Question about JVC AV-65WP74 Rear Projection Television
Can I remove the base to this TV to move it?
I would like to remove the base to move the TV to a Rec room in the basement. And then reattach the base. Is this possible for a novice?
  • JVC Master
  • 8,617 Answers
Yes the set can be disassembled and then reassembled. But you would need the service manual that will explain how to get the set apart into seperate pieces. Heres a link to where you can get the service manual for your model they send it by download link.
http://servicemanuals.vstore.ca/product_info.php/pName/av65wp74/cName/jvc
Posted on Jun 15, 2009
Viore tv sound cuts out
Could be a failing power supply
Mar 12, 2014 | Televison & Video
I bought a used kp 61hs30 sony projection tv. It is too tall to fit down the stairs into the basement. I heard the top part with the screen justs lifts off the base - where the components are (after you...
The top as you describe it, can be removed for cleaning and moving. There are no electronics there and allignment will not be affected.
Hope this helps.
Dec 29, 2010 | Televison & Video
Hi I want to move the TV to my basement. I
ON THE SIDES THERE ARE 4 SCREWS THE TOP LIFTS OFF
Dec 15, 2009 | Mitsubishi WS-65908 TV
Kenmore 54501 turns on but nothing happens in my damp basement
A dehumidifier heats and cools the air to remove moisture. Most are like a small air cond. The Condenser coil is right in front of the evap.coil. So the compressor may not be coming on. Does it sound the same as before? It may be low on freon. You will have to get in there and listen and feel the lines at or near the compressor, Learn how to get down in there to the compressor. Run it for 10 Mins. unplug it, open it up, and feel the lines. Some lines should be or can be HOT to the touch. Some should be cool. The smaller the line the hotter it should be, and the compressor should be warm (to hot) to the touch. repost for more info.
Jul 08, 2009 | Kenmore 54501 Dehumidifier
How do i pull out a faulty heater blower motor from behind glovebox in 91 accord?
For Pictured Detailed Innstruction see Bottom of Page
BLOWER UNIT REMOVAL
  1. Remove the glove box.
2. Remove Glove box FRAME
3. Pull back the carpet and remove the kick panel. Remove the control unit bracket mounting nuts (4). Disconnect the connectors (5) and remove the control unit and bracket.
  1. Without A/C:
    • Remove the self-tapping screws (3) and remove the heater duct.
    • Remove the blower (3 nuts).
  • If the car has A/C, remove the blower unit according to the sequence shown
  • BLOWER MOTOR REPLACEMENT
    Refer to illustration for blower unit disassembly and reassembly, noting the following:
    • Before reassembly, make sure that the air door and linkage moves smoothly without binding.
    • When reattaching the recirculation control motor, make sure its positioning will not allow the air door to be pulled too far. Attach the recirculation control motor and all linkage, then apply battery voltage and watch the recirculation control door movement. If necessary, loosen the holding screw and move the recirculation control motor up or down
    • CONTROL ROD ADJUSTMENT
      Connect the recirculation control motor connector to the main wire harness and turn the FRE/REC switch to "REC". Hold the air door closed, then connect the control rod to the clip on the arm.
    • Email Me at the nickkname shown here >>rejakwilson @aol.com
Jan 18, 2009 | 1991 Honda Accord
Cabinet removal
Unfortunatly no there isnt. The tv bottom contains all the circuits, color guns, speakers. From where the bottom of the screen starts to the top is all part of the entire cabinet which is molded plastic. The top part contains a mirror and the screen you see as well as possibly a remote sensor. Short of sawing it in half and tossing it away you could take it apart but this would have to be done completely to gain you the most space and could be dangerous considering the high voltage transformer that the unit uses to power the color guns.
Mar 07, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Disassemble Rear Projection TV
well the short answer is : Check the sides of the set see if there is a crack in the middle where you could separate them
Long answer: i would not recommend it even if it does, the screens are sensitive and could get dust inside the screen.
Never taken one apart that far. i suspect most tech don't because of the problems aligning and dust ect.. trying to get it back together.
Dec 13, 2007 | Philips 60PP9202 60" Rear Projection...
PROBLEMS WITH USING MY CAMERA
hi. could be wrong, but eject the cassette, on the top there is this tiny yellow (maybe red) plastic switch. should see save or rec with direction arrow. slide it into rec mode and wah-la! i hope!
Apr 03, 2007 | JVC GR-D250 Mini DV Digital Camcorder
No dial tone...but can hear the tv
move the Base unit away from the TV. Check if ADSL filter in use may need to replace one or all ADSL filters
2.4 GHZ hmmm do you have 802.11 BNG WI FI in use with any of your computers ???
2.4 Ghz is a problem as computer WI FI uses this frequency as well !
check the line cord is plugged in to the base unit
Check base has power
May 24, 2017 | Uniden DCX770 for DMX700, DCT600 Cordless...
JVC AV-65WP74 Rear Projection Television Logo
125 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
