error code Df and e4
E4 Outdoor activation of low pressure switch/ less suction pressure.
Check back pressure, which should be 60 PSI when ambient temp 98 degree.If not Short of gas- find leak and arrest. And do gas charging. Even due to indoor coil dust blocked also e4 arise. Clean the coil and reset it.
Nov 25, 2010 | Napoleon NHPS12 Air Conditioner
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
Base unit displaying E4 after we experienced a power black out
e4 error code that means it ihas defective base unit. it happened due to a spike in the power lines that may cause this error
Feb 09, 2009 | Uniden 5.8GHz Cordless Phone
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
BEGO Gelovit 200 BEGO Logo
57 people viewed this question
Top BEGO Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a BEGO Toy Expert? Answer questions, earn points and help others
