Question about Salton George Foreman Grp4 Next Grilleration 72 Sq In
Grp4-05 where to buy waffle plate
I made some yummy waffles in my kitchen waffle maker and forgot about the one waffle. Several months later, I went to make waffles again and found a terrible black powder in the appliance. The waffle had...
Unfortunately you have ruined a perfectly good waffle maker...
The coating in there is a teflon coating that needs to be applied properly for it to work...if you try to use it in the condition it is in then the waffle will stick to the plate...
Best thing to do is to trash the old one and then buy a new one...
heatman101
Jun 24, 2011 | KitchenAid Kitchen Appliances - Others
Cleaning your waffle iron WPLT4
Let me start by telling you WHAT NOT TO DO.
  1. Never clean a waffle maker while it's still hot. Let it cool completely.
  2. Never dunk your entire waffle maker in water.
  3. Never use scouring pads, steel wool or abrasive cleansers.
  4. Never use a knife or pointed object to clean your waffle maker(I've actually seen that advised on less reputable sites).
When it comes to cleaning a waffle maker, your first source of information should always be the owner's manual. There are many different kinds of waffle makers, so your buddy Mr Breakfast will gladly defer his expertise to the company that makes your waffle maker.
What I can speak about is my own favorite waffle iron. It's a modern electric waffle iron with non-stick and non-removable baking plates. That's the same kind you have? Oh good. It looks like you came to the right guy.
Cleaning the baking plates:
  1. Remove any small puddles of oil with a dry paper towel.
  2. Brush away any crumbs with a soft-bristled kitchen brush or old toothbrush.
  3. Remove any batter stuck to the iron with a rubber spatula.
  4. To remove really-stuck-on batter, douse the baked-on batter with cooking oil. Wait 5 minutes for the batter to soften. Dab the batter off with a paper towel or cloth.
  5. To prevent staining and long-term oil build up, wipe down the baking plates with a damp cloth or paper towel.
  6. Make sure the waffle iron is completely dry before storing.
To clean the exterior, wipe down the housing and handle with a damp cloth.
Keeping it clean:
There are a couple things to remember to make sure our kind of waffle maker stays clean.
  1. Unless stated otherwise in the manufacturer's instructions, you should never coat the baking plates of a non-stick waffle iron with cooking spray. Over time that will give you a gummy build up that will turn your waffle maker to junk. Today, when a waffle maker makes the claim that it's non-stick, they really mean it. The only oil you need is the oil in the recipe. If your waffles are sticking, it's your batter that needs more oil, not your waffle maker.
  2. Unless stated otherwise in the manufacturer's instructions, don't use soap to clean your baking plates. Soap can be the enemy of a non-stick surface. Oil - on the other hand - can be a great friend. It creates a thin layer that helps maintain the non-stick surface. Soap will completely obliterate that layer of friendly oil. Harsh soaps can deteriorate the manufacturer's non-stick surface over time.
Mar 05, 2011 | Salton WM4 Waffle Maker
I have a swb7re waffle iron. What's the best way to clean it?
Hello, W/D here.
Not everyone will tell you this, but here's the best way. When you are finished with the waffle maker, the plates will be oily. That's good. Wipe down the outside of the appliance with mild soapy water, followed by clean water. Wipe down the plates with clean water only, just enough to remove any left over waffle material. Then, dry the plates with paper towels, or a soft cloth. You want to avoid detergent on the plates, as this strips the oil off which seasons the plates, making better waffles.
Best regards, --W/D--
Feb 10, 2011 | Star SWB7RBE Waffle Maker
ProLine waffle maker sticking. Followed all direction from factory. No Pam used.
The plates on the waffle maker need to have some sort of cooking oil or butter to lubricate and prevent your waffle mix from sticking.
Spray some PAM on the plates once the correct temperature has been reached, or alternatively brush on a little melted butter or vegetable oil. Pour in your waffle mix and when cooked the waffle should lift straight off.
Jan 16, 2011 | KitchenAid Pro Line¿ Waffle Baker
How do i clean a phillips kb5500 waffle maker. can you submerse it at the plates don't seem to detach
no,,,,dont put it into any water,,,,heat up the waffle maker then wet a dish cloth and put it in the waffle maker for a fuw seconds,,the steem will clean the plates and you can then wip the plates off with a "hand full" of paper kitchen towel so you dont burn your hands,,, to keep it clean just after cooking put a drop of cooking oil in the waffle maker wip it round with kitchen paper
Jun 27, 2010 | Kitchen Appliances - Others
How to clean the waffle plates? Can they be
There's no problem, you can put them in the dishwasher.
Apr 03, 2010 | Toastmaster TWB2 Cool Touch Belgian Waffle...
Clean belgain waffle maker
Most of the newer waffle makers within the last 10 years or so you cannot remove the plates, you can try going to toastmaster.com find their customer service link most usually list an 800 number you can call or they give you an email link
Mar 28, 2009 | Toastmaster 217 Cool Touch Belgian Waffle...
Waffle plates are worn, iron too hot
You can order these parts directly from Gold Medal...
Phone: 800-543-0862, Ask for Technical Service
www.gmpopcorn.com
The part number for the plates is 75090 and the part number for the thermostat is 76337
Mar 24, 2009 | Gold Medal 5020 Waffle Maker
I need instructions for a waffle maker mine are lost
When making a waffle have your batter made plug in your maker and get it started heating if there is a light it will go off whenit is hot enough if not wait aprox 2-3 minutes at the most 5 then spay or brush the inside of the plates with a nonstick cooking spray or brush with butter then pour your batter in the center of the bottom plate and close the lid it should start steaming right away watch the steam it is a never fail indicater of how done your waffle is the less steam the more done your waffle is, there is a lot of trial and error with waffle makers, you should spay or brush between each waffle or they will stick. Let me know how it all cooks out. goofballlovers
Mar 24, 2009 | Kitchen Appliances - Others
Repalcement plates for Model 270A Toastmaster Waffle Iron?
There is no way you can get replacement plates for you Toastmaster cheaper than you can buy a new one, the most expensive Toastmaster waffle maker I found was $30. the cheapest was $15 shipping will be at least half of that.
Feb 09, 2009 | Toastmaster 287 Waffle Maker
Salton George Foreman Grp4 Next Grilleration 72 Sq In Logo
Top Salton Kitchen Appliances - Others Experts
Gareth Cockram
Gareth Cockram
Jerry Greenberg
Jerry Greenberg
Robert Plante
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
