Question about Compaq Computers & Internet
Replace memory CQ45-805TU
How to replace memory
Tip
Resetting the bios password for Toshiba Laptop
It working with the Satellite A135
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back the black lebel back from memory module 1, I soldered PAD500 solder pads (to short circuit them), install one memory memory in slot 2 and turned notebook on, it erase the password and boot without asking for one. Then power off desolder PAD500, replace mylar. Replace memory modules. Replace battery. Power up unit, replace memory cover and screw. Whalá!! the password gone, and you can enter to bios setup to set a new password if you want.
on Mar 15, 2008 | Toshiba Satellite A135-S2276 Notebook
The PC does not start.Only it beeps and a red light blinks,also fen is not working.
here are some of the basic codes, depending on which BIOS you have...
Also you do not indicate which fan? I would guess you mean the main Power Supply (PS)? In which case it could just be you need to replace the PS.
Here is a link to some other codes as well...
http://www.computerhope.com/beep.htm
AMI BIOS ERROR BEEP CODES
  • 1 Beep - Memory Refresh Failure (check memory)
  • 2 Beeps - Memory Parity Error in first 64KB block (check memory)
  • 3 Beeps - Memory Read/Write Error in first 64KB block (check memory)
  • 4 Beeps - Motherboard timer not functioning (possible motherboard replacement)
  • 5 Beeps - Processor Error (may need replacement Processor)
  • 6 Beeps - Gate A20/keyboard controller failure (possible motherboard replacement)
  • 7 Beeps - Processor Exception Interrupt Error (may need replacement Processor)
  • 8 Beeps - Display Memory Read/Write Failure (reseat or replace video card)
  • 9 Beeps - ROM checksum Error (replace BIOS chip or motherboard)
  • 10 Beeps - CMOS shutdown Read/Write error (possible motherboard replacement)
  • 11 Beeps - Bad Cache Memory - test failed (replace cache memory)
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
I hope this helps.
Mar 29, 2011 | HP Computers & Internet
How to replace memory acer aspire 5003wlmi
The maximum memory supported on your notebook is upto 2GB and the compatible memory modules can are 1G PC-2700 S.O. DIMM.
Regarding the Memory replacement procedure, please download the user manual from the below URL, where you can find the instructions for replacing the memory:
http://search-manual-online.com/download/manual/ACER%20MANUAL/aHR0cDovL25ld3Nncm91cHMuZGVya2VpbGVyLmNvbS9wZGYvQXJjaGl2ZS9SZWMvcmVjLmFydHMuY29taWNzLm1pc2MvMjAwOS0wNy9tc2cwMDAxNS5wZGY
May 25, 2010 | Computers & Internet
Shut down un exspectedly blue screen
Hello Whittgt hi!, the blue screen is usually caused by a memory problem, replacing the memory will solve the blue screen. Ask a friend if he knows how to remove and replace the memory, Or a friendly dealer where you will buy the memory may give you free or a discount for replacement of the memory.
Mar 13, 2010 | Toshiba Satellite A205-S5804 Notebook
Memory card isshowing corrupt
That means that memory card is faulty and you must replace the memory card.
Test the memory card on a computer using a card reader and test a different card inside the phone.
If the phone returns same error with all memory cards, then the phone memory card slot is faulty, otherwise just replace memory card.
Jul 11, 2009 | Nokia N70 Cellular Phone
My computer cant start up and is making a beeping noise
Most likely a ram problem. Sometimes reseating the memory will fix the problem.
Remove and reseat the RAM On most notebook PCs, removing and reinserting the memory is a simple step and does not require advanced technical knowledge of the computer. HP recommends reseating the memory module before arranging for warranty service repair. If you are not confident following the steps for removing and replacing the memory module in this document, contact an HP support specialist for assistance.
NOTE: If someone other than HP installs or upgrades the RAM, any damage caused by the RAM and/or by the person when trying to install or upgrade the RAM is excluded from coverage under the product warranty. The customer assumes all risk and liability for damages for any such installation or upgrade.Some HP notebooks may have a secondary memory module located under the keyboard. For removal and replacement instructions pertaining to the second memory module contact an HP support specialist for assistance. WARNING: This product contains components that are easily damaged by Electrostatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, set the notebook on a grounded surface that dissipates any static charge, and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC. Use the following steps to remove and replace the memory modules. These steps should be repeated for each memory module installed in your notebook. Step 1 - Remove the battery
  1. Slide and hold the battery release latch to the unlock position.
  2. Use your finger to lift the battery up and out.
Step 2 - Remove the memory module
  1. Locate the memory module cover on the bottom of the notebook.
  2. Remove the screw that covers the memory module.
  3. Use your finger or a flat head screw driver to lift the inside edge of the memory module and remove it.
    NOTE: When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  4. Push both tabs outward simultaneously to release the memory module.
  5. Grasp the memory module by the edges and pull gently to remove it.
  6. After removing one module, replace the memory expansion cover and then replace the screw.
Step 3 - Reseat the memory module
  3. Locate the alignment slot on the memory module and align it to the empty board receptacle.
  4. Grasp the memory module by the edge and push gently to install it.
  5. Press the expansion memory board down to latch the tabs.
  6. After replacing the module, replace the memory expansion cover and then replace the screw.
After the memory is reseated, connect the AC adapter and turn on the notebook.
Nov 10, 2008 | HP Pavilion dv6000z Notebook
Need a password...
Found these instructions on another website...
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw.
Hope this helps
Regards
Aug 18, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite 310 series (china)
Aug 16, 2008 | Toshiba Satellite A135-S2276 Notebook
HAVE A TOSHIBA SATELLITE A135-S4677 NOTEBOOK AND HAVE FORGOTTEN MY HDD1 INNER BIOS PASSWORD & NEED TO RESET IT IF POSSIBLE.
This works only for some models.
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back the mylar. there should be a set of solder pads labeled JOPEN1. Short the JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw. Hope this helps.
Feb 29, 2008 | Computers & Internet
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
