Question about Frigidaire GLMV169 Microwave Oven
Interactive display doesn't display
Numbers don't show on display, what can cause this?
Stopped working without power. Unplugging/re-plugging did not work. No display, no buttons responding. Is there re-set option?
there is a fuse inside,take it to someone that knows how to repair,if you use the wrong fuse,you could cause a fire or health problems
Mar 14, 2015 | Sharp R-820BK Microwave Convection Oven,...
Interactive display on microwave
Is it the LCD display that you are speaking of? Is it full vertical or horizontal lines that are out, or only certain LCD segments of the numbers/letters?
Jun 06, 2008 | Microwave Ovens
Microwave not working
see this causes and fix it. God bless you
If the microwave will not work at all, make sure power is on at the outlet and test the electrical cord. Test the fuse and replace it if it is faulty. Also check the door to make sure it closes properly. Test and, if needed, replace the fan.
If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout , and the fan replacing parts that don't pass the test.
Oct 16, 2012 | Kenmore Microwave Ovens
Micrwave not working
If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout and the fan, replacing parts that don't pass the test.
Oct 16, 2012 | Microwave Ovens
Advantium 120 not working
If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout, and the fan, replacing parts that don't pass the test.
Oct 15, 2012 | Maytag MMV1153A Microwave Oven
Why it's not functioning?
God bless you
f the microwave will not work at all, make sure power is on at the outlet and test the electrical cord. Test the fuse and replace it if it is faulty. Also check the door to make sure it closes properly. Test and, if needed, replace the fan. If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout (see the Applaince Controls Fix-It Guide), and the fan, replacing parts that don't pass the test.
If the oven keeps blowing fuses, check for a faulty door interlock or monitor switch.
Oct 02, 2012 | Microwave Ovens
R-820js wont heat
see this causes and fix it .God bless you
Oct 02, 2012 | Sharp R820JS 900 Watts Convection ...
My microwave oven from LG MG 604 W has now starting problem, when we open the door the light is on and even the display is okay we can set the timer but when we press the start button it doesn't start...
The owner's manual should tell you what that symbol means.
If for some reason you don't still have yours, you can download it here.
I would suspect a bad door switch or door switch mount.
You should see my text file on door switches for more information.
You can order LG parts from Encompass here or you can call them toll-free at 866-779-5835.
Sep 26, 2011 | Cuisinart CMW-100 Microwave Oven
The microwave display shows "Door" and it won't
I could have been more specific with a model number, but if this general answer doesn't do the trick, feel free to contact me with your full model and specific symptoms here.
It's usually a bad door switch or door switch mount. My helpful text file on door switches is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's one of those overdesigned Whirlpools, it can be one of many components. See the example photo at the bottom of this reply.
Aug 03, 2011 | Whirlpool GT1195SH Microwave Oven
Interactive display only shows half the letter and number.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
We also have the full service manual for this model at our site, linked above.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 04, 2008 | Sharp R-820B Convection/Microwave Oven
Open Questions:
Frigidaire GLMV169 Microwave Oven Logo
14 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
