Question about OKI B4250n Laser Printer
Problems with Oki Printer and Toner Sensing
I have the above printer and it called for toner, inserted the toner, and it saying that the ID Unit is not installed and Toner Sensor Error.  Cannot find anything in the "Help" menu and do not have the paper manual.
Can you assist please.
  • 2255 Nov 04, 2007
    I always use the proper brand and the correct toner for my printer without fail. This response was not effective at all.
Still you having the problem after expert suggesion? You did the suggestions given by others? Hope you solved the problems.. Still you get the same problem contact me with correct question.. Because already they give the suitable suggestions..
Why waste money? Save up to 70% on toner cartridges by purchasing toner printer supplies from
<a rel='nofollow' href=""></a>
Posted on May 21, 2008
  • OKI Master
  • 1,113 Answers
Yup Dodgy refill cart without require chip to identify itself to the printer or cart not suited to b4200/4250 , get a real oki toner from your country that suits exact model.
here is code for required product
Posted on Oct 31, 2007
Emty error with new toner. Oki B410
What a usless "solution"...Do you have something that can accually work?
There is a procedure that will solve this issue. I have a new toner inserted and it keeps crying that the toner is empty...I have taken in out and put it back in, Now how do I reset the **** thing?
Mar 06, 2010 | Oki Electric Industry B410D Laser 30PPM...
I changed the drum unit on my c5500 printer and didn't realize that I needed to replace the toner at the same time. I just replaced that toner about a month ago and now it's saying it's empty - which I...
Before you replace a drum unit, you should (with the top toner cartridge still in place) turn the unit upside down and gently shake the toner that is in the drum unit back into the toner cartridge. When you install toner on these printers, most of the toner falls into the drum unit. The only way you can "reset" the printer is to add more toner, because there is almost no toner in that new drum.
Oct 20, 2009 | OKI C5500n Printer
Fatal error : 144 on a Okidata
this is indicated when the toner feed switch error
or the toner locklever-open error occurs repeatedly when new toner is used.
it has to do with the yellow.
3 possible solutions.
Confirm that the lever is in position.
Replace the toner feed unit.
Replace the ID units.
Aug 28, 2009 | OKI C9600hdn Laser Printer
OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Jan 19, 2009 | OKI C5100n Laser Printer
Toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
Oki C3200n Says Order K Toner after install
Two possible problems:
1. You actually got a partially empty new toner. This has happened to me once.
2. The sensor on the printer is dirty and not seeing the toner. With the toner there is a little wipe that says it is for cleaning the LED. There is an LED sensor that "reads" the presence of the toner. If this is dirty it will think there is no toner cartridge.
Jul 09, 2008 | OKI C3200n Led Printer
Oki 3300
When installing the C3300 printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result.
Mar 28, 2008 | OKI C5200n Laser Printer
OKI 9800 with "342" error code
problem might be with toner recycle coil which runs around the back of the belt unit. as the cyan unit is the furthest down the line if any blockages occur it can back up and lift the drum unit up. check the square opening of the recycle unit on the cyan end. Make sure you change waste toner unit when prompted or you might break a gear (big job) Karl Oki engineer
Aug 24, 2007 | OKI 9800hdn Laser Printer
OKI B4250n Laser Printer Logo
1,128 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
