Question about Bosch Washing Machines
Wvh28420gb/03 logixx reset
Logixx does not spin
Bosch logixx 8 varioperfect
you will have a broken spider in the machine
Jul 22, 2014 | Washing Machines
I have a bosch logixx sensitive washing machine code F:43 is displaying what does it mean
Hi there. After doing some research, I've discovered you need to either reset the machine by doing various on/off/pause/spin actions in a certain sequence (the sequence depends on your E-Nr number), or that there is a problem with the main control board.
Oct 11, 2013 | Washing Machines
How do I unlock my bosch washer dryer logixx 7/4. the red lock key symbol is on
Model WVH28420GB :
Firstly, follow the instructions for "Emergency Release" on page 13 of the Operating Instructions for this machine.
If, when you switch on the machine and select a washing programme after doing this, the key symbol still appears, press and hold down the 'Timer' button (second from top on the left hand side of the message panel) for a few seconds until the key disappears. Now operate the machine as you normally do.
Dec 04, 2011 | Washing Machines
F21 what can I do? Please please
Hi
F21 error in your Bosch washer relates to a motor or a control board fault. This can be reset and to reset it turn the appliance knob to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and then press and hold the spin button, then while holding that button turn the knob to 7 o'clock position, continue holding spin button for 15 seconds and then turn the knob to off. After a minute turn it back on, if the error code is still there then it means that the motor or brushes in the motor should be replaced, though it is always better to replace the motor assembly completely. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Bosch Logixx WAS2446 Front Load Washer
Bosch Logixx 8 Washing Machine E-NR-WAS28466GB /03
The heating element has blown - this has happened to mine on 3 occasions all covered under extended warranty - regularly occurs about once per year. Now hear is the interesting bit - do you have a microwave near the unit ? If so move it because our Bosch engineer said that the microwaves can have an effect on the unit. If it is true then I will know next year about this time !
May 09, 2010 | Washing Machines
Bosch logixx 1400 express washing machine spin is not working . ALSO THE WATER IS NOT BEING DRAINED OUT IN THE NORMAL CYCLE
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Apr 10, 2010 | Bosch Exxcel WFX 145S Front Load Washer
The heqating element has blown - common problem on our machine - happens around once per year - under warranty - now on our 3rd new heating element !
Mar 17, 2010 | Bosch Washing Machines
Not heating up
some times the heating coil breaks or the thermal resistor goes bad
Nov 02, 2009 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
