Question about Onkyo TX-DS595 Receiver
No sound powers up, no sound
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
I have a crown power amp XTi 2000 that will power up and then i hear a clicking sound and it powers down. could it be the switch. it sounds like the sound is coming from that direction
Look on the heat sink for a temperature sensor that operates the overload relay. . Make sure the heat sink isn't overheating. If it is then the output transistors are shorted.
Oct 14, 2014 | Audio Players & Recorders
I have a memorex. I am getting sound but no picture. When powered on, the memorex sign shows up but then no picture just sound. Also makes a slight screeching sound for approx 10 sec. when powered on.
I guess the blanket draped over the TV is intended to give it a "timeout". Anyway, you will likely conclude eventually that the internal power supply has failed.
Jan 02, 2014 | Memorex MLT1921 19 in. LCD TV
Klipsch soundbar (SB1) won't power on ... green light on power adaptor seems to trip and go off when I power on the SB
I have read that this may be due to the order in how the AC adapter is attached to the sound bar. After some research I found that you need to unplug the AC adapter from the wall and the sound bar and let it sit for about 15min. Then flip the power switch "ON" on the sound bar and connect the AC adapter to the rear of the sound bar. Lastly, plug the adapter into the power outlet.
Feb 21, 2013 | Klipsch Audio Players & Recorders
Beeping Noises When Power Is On
Sounds like a faulty power supply or the wire going in/out of it. Try moving the wire and see if that gives you a good connection.
Jun 11, 2012 | Computers & Internet
When using Firewire bus to power the sound card my
It's likely that the FireWire bus isn't meeting the power needs of your card. Just use the external supply since there isn't too much you can do.
Jul 13, 2010 | Edirol FA-66 Sound Card
Clicking sound when power is off
have the power supply tested or use a diff power supply in your cpu, just to see if the clicking sound will disappear,if it disappear then a power supply replacement would be beneficial, if not then have your cpu check by a qualified tech to see where is that sound coming from
Nov 21, 2009 | Gateway Bestec ATX-300-12EB3 305w Power...
Recently when powered up, sometimes the sound
Let verify first to narrow down to where the problem can be. First, attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Nov 19, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Onkyo TX-DS595 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
