Question about HP ProLiant ML110 G5 (444809-001) Server
Standby light is Green, Overtemp is green, Dimm Ecc is Green, PSU is off
Server not Start
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 181 Answers
Clear NVRAM , Refix 24pin power connector on motherboard
Posted on Nov 04, 2016
Won't start up little green light flashing on back
the green light flashing on the backside is your internetconnection.
about the computer wan't start i should check the PSU do the fan movs any light on the motherboard.if not is the electric cord firmly and tight in place.if the fans runs and lights on the motherboard.you got no picture proberly brooken videocard.
Apr 11, 2013 | Computers & Internet
I got dell optiplex 755 desktop computer in the power supply unit at the back there is a small button and a green light what are these for??
It help diagnose problems with your computer
A solid green light means the computer is operating normally.
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode
Jan 29, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
I bought P3200 ddr 400 1gb memory and when i install it , it does not show up. any ideas why and if there is something i can do .
The Intel® Server Board S875WP1-E supports both ECC and Non ECC Unbuffered PC2100 (266 MHz), PC2700 (333 MHz), or PC3200 (400 MHz) compliant Double Data Rate (DDR) memory modules. Dual channel memory functionality requires two DIMM modules installed into DIMM sockets 1A & 1B, and then DIMM sockets 2A & 2B. The DIMM module size, speed and vendor must be the same.
You can install a single 128 MB memory module into DIMM socket 1A. The minimum supported memory size is 128 MB. The minimum main memory configuration is a single 128 MB memory module, and the maximum configurable memory size is 4GB. With only a single memory module installed, the system will only operate using a one memory channel.
Third party memory vendors may use the same module part number with different
DRAM vendors and die revisions. To insure proper system operation, verify that each DRAM
vendor and die revision has been separately tested and qualified. Please notify CMTL if there is a discrepancy.
Apr 10, 2011 | Intel Server Board S875WP1-E (S875WP1LX)...
Hi, I have a 37lc46 LG LCD which takes ages to start. When I press the power button the standby light goes off for about an hour, when it comes back on again I have to continue pressing the remote power...
Replacement power supply is used?
You need to verify the DC output voltages of the power supply first and make sure this power supply has no bad caps with leaking/bulging tops. It goes into standby can also be that it detects fault some where in the set.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 06, 2010 | LG 42LC2D 42 in. LCD HDTV
Compaq ProLiant DL380 G2 boot error. Front panel led "Internal health" initially green, then goes red with 2 second beep alternating with 2 second off. All ram leds yellow - only two populated. ...
You can get all of the documentation here
Also, Judging that the LEDs are not corresponding with the servers actual status (processor LED), This server may have been taken apart and the wires to the status leds were incorrectly reconnected. I would look at the documentation for the motherboard and compare to the wiring diagram. The RAM May be an issue. Depends on whether the machine makes it past POST (Power On Self Test). If it does, The ram is fine. If not, I would inspect that beep code further. It probably has something to do with the memory. If the memory is malfunctioning, you will get no response from the machine other than beep codes and status leds. According to the documentation, the closest match for your beep code means this:
207-Memory Configuration Warning -
DIMM In Socket X does not have Primary Width of 4 and only supports standard ECC.
Advanced ECC does not function when mixing DIMMs with Primary Widths of x4 and x8.
Audible Beeps: 1 long, 1 short, or none
Possible Cause: Installed DIMMs have a primary width of x8.
Action: Install DIMMs that have a primary width of x4 if Advanced ECC memory support is required.
I hope this helps. Thank you for choosing fixya.com
Dec 03, 2010 | Compaq ProLiant DL380 Server
I'm have one server ibm with 1Gb of ram and i want to upgrade but don;t know about it can be support thank for help!
Technology: DDR SDRAM - ECC, max 4Gb, Memory speed: 400MHz, Form factor: DIMM 184-pin, Memory Specification Compliance: PC3200
Jun 30, 2010 | IBM xSeries 206 Server
Compaq proliant 5500 server wont power up
In my experience when a server/computer does absolutely nothing when the power button is pressed it is a dead processor. That may not be the case in your situation. It could be as simple as a defective power switch. Is the switch a soft touch or does it push in and click? Does the switch feel normal when pushed? One of the power supplies could also be bad. Do you have any good power supplies to test in the server? Were there any power outages recently that could have caused damage to the PSU? I would start with checking the switch. You could hook up a circuit tester and see if the switch completes the circuit when depressed. Also take a look inside the server and look for any loose connections on the mainboard. It is possible the wire for the power switch has come loose.
Sep 05, 2009 | Compaq ProLiant 3000/5500 Redundant...
Mobo wont power up
yes u can, test it with another PSU...good luck.
May 25, 2009 | Gateway Media Center Desktop PC
Faulty Panasonic Projector
90% that this is a bad psu !
had mine fixed today with used psu from ebay.
try to find a faulty pt-ae900 for a exchange psu !
60€ faulty projector + 60€ psu = 120€ for pt-ae900
hooray :)
cheers,
tobias
Dec 31, 2008 | Panasonic PT-AE900U Multimedia Projector
HP ProLiant ML110 G5 (444809-001) Server Logo
137 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
