Question about Sony RCDW3 2Disc CD Recorder
Laser assembly player deck one need part number for laser pick-up replacement
    Champion:
    Habit-Forming:
  • 239 Answers
Remove laser and number should be on it
Posted on Aug 09, 2014
C13
C13 means the deck cannot read the minidisc table of contents for some reason. Since you have no disc in the deck it probably means the laser head is out of allignment or just plain worn out.
I often see MDs being sold for parts, but you need to know the fix is usually cost prohibitve. Most likely the laser assembly in your deck is bad and will cost too much to replace. MD's are more complex than CDs and are optical/magnetic using a laser to read and a laser + magnetic head to record on the discs which are read/write many times.
Jan 30, 2012 | Sony MXD-D40 Mini Disc Player
Chasing instructions for a boardgame called Lotto. It was produced by Legend Games Australia
Lotto is a game that is played like bingo, but pictures are used instead of numbers. The Rules: To play, you need the deck of picture cards and at least one board for each player. Each player will also need a dozen or so dried beans or pennies to mark their board.
Each player gets a game board (which shows 16 pictures). Someone picks cards from the deck (it can be the teacher, or the players can take turns picking a card), and if a player has that picture on their board, they cover it with a penny or a dried bean. The winner is the first person to cover 4 pictures in a row (horizontal, vertical or diagonal). The winner calls out "Lotto!" or "Loteria!" Comment or vote if this helps!!
Jun 07, 2011 | Video Game Consoles & Games
The deck keeps ejecting the cd after a few seconds of being inserted
Hi, its possibly the laser pick assembly itself but un-sure as would need to be tested. if you havent got your player repaired and you live in the uk then you can try this site. www.audiovisualservices.info
Hope this has helped you.
Thanks.
Feb 04, 2011 | Pioneer CDJ-1000 CD Player
LG797T. Used to play DVDs but now we can't use the DVD player to watch movies because we get "Unknown disc, please try again." when it tries to read the disc. Can this be fixed at home (and how) or do I...
The problem with your unit is either a faulty laser or it could also be a faulty mpeg printed circuit board.
The way i would go about solving this issue if the unit is not under warranty is first try to clean the laser.
You can do this removing the case from the unit and if the laser is accessable, use a cue-tip or soft, clean cotton bud to gently wipe the 'eye' of the laser. Make sure to use clean and soft Cotton tips as you do not want to scratch the laser and cause further damage.
After you have done this you can test the unit without replacing the outer case, his will also give you a chance to see if the laser is lighting up to bright, concentrated red dot.
If this isnt happening you need to replace the laser. Nearly every LG product i have dealt with has a yellow or white sticker with a part number on it to make ordering another easy.
If it does not have locatable part number, refer to your local authorised repair agent as they will be able to either repair the unit for you or be able to source and obtain a 'DVD Deck Assembly', which is the entire setup that contains the laser, the drawer that the disc sitson as well as the spindle motors.
Replacing the DVD Deck Assembly is as straight foward as marking everthing you remove with a coloured marker, so you know where it ame from and being careful with any flat ribbon cables you may need to remove near or attached the laser
Mar 16, 2010 | LG RC797T
Cdm 500 not reading disk 1
First, try the disc that plays OK in deck 2 in deck 1. This will eliminate the disc as the problem. If the disc won't play in deck 1, then the laser pick-up is on it's way out. There is no easy fix for this, it will require the attention of an engineer.
Dec 12, 2008 | Philips CDM-500 2-Disc CD Player
TWO CDX DECKS TWO DIFFERENT PROBLEMS
Fault 1: sounds like a servo or laser pick-up fault.
Fault 2: sounds like a broking track on the pcb or dry joint at the phono output stage.
If you havent had it repaired you can send it to us.
Regards.
http://www.audiovisualservices.info/
Aug 13, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Tuner increments
those are odd numbers you decribed there
i understand what your saying to get the even numbers you have to use the remote and single click to what you want and if you want to stop a seek for frequencie hit the button back
you know foward select for scan and then back button for stop and then single press in what you need it takes a little fenness to control for even even numbers you just have to stop scan and seek single taps at a time
Jun 08, 2008 | Pioneer DEH-1900MP CD Player
Toc code keeps comeing up on my kenwood kdc x5589
Hi, toc error means that the laser is struggling to read the Table of Contents which tells the unit where all the information is on the disc, it may be something as simple as the lens needs cleaning or something as complicated as the laser needs replacing, but you could try running a cd disc cleaner through it first. Good luck......
Jan 24, 2008 | Kenwood eXcelon KDC-X559 CD Player
Avic-n2 won't read the navigation disks...
If it play cd's but not not dvd's or navi disc then your laser is "tired" or out of alignment. If it does not play any type of disc then it needs a new laser pick unit. A capable tech should be able to re-align or replace the laser pick up unit for about $75 to $150. Contact me if you need it perfome. My number is 801-414-4566.
Jan 22, 2008 | Pioneer AVIC-N2 Car DVD Player
CD will not play
try to put a paper clip into the reset button benrrth the vol knob
Dec 10, 2007 | Car Audio & Video
Sony RCDW3 2Disc CD Recorder Logo
44 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
