Question about Proform Sport 1000 Folding Treadmill PFTL91205 - !
Cooling fan will not turn off even when safety key is removed
Heater blower fan will not turn off even without key in ignition
"Radiator fan" "Engine Fan" "COOLING FAN WILL NOT TURN OFF"
Click the link below to troubleshoot the problem:---
http://technoanswers.blogspot.com/2012/11/radiator-fan-engine-fan-cooling-fan.html
These will help.
Thanks.
Dec 14, 2012 | 2005 GMC Envoy
Cooling fan runs continuously, even after shutting the ignition off
sounds like it could be a relay.
With everything plugged in and the fans running with the key off remove the cooling fan 1 fuse. Do they stop?
If they do not stop remove the cooling fan 2 fuse. Do they stop?
Aug 15, 2012 | 2002 Pontiac Montana
Cooling fan will not shut off continued even after ignition key is off and removed, and small black box in front of battery keeps making a clicking noice
That would be the relay box, remove the lid and remove the relay that controls the cooling fan circuit. and that would be the one making the clicking noise. It will probably be very hot, If you have pulled the right one the cooling fan will turn off. Replace it with a new one. Should be fine now, however in the event that the problem does not go away then replace the engine coolant temperature sensor. Good Luck From Ernie @ RedDeer, Alberta, Canada.
Jan 14, 2011 | 2002 Saturn L-Series
Fan will not turn off, even after removing the key
Some cooling fans run even after the enginr shuts off, so that the temp is lowered. If it stays on all the time, then you might have a switch, sensor or relay problem
Oct 12, 2010 | GMC Envoy Cars & Trucks
Whay does my radiator fan stay on whaen i turn the car off
It stays on to continue cooling the contents of the radiator, which remain hot even after you turn your car off. When the coolant is cooled, the fan will turn off.
Aug 07, 2010 | 2001 Nissan Altima
Cooling fan didnt shut off when ignition was turned off
It is the cooling fan relay,it will be in the fuse/relay box under the hood,on drivers side,or near the fans,if you remove the correct relay,the cooling fans will turn off.Just replace it with a new one from the parts store.
Jan 23, 2010 | 1996 Ford Taurus
2001 Volvo s-40 cooling fan comes on after the key is turned off. all the time. (even when COLD) ????
its normal for it to come on when its hot, but if it dose come on when its cold i wouldnt worry about it, if it dose bother you take it to a garage i sure they will say the same as i have,
Jun 05, 2009 | 2002 Volvo S60
The cooling fan doesnt work on my 91 honda accord
  1. Cooling fan Relay
  2. Engine temp Sensor
  3. Cooling fan itself
  4. If While A/C is on Fan does not come on I would Check Fan By unplugging it first than apply Pos+ and Neg- to it if it comes on that's eliminated Then go to step 1-3 one of them is bad I usually replace Engine temp sensors no mater what they are Crucial components for the safety of the Engine.
Jan 13, 2009 | Honda Accord Cars & Trucks
Proform Sport 1000 Folding Treadmill PFTL91205 - ! Logo
20 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
