Question about Home Comfort Washing Machines
I need to replace the v belt #0462E but can't find the #
How can i replace the v belt if i can't get the same number
Where can I get replacement drive belt
I have some replacement bread machine belts. Is the number code on the side of the belt still visible? It should look something like this: STS 60 S3M 471 I need the code off the belt to see if I have one in stock.
May 01, 2013 | Morphy Richards 48280 FastBake Bread...
The bristles will not spin.
See if the belt (that drives the bristles) if is loose or need replacement.The belts are located either on the left or right side of the bristle brush(you can locate it by putting the vacuum upright and see under the brushes). If it is loose or broken replace it(walmart has replacements for it or any hardware store)just bring the belt for the replacement number written on the belt,or know the brand and model number.
Nov 19, 2010 | Bissell 3522 PowerForce Bagged Upright...
Belt part number and doesnt stop at end of cycle
Go to an appliance parts store and take the belt with you. They can get you a new belt and probably the timer control unit.
Mar 26, 2010 | Dryers
Is there an easy way to see if a drive belt may be broken? It's so difficult to push my Kenmore upright vacuum!
Well there is only turning the vacuum over and see if the brush is rotating.
If it is not moving then you need to replace the belt.
If you need to know how to remove the bottom plate to replace the belt, please post the model number, the numbers you posted above are not the kenmore model numbers, the model numbers will look like this
316135912,FPF311PHSB, FGF316WGSK
Feb 15, 2010 | Kenmore 35912 / 35913 Progressive Upright...
The barrel isn't spinning
the belt broke,replace the belt,if you sent model number i could tell you the part number,open the door look around the opening where you put the clothes in and find the model number,call your parts guy,give him the number and he can tell you what belt you need
Dec 18, 2009 | Dryers
2001 Dodge Dakota replacement serpentine belt too short (w/o air)
Just tell parts place that you need 90" belt last three number's on belt part number's should end with 900 if you need one more inch last three number's should end with 910. good luck.
Nov 28, 2009 | 2001 Dodge Dakota
Need replacement belt PN 43409 for Electrolux Commercial Upright
Just about any vac shop should have the belt. This belt is the same belt used in the upright vacs as well as the power nozzels. The new oem part number is 48359.
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
My Neptune dry tub does not spin. I tried to spin it by hand and it was difficult. Can I repair this myself rather than have a repair man do it?
As you may imagine, a dryer is about the most simple household electric item there is. It is a gigantic tub that has a huge belt around it that attaches to an electric motor. The belt is rubber and subject to wear, as well as extreme heat caused by the whole process.
90% of the time its the belt, but unusually, your motor could be fried (which makes repair worthless). It's no wonder people make a living off of taking these units off the side of the road, replacing the belt for $20 and selling them on CL for $100.
You need to locate the model number and/or serial number for your unit. Also you need to open it up (which should be easy) and confirm the belt is mangled, and the motor spins fine. The belt could also just have jumped the track, and you can replace it. Replacing the belt is similar to putting a chain back on a bicycle. Usually if the belt jumps the track, it needs replacement anyway. Take the belt off/out of the way, and run the dryer to confirm the electric motor is running fine.
After that plug you model number and/or serial in google, with "replacement belt" and you should be able to find information on it.
Apr 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I cant find my dryer model number online.
Go to appliancepartspros.com and type in your model number. Use the suggested model number they provide, which is the XMW0 suffix you have listed. The part numbers will be the same for these models. If you look under the "Cabinet" diagram at item number 56, it states in the part description that this belt replaces the 5 rib (wider) belt that you have and fits all Whirlpool models. The part number is AP2946843.
For a diagram on how to replace the belt, go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page, is a link for "Dryer Belt Diagrams" under the "Special Features" section. Scroll down to Whirlpool and use diagram H. I hope this helps you. Let me know if you require additional assistance.
Jan 03, 2009 | Dryers
I have a bissell 7.5poweramp uprite vacuum with a broken belt for the brush. What size belt would i need to fix this?
Not sure with having the model number, there may be a number on the belt, like style 7 etc. If no number, get me the model number and I can find out.
Feb 28, 2008 | Vacuums
Washing Machines Logo
59 people viewed this question
Top Home Comfort Washing Machines Experts
Are you a Home Comfort Washing Machine Expert? Answer questions, earn points and help others
