Question about Sportcraft Tx2.5 Tx 2.5 Treadmill Motor Speed Controller Board Circuit Control
Lubricate How do I lubricate the tredmill
Reebok Treadmill error code 5
Exactly same just happened to my brand new Zr9 (error 5). Reebok said they would replace the motor or complete tredmill or my money back. Undecided as to what to do but thought i was buying a reliable bit of kit ??? They do cover it with 2yr warranty and it is really nice use, will research a bit more before deciding.
Feb 20, 2014 | Reebok Exercise & Fitness
I have a tredmill that quit.Is there a fuse that could be blown and where is it?
1) Unplug the machine, and test the fuse.
2) See is if there some componenet BURN, such: resistor, diode, capacitor, triac, or SCR. AND tEST IT.
3) See the block diagram, the fuse can be located in the boards, or near to the main switch.
God bless you
Jun 09, 2012 | FreeMotion Emotion Tredmill Tv Treadmill...
Error 7 how to fix for tredmill
Dear Sir:
This is indicating problem with your elevation motor.
Please check the connection, and tight, lubricate the gear + shaft .
Test the motor is o.k or faulty.
Run the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for diagnose and Help.
sincerely. God bless you.
Ernesto Cuadra
Managua, Nicaragua.
Mar 05, 2012 | Exercise & Fitness
What lubricant can i use for my pro form tredmill model 380 E?
You can use silicone lubricants.
But if you want buy lubricants:
go to www. treadmillpartszone.com
or www. gympart.com
sincerely.
E.CUADRA
MANAGUA,NICARAGUA. C.A
Nov 23, 2011 | Tunturi T20 Folding Programmable Treadmill
Proform tredmill---stops after a couple of steps--will start back up after getting off---motor control board?
Inspect the walking board and belt first.Feel the tecture at the outer edge of the belt, then feel the center. If it feel fuzzy, the walking belt is worn.
Check the walking board for damage, deep scratches, excessive friction will cause an over current shutdown of the controller.
If the walking belt and board are good, lubricate the walking board and belt and try again.
Does the motor spark allot when running?? This will also cause over current.
Have you tightened the belt (too tight??)
After covering these suggestions, if the same problem is apparent, change the motor controller..
Dec 16, 2010 | Proform 755cs Treadmill Motor Control...
While walking on my tredmill the belt jerks
Sometimes mine can "****" when my body weight on the front foot slightly slips the belt forward before I put full pressure on it and it slides back into normal walking. Don't know what your natural walking style is like, but this tends to happen when I am "heavy" on my heel with that forward step. Could also be that your belt needs lubricating (buy from sports stores).
Nov 27, 2010 | RTO Image 15.0R Treadmill Walking Belt
Stops while in motion
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 01, 2010 | Proform CrossTrainer Treadmill
Hi my tredmill will turn on but moter wont
If elevation will work it's more than likely your motor controller. I would need to know which treadmill you have to help any futher.
Nov 15, 2009 | Exercise & Fitness
After 10minutes the tredmill stops
Either you are forcing it to go faster than the set speed or not keeping up and it is trying to compensate. Eric
Aug 03, 2009 | Exercise & Fitness
Sportcraft Tx2.5 Tx 2.5 Treadmill Motor Speed Controller Board Circuit Control Logo
49 people viewed this question
Top Sportcraft Exercise & Fitness Experts
John
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
