Question about HP PSC 2355 All-In-One InkJet Printer
Paper feeds half way, then check paper light blinks but no jam!
Same issue. Still no fix.
    Guru:
  • 224 Answers
Try cleaning the rollers at the bottom where the paper feeds in from and that should help.Now if this does not resolve the issue then trust me call in to hp total care at 1800-474-6836 and get a discount of atleast 50% on upgrade printers nothing less that 50%
Posted on Jun 16, 2009
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Paper stops half way
Please check for torn piece in the carriage which is causing the error
Jul 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
I have a HL-2070N printer and it would not print, the Paper light is red and blinking. Also, sometimes when it prints the pages get stuck half way out. Any solutions? Thank you.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cause if the paper stops in the same position all the time.
The error light is simply telling you that there is a paper jam. Open both the back panel (you should be seeing the orange roller clearly) and the front panel. Grab the handle and take out the toner and drum and check there are papers stucked. Chances are there will be.
Thank you for using Fixya!
Dec 04, 2010 | Brother Office Equipment & Supplies
Hp psc 1400 inkjet fix, paper jam
Please try these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
Check paper light blinking and "E" code
trying to print the las job you had.
Try hiiting the cancel button when you turn it on
Oct 22, 2007 | HP PSC 1315 All-In-One InkJet Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
Paper LED blinking
Try feeding using bypass, probally worn/dirty/broke paper cassette paper feed roller having trouble feeding the paper in.
Sep 30, 2007 | HP LaserJet 4L Printer
EPSON SYLUS C80 indicates "printer error: paper jam"
Epson has an interactive troubleshooting guide on their support site. http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp From the link above, choose your model printer. You will then be brought to the main page of your printer. Then, click on the "interactive help program" link under the Troubleshooting Guide section. Through this, you will be able to find an article describing what all the indicator lights mean and how to possibly resolve the issues.
Sep 21, 2006 | Epson Stylus C80 InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
100 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
