Question about Body Solid Exercise & Fitness
Too much play in the pulley sysetem
I have too much play in the pulley system. When I use the pec fly position the arm bars move about 4in before engaging and moving the weight. I have to raise the top weight play several inches and adjust the chain link at the bottom of the machine to tighten it up but I think there must be a better way. What am I doing wrong. Thanks
catriver
  • 878 Answers
SOURCE: The arms of my dish washer won't move
First thing you want to do is make sure the spray arms themselves are o.k. The ports are not clogged and there are no cracks. Once you are satisfied this is not the problem, check the seal ring on between the lower spray arm and the spray arm support on the pump. See if it is out of position or damaged. Make sure the water level is not too low, should just come in contact with the bottom of the heating element. Next check your filters, look for garbage, plastics, anything that would clog it. Last would be the pump itself. Ron
Posted on Apr 18, 2006
djproaudio
  • 515 Answers
SOURCE: Kenwood KD 3070 turntable
There should be a set screw that you can tighten in order to adjust the height return. If you do not have anything like this, perhaps your record is raised too much. How thick is your rubber mat? Do you have any other mats sitting on top of this?
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
Posted on Sep 13, 2008
SOURCE: Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Posted on Oct 03, 2008
SOURCE: adjusting timing on brother pe 150 embroidery machine
How do I adjust the timing on my machine?
Posted on Oct 04, 2008
DickCanFixIt
  • 948 Answers
SOURCE: chain needs to be 1/4
1/4" is too tight, you should have one inch minimum. Check it while the bike is upright sitting on the tires. Move the longest part of the chain up and down and you should have one to one and a half inches of play.
As a comparison, my BMW 650 has seven inches of suspension travel at the rear and my spec is 45 to 55mm which is about an inch and 3/4 to two inches.
Posted on Apr 27, 2009
Air conditioning belt broke - need to replace it
Make sure the path of the belt is correct. The belt is tightened by a spring loaded arm with a pulley on it. There is a cut-out or raised position molded into the spring arm for a Rachet or breaker bar to attach. It will be a square shape to match the 1/2 drive breaker bar.
When force is applied, the arm will move and contract the spring. This will provide room to slip on the belt with your free hand.
The idea is to slip the belt on at the easiest point. Often this is the top pulley on the Alternator.
What you should also do is rotate each pulley on the engine, including the A/C, by hand, to diagnose bad bearings, which will have a rough rotation.
There are some spring arms which can be pressed by hand, without a tool, to provide the clearance to slip on a belt. Really depends on where the spring arm is and how strong you are. Just route the belt around the spring arm and press with your body weight to move the spring while slipping the belt on the Alternator pulley or any you can reach.
Jan 21, 2014 | 1988 Lincoln Town Car
Tip
Replace or install a serpentine belt
This may not work for all engines but should work for most. Most engines are the same when it comes to a serpentine belt. There is a series of pulleys. Some are ribbed and some are flat. The belt will go on to match. The ribbed side of the belt will pass across the ribbed pulleys and the flat side against the flat pulleys. It is fairly easy to figure out the outermost pulleys which the belt must go around. Once you have done this you can assess which ones to put the flat side of the belt against.
One of the pulleys is the tension pulley. It is generally on a moving arm and has a spring tensioner. When the belt is off, the arm should move.
When a belt is on the engine you have to release the tension to remove it. This generally requires a fairly large breaker bar or a socket wrench with a cheater pipe to generate enough force to release the tension. There is generally a nut that holds the tension pulley on. If you are loosening the nut when you pull with the breaker bar you are pulling the wrong direction. It takes a good amount of force to loosen the tension on the belt. If you removed the tension pulley as a means of removing the belt you will have to reattach the pulley and then make sure you pull in the correct direction to allow the belt to go over the tension pulley to reinstall.
If you are replacing a broken belt you have to move the tension pulley to allow the belt to slip onto it. Pull the breaker bar to move the pulley. Pulling it far enough allows the belt to easily slip on. Again, if the nut is loosening or you aren't moving the pulley and arm you are pulling the wrong way. It takes quite a force to move the pulley.
Once the belt is on the tension pulley, make sure it is properly sitting on all pulleys and the grooves in the belt match the grooves on the pulleys.
