Question about Motorola Mobility MA580 (612572111116) Cordless Phone
Motorola 580 handset not working
My handset isn't working. I tried to hit talk and it just beeps. It is fully charged and shows it's charging when I lay it on the set. The speaker phone works. When I hit the locater it doesn't beep to the handset either. Help, it's my only home phone!
  • Anonymous Dec 12, 2007
    it's always being charged when the handset is in the base. why?
  • toddlaw Jan 16, 2008
    Same problem here. Tried recycling the power supplies on both units, per Motorola's suggestion, no joy. Tried new battery, per Motorola's suggestion. No joy. The fact that others are having this problem makes me think this was a lousy unit.
Are these phones registered to your base? scroll around in the menu until you come to register and press the "-" key. then quickly press and hold the page button on the base unit. you will here the phone beep. should work now
Posted on Mar 23, 2008
My handset does not connect to the base station. It flashes momentarily, but does not find the base. The base station has a humming noise when the phone line is disconnected and the talk button is depressed. Hum is also present when the phone line is reconnected. The problem was resolved by replacing the 9VDC power supply. The hum disappeared and the handset immediately connected to the base.
Posted on Mar 01, 2008
Battery doesn't charge
Shirley, check if you inserted the chip properly. Usually the bars are your wifi strength. Most likely its the chip.
Mar 02, 2014 | Panasonic Lands Phones
Phone says no link to base reconnect to mainbase ac addapter
The instructions worked after the additional KX-TGA402N handset was fully charged and I kept pressing the menu/ok button of the additional handset to advance from initial settings to the handset registration mode.
How do register an optional accessory handset to my existing main base...
Feb 08, 2013 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
Handset 2 show unavailable
there is some battery problem with your phone please service it asap.
Jun 21, 2009 | GE 25841GE3 5.8 GHz Twin Cordless...
My uniden dct648-3 keeps saying "warning please wait" and it fully charged - so it says. i can hear the phone ring but as soon as i pick it up and hit talk, that darn message appears and i hear nothing....
I had this exact same problem. I had to reset all three handsets. Select menu, system reset, replacing base, then follow directions. This worked for one unit but the other ones I had to buy new batteries eventhough they showed fully charged. Good Luck
Jun 05, 2009 | Uniden DCT648-3 Cordless Phone
Cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at
However, my problems were cleared when I cleared the handset with the second set of instructions.
Apr 25, 2009 | Uniden DECT 6.0 Cordless Phone ID
I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
My handset won't charge
Try charging it in a different cradle if you have more than one handset.  This has happened to me where a particular base will not charge a particular phone.  Once charged elsewhere the problem resolved.
Feb 14, 2008 | Motorola Mobility MD671 Cordless Phone
Battery Charging
If both the charger and the battery are warm to the touch, the battery is probably charged.
The low battery level warning level is learned by the phone. To train it, allow the battery to run down once until the phone stops working, then recharge it.
The best way totest the charging operation would be to try using the phone. Fully charged you should get about 6 hours of talk time from a fully charged battery, and at least a week of standby operation.
Dec 25, 2007 | Motorola Mobility V176 Cellular Phone
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
My Phone Won't Recieve A Signal?
I Have exactly the same problem. maybe someone found a workaround for this issue? Thank you
Jul 21, 2007 | GE 26939GE2 Cordless Phone
Motorola Mobility MA580 (612572111116) Cordless Phone Logo
339 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
