Question about Maytag MDE2400A Electric Dryer
Mde2400a How do I remove the front panel?
Having trouble removing nut to remove old fan blower on mde 2400
I ended up drilling 2 holes in the metal casing that is blocking the 2 bottom screws from being removed. However, I'm stuck trying to unscrew the big nut that is holding the fan in place. This is such a bad design. This part is not easy to replace. Would love to hear any tips for doing this job easier.
Aug 21, 2011 | Maytag MDE2400A Electric Dryer
My dryer is not drying very well, we beleive it may be because we need to clean the lint tray. where is the lint tray and how do you remove it
On this model your lint filter is in the middle of the door. Simply ope the door and unsnap the plastic grill. The filter is behind it. Also the venting from the rear of the dryer to wherever it ends up outside needs to be cleaned.
Nov 18, 2010 | Maytag MDE2400A Electric Dryer
Not getting hot
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Sep 10, 2010 | Maytag MDE2400A Electric Dryer
Maytag dryer no power to electrical panel..was just working fine
So I am having the same exact problem. Did you ever get a solution?
Aug 08, 2010 | Maytag MDE2400A Electric Dryer
Dryer not heating
There is a heating element or thermal coupler that go out on Electric dryers.
May 29, 2010 | Maytag MDE2400A Electric Dryer
110v or 220v ?
That would be a 220v dryer...virtually all electric dryers are 220v.
heatman101
Apr 19, 2010 | Maytag MDE2400A Electric Dryer
Maytag neptune electric dryer has no power on board
Maytag Neptune- electric panel is on but buttons are not responding
Mar 07, 2010 | Maytag MDE2400A Electric Dryer
My Maytag MDE9206AYW runs but won't heat
Had this problem right before Christmas on same dryer. Mine is 9 years old.
Lint had built up in the exhaust hose between the dryer and the wall. Vacuumed it out.
Runs like a champ now.
Jan 18, 2010 | Maytag MDE2400A Electric Dryer
How do i get to dryer fuses in a maytag mde2400a?
Don't believe dryers have fuses, what probably happened the electric coil is burn't out, you'll have to take it apart to check
Nov 11, 2008 | Dryers
Maytag MDE2400A Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
