Philips tv error codes 12 for 42pfl3603d/27
I have a 42PFL3603D/27 it blinks 1 long red then 2 short red. Do I understand this is error code 12? What does that code mean and can I fix it myself or do I need a repair shop?
    Top Expert:
  • Televison & ... Master
  • 74,473 Answers
Power supply problem. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 30, 2014
  • 52 Answers
SOURCE: Philips 42PF5321D/37 Error Codes
replacing ssb for 4 blink error was correct as error is communication failure specific to micro processor on ssb. getting an alternate error after replacing ssb would suggest either wrong ssb or defective ssb. verify vendor number on ssb tuner on original and new ssb and if same reorder that board and if not order per original board
Posted on Aug 14, 2008
SOURCE: red light blinking
My one take too long to turn on, relay/green light on and off for hours before it can start, I use a hair dryer to heat it up everytime, aim at the center from top, then it turn on very faster, no need to service
Posted on Oct 07, 2008
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
  • 80 Answers
SOURCE: System will not power up
Remove the back from the set and look at the power board in the center of the TV. It will probably have one of more capacitors with the tops bulging out. Replace them with the same value part. Available from radio shack and almost any electronic suppliers.
Posted on May 21, 2009
  • 44 Answers
SOURCE: Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
?when I turn TV on I get a red light blinks 1 time then 2 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
May 17, 2016 | Philips 42PFL7403D/F7 42-Inch 1920 x 1080p...
Philips tv red blinking light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 27, 2014 | Philips 50PF9966 50 in. HDTV-Ready Plasma...
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
Philips 37PF5521D green light flashes 1 long then 9 short
The fault code is '19'. Counting the flashes to philips TVs are given in detail by the link given below. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ You can get details about the fault codes, blinking codes etc:
Nov 14, 2013 | Philips 37PF5521D 37 in. HD-Ready LCD...
When i go to turn on the tv the red power light turns on and then starts flashing, with an all blank tv screen. I cant get anything but a black screen. The light will flash for a lil while, then the tv...
BLINKING RED LIGHT IS ERROR CODE.
1. Unplug set for a few minutes.
2. Plug back in and turn on.
3. When red power light starts blinking--COUNT THE BLINKS.
4. THREE BLINKS, pause, THREE BLINKS (ETC) IS SHORT PROTECTION AND A DO IT YOURSELF repair for some people. I have complete instructions for this repair.
5. 5 blinks, pause and 5 blinks etc is short on 140 volt line and while not as easy as 3 blink error code it points to places to look at.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Post a comment here when you know what error code is and I will help.
REGARDS, SD TECH
Aug 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
42PFL5332D/37 does not turn on red light flashes 6 times.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Jan 20, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
My philips tv flat screen keeps shutting off and a red flashing code starts blinking?
Not sure what code since you didn't say, but here is the code breakdown.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 27, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
1 long and 4 short blinks for this model is specific to class d audio amplifier on small signal board. if it is intermittent where this sometimes happens and you can unplug and replug and power back on would be related to the firmware version but if version is correct you would still need to replace ssb
Aug 17, 2008 | Philips 50PF9830A 50 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
