Question about Technical Pro Dv80 1 Single Disc Professional Dj Dvd Player
Can't turn off close captioning
Unable to turn off close captioning
I'm Unable to turn on closed caption. How do i turn on this settings on Intervideo WinDVD 5?
Closed caption possible only if it is supported DVD that you trying to watch.
Jun 02, 2011 | Intervideo WinDVD 5 for PC
JVC model AV-32750..... The close caption feature is toggled on and a large black square is blocking picture. I have no remote to enter the menu settings so using buttons on bottom front. I am unable to...
just look in the section for closed captions----the box is the "text" feature and just needs to be turned off; if you did it without a remote it can be undone the same way.
SD TECH
May 13, 2011 | JVC AV-32750 32" TV
I can't turn the closed captioning OFF on my insgnia flat screen tv model NS-L CD37. i have a universal rca remote & the closed captioning won't go away - HELP !
The problem is that the universal remote is not sending the correct IR signal to your units IR receiver, regaurdless whether or not you turned the captions on with the universal, it is unable to send the signal to turn them off, if you have a menu button on your unit you could try accessing the closed caption option that way, alternatively you can do a system reset, if you can access that menu option, you may need to do a tv retune to get your stations, but the closed captioning should be off. I hope this helps. Good luck.
Jun 07, 2010 | Insignia 37" LCD Flat-Panel HDTV
Close caption problem
Use ur remote turn off CC functions on the remote.
Or go to the menu go to the caption turn everything off like Text or CC1 CC2.
Sep 23, 2009 | Vizio VW42LF 42 in. LCD HDTV
Unable to remove the closed caption through the remote control (Haier) 42 inch flat screen tv. Went through the function and selected 'No' to Closed Caption, but it does not remove it. Thanks, Sandy
I dont know what model you have i see two on there website. i read manual for one of the 42 inch lcd tvs and i do see where you confirmed you said off to closed caption mode am i correct? Ok try this turn the closed caption on and exit menu. now shut off tv and turn it back on. now go into menu and turn closed caption mode to off now and exit menu and see if that helps. ok i hope this helps ....oh i forgot to mention make sure that you didnt enable the closed captioning on your cable box remote. Just might want to check with that. It might not be your tv at all it could be the cable boxes closed captioning service. I hope some of this helps if not see if there is a factory reset in the menu.
Feb 20, 2009 | Haier Televison & Video
Lost remote! How do you turn off the closed captioning?
Try using the channel down button until you reach the menu and proceed from there. Or, you can try purchasing a replacement remote.
Nov 04, 2008 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Insignia TV and Direct TV Remote issue - cannot get the closed captioning turned off
The TV slowly, all by itself, ran closed caption on the major stations.
Unable to turn off through the menu as that option was greyed out.
Now all channels have this unwanted closed caption.
Any similar problems and ideas.
Thanks, Harold
Jul 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Unable to stop closed caption
go to the menu of the movie and turn them off from there
Jan 23, 2008 | Televison & Video
Closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
Nov 27, 2007 | LG 42PX5D 42 in. Plasma HDTV
Missing Close Captioning (Unable to Activate)
get you cable company to give you the code to undo their control of your tv with their remote then try the cc button on the Protron remote and check the miscellaneous section 3 of your controls and make sure the closed caption option is not on
Apr 30, 2007 | Protron PLTV-32 Television
Technical Pro Dv80 1 Single Disc Professional Dj Dvd Player Logo
44 people viewed this question
Top Technical Pro Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Bapco
Are you a Technical Pro Audio Player and Recorder Expert? Answer questions, earn points and help others
