Question about Tablets & eReaders
Cannot connect emerson HD Actioncam to computer model evc455
When I connect the usb to camera usb to ccomputer and turn on camera I can't find the file to open to edit the pic. or videos.
Can I connect my fire hd 10 to my tv using a cable.
It seems as if it is possible to connect your Fire HD 10 to a TV via a HDMI cable. In order to do this you will either need:
  • Amazon HDMI adapter for fire tablets
  • Micro HDMI/ USB to HDMI cable
Here is a helpful article with ways to connect to a TV and links to the types of adapters on amazon.
How to Connect Kindle Fire to TV
Amazon com Amazon HDMI Adapter for Fire Tablets 4th Generation Kindle Store
Amazon com AmazonBasics High Speed Micro HDMI to HDMI Cable 3 Feet Latest...
Apr 02, 2016 | Amazon Kindle Fire HD
I have charged my Nook HD but it won't turn on. What can the problem be?
Do you have the charging graphic as in this image Nina?
How to Reset Nook HD
If yes, send it back. If not, your charger is faulty. Try charging with a computer USB.
Jan 21, 2016 | NOOK HD 7 Tablet
Tablet emerson
Make sure it's switched off when you charge it.Try to charge it for at least 12 hours. If still no success, try with a different charger, or through the USB cord. If still no success, probably a bad battery.
Aug 11, 2014 | Emerson 7 Cortex A8 1.0GHz Android 4.1...
Asus Memo Pad HD 7 won't turn on or charge.
1. how old is your tablet 2. have you tried another charger such as a phone charger. My blackberry charger works fine for my tablet. Also with your tablet you should have had a usb cable that connected from mini usb to the asus plug in transformer.
Jul 20, 2014 | ASUS MeMO Pad HD 7
What is wron with my tablet?
You need to do a hard reset,, read the owners manual for that step, as far as it telling you it would go faster if you had a USB 2.0. , that means your computer is way out of date
May 15, 2014 | ProntoTec 7 Inch HD 1024x600 Capacitive...
Freezes and screen turns purple and blue
the video you are watching or trying to watch was obviously copied over too it, it may be an MKV file..(blue ray file) i hate to tell you this but...the Chromo AAAAAAAA White 4gb 7" Android 4.0 Touch Capacitive Screen only has 512k of ram...(thats brain power to perform tasks) in other words....the movie file your playing has far too much data in HD and DOLBY data to play it smootly and your device is stalling using up all the ram tryng to play the movie.....to play a HD Movie without stuff ups you need at least 2gig ram not 512k thats like half a gig ram you have there and just wont do it. you already posted the specs in the title of this problem see >>> Chromo AAAAAAAA White 4gb 7" Android 4.0 Touch Capacitive Screen 1.2ghz 512 RAM Mid Tablet Pc Wifi 3g Camera Tr-a13 - Bonus USB 2.0 to Micro USB Adapter.....take note it says ....512k RAM !!!! you need more ram at least 2gig ram to play HD movies....you could try and see if you can get extra ram for these...im sure you can.
Jan 02, 2014 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
Kindle wont charge
Not all computer USB ports put out enough current to charge batteries. Try another port on the computer, if there is one. If you're going through a USB hub, remove it and connect the Kindle directly to the computer. If you have access to an AC-USB charger (one that plugs into a wall outlet instead of a computer), try using that.
Dec 24, 2013 | Amazon Kindle Fire HD
Camera don't want to connect to android tablet
A couple things to check. Sometimes the router will not allow you to use an Outside IP address to view your cameras if you are Inside the same network as the DVR. I know AT&T for sure does not allow you to go from inside your network, to an outside IP address that directs you back to your inside network. Sorry is this sounds confusing. To test this, turn WiFi off on your Android and try to access the cameras. If you cannot connect inside or outside your network, then you should try to verify you can connect with a computer. Use a PC or laptop to see if your cameras are visible. If you can access the cameras on PC, make sure there is not another port that needs to be opened for the mobile devices. Geovision DVRs for instance require some changes in the DVR itself to allow mobile devices to connect. Email me back with your DVR model and what carrier you have, the phone model and the internet provider. But you must first try getting to view your cameras on a PC to see if the setup was the issue. Good luck.
Oct 24, 2013 | Amazon Kindle Fire HD
How To Download Photos
What make and model camera? What make and model tablet?
Most cameras and many tablets only function as USB devices and not as USB controllers. You'll have to first copy the photos from the camera's memory card to a computer and then from the computer to the tablet.
Apr 25, 2013 | Tablets & eReaders
Tablets & eReaders Logo
60 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
