Question about Snapper RE110 28 inch 11.5 HP Rear Engine Riding Mower
Was mowing and mower quit moving.could this be clutch
Could the clutch cause the mower to quit moving with the blades turning
  • 2,540 Answers
Its possible but check drive belt as well. If it comes off or broken mower will not move.
Posted on Jan 20, 2016
My Husqvarna riding mower blade quit working while mowing,after I shut engine off it now will not turnover or even click
suspect blade quit working due to low battery voltage to the blade clutch. check your battery connections and voltage. should be 12.6 at rest. its also possible your charging coil has failed causing the dead battery
May 16, 2018 | Husqvarna Garden
Clutch adjustment for engaging dec
You clutch is probably OK. This sounds like some binding in the mowing deck.
  1. Take off the deck.
  2. Clean the underside of the mowing deck.
  3. Remove the belt and be sure all the moving parts move freely. If something is bound, try to free it up with oil.
  4. Replace any bound up bearings. Bearing are a very high maintenance item on a mowing deck.
Good luck.
Apr 05, 2015 | Garden
My mower will die everytime i engage the blades to mow
Check to see if one of your deck spindles isn't seized. Disengage the blades and turn each blade to see if its free. Sounds like either a spindle is seized or your electric clutch on the motor has a problem.
Jul 20, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Tractor quits when engaging the blades
unhook clutch and see if blades stop turnig and then try engage clutch with the switch if motor stays running bad clutch
Jun 01, 2013 | Mtd Garden
Mower quit working om massey 318 gtx
**** it buy a new one
May 18, 2012 | Toys
Mower runs but blades won't engage.
first check for a blown fuse (owners manual will tell location) next try checking the blade engage switch next check the electric clutch good luck
Sep 10, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
I have a 18.5 hp 42" electric start craftsman mower. when i went to engage the blades the lever was harder to move than usual and once it was engaged nothing happened. blades not turning! please help.
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dies when clutch disengaged
It sounds like the seat switch is disconnected or failed. Check it out. If it thinks there is no **** on the seat it will cause your symptoms.
May 25, 2009 | John Deere Garden
Snapper RE110 28 inch 11.5 HP Rear Engine Riding Mower Logo
119 people viewed this question
Top Snapper Garden Experts
ray gallant
Thomas Perkins
Thomas Perkins
mburke3
Are you a Snapper Garden Expert? Answer questions, earn points and help others
