Question about KitchenAid KUWA244PBS Wine Cooler
How to replace the evaporator
I was defrosting the wine cellar and punched a hole in the face of the evaporator
What would cause it to leak water?
all refrigerators will make condensation it is were evaporator meets air takes moisture out drips down into a pan located on or near compressor it maybe as simple as a plastic hose out of collector pan that will have on some refrigerators a fan .
heat from compressor and fan will evaporate the water.
your problem also can be bad door gaskets letting humid air into it
Check door gaskets make sure it seals check drain pan may have a rust hole or its plastic and may have a crack in it
send us a model # we can tell you were to look
Jul 02, 2015 | Kenmore 38 Bottle Dual-Zone Wine Cellar
Bottom level of wine cooler frosted up. Trying to defrost. What is the problem?
It sounds like your thermostat is set to low, if there is a fan check it. That can also happen for a while before it quits working if there is a refrigrent leak.
Jan 11, 2015 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
Frigidaire 18.2 cuft top freezer refridgerator either melts or freezes everything
The defroster heating elements are burnt out and won't defrost and causes system to freeze up. Then it won't cool. Unplug ice will melt off cooling fins then it will cool till it freezes up again. Install new defrost heating element. Replace both.
Jan 15, 2014 | EuroCave Performance 283 Wine Cellar
Icing up on inside air return
try to defrost the unit check the evaporator fan if working good adjust the setting or lessen the setting of your thermostat maybe the thermostat cannot cut off after reaching the temperature setting then start your unit then observe.
Feb 23, 2011 | Breezaire WKE6000 Wine Cellar Cooling Unit
My wine cooler is not reaching the set temperature. It stops at around 73 and the display flashed AL. Any ideas?
check to see if compressor cycles, if so you may have a thermistor problem which is intergrated with control, replace if you can find part. make sure to check evaporator, see if ice is forming if so you have a leak,or dry evap. you have a leak. repar.
hope this helps.
Aug 14, 2010 | Vintage Keeper Koolspace Wine Cellar
Wine cooler does not get cool - fans do not run the light and temperature display do work
if you hear the compressor tun on but not the fan, replace the fan and you may have to defrost the evaporator coils. if the compressor does not turn on either, it's the thermostat, the defrost timer, or a relay on the main board.
Nov 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Punched inside panel.
sounds like some one tried to defrost it with an knife. you can order the evaporator thru haier but unless you know how to do sealed system work you will need a qualifed refrigeration company to repair it for you if you provide the part approximate cost in the states is around 300-400 dollars. good luck peyton
Jan 29, 2009 | Haier HVH025A Wine Cooler
Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Dec 30, 2008 | Oster 12-Bottle Wine Cellar - Black
KitchenAid KUWA244PBS Wine Cooler Logo
15 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