Be careful not to pinch any fingers.
And make sure you don't leave any sockets attached when starting the engine.
on Jun 07, 2010 | Buick LeSabre Cars & Trucks
How do you make the tensioner release to tighten the timing belt?
The belt tensioner keeps the belt tight inside each accessory pulley while the engine is running. The tensioner is made up of a spring-loaded arm. If the spring inside of the tensioner becomes loose then it will not be able to hold the belt properly.And belt will also get loose. The belt tensioner is on the engine underneath the alternator. Its fitted by bolt.To loose the belt you will need drive socket and breaker bar .Turn the breaker bar counterclockwise to release tension from the belt.Remove the mounting bolt at the top center of the tensioner arm.The tensioner arm is loose and will easily come out.If you in-case are to replace the tensioner then place the new tensioner in same place and tighten the bolt which you removed.Before removing or moving the belt check the position of the belt passing from each pulley.so that when you fit the parts there is no problem in fitting the parts.
After its done.Start the engine and see that belt and tensioner runs freely and belt moving from each pulley smoothly.
------------- This will help.Thanks.Helpmech.
Dec 06, 2010 | Pontiac Grand Am Cars & Trucks
How to install a serpentine belt on a 1994 mercury grand marquis it seems that i can get a 3/8 or 1/2in ratchet to move tensioner
It is sometimes pretty tough getting it to move.
Make sure you are Rotating it the correct way.
Do you have a Breaker Bar or a Serpentine Belt Tensioner Tool. Stores like Harbor Freight and even some Auto Parts Stores have these. Some of the auto parts stores have these for rent (for free with a refundable deposit).
I like and use weekly the Serpentine Tool from Harbor Freight (Item #66344-0VGA- $20). It is narrow enough to fit in most tight spots. The main bar has a 3/8-in fitting, and the extension bar can connect to this with a 1/2-in fitting.
The idea is to have more leverage. The Ratchet and/or Wrench sometimes does not provide that leverage needed.
When installing follow the below guidelines. DO NOT try to put the Belt on the Tensioner last.
"HOW TO":
Standard Rules to Removal the Serpentine Belt with an Automatic Tensioner:
1. Find the Tensioner(s).
2. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
3. Remove the loosened belt off one of the other more easily accessed Pulleys.
4. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
Standard Rules for Installing the Serpentine Belt with an Automatic Tensioner:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them.
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
Apr 07, 2010 | 1994 Mercury Grand Marquis
I'm having a heck of a time trying to get the old belt off. Is there a trick to loosening the tension-pully? I'm using a 15mm socket to try to turn the nut on the pulley to move it down, but it won't go....
You probably aren't applying enough force. You need a fairly long breaker bar or something to slip over the ratchet to get more force. One direction actually loosens the nut. Push/pull the other way.
Mar 13, 2010 | 2001 Chevrolet Impala
Need to change belt on 2003 Pontiac Montana. Where is the release point to start?
there is a tensioner in the system it is a flexiable arm with a big spring in it and a pulley attached put a socket on a braker bar and move the pulley the opposit way of the belt and the belt will come loose (remember that you must hold the breaker bar due the tension on it till you get the belt off the pulley remember the belt routing when reinstalling
Mar 01, 2010 | 2003 Pontiac Montana
HOW TO CHANGE DRIVE BELT ON MY 98 GMC SONOMA 4 CYLINDER
it may be easier to attach the breaker bar to the tensioner arm from under the vehicle to relieve belt tension
  1. On 1994-97 2.2L engines and 1994-96 4.3L engines, using a 1/2 in. breaker bar and if necessary, with a socket placed on the tensioner pulley bolt, rotate the tensioner counterclockwise to relieve the belt tension. On some 2.2L engines it may be easier to attach the breaker bar to the tensioner arm from under the vehicle.
  2. On 1998-99 2.2L engines and 1997-99 4.3L engines, using a 3/8 in. breaker bar, rotate the tensioner counterclockwise to relieve the belt tension. On some 2.2L engines it may be easier to attach the breaker bar to the tensioner arm from under the vehicle.
  3. Remove the serpentine belt.
To install:
  1. Route the belt over all the pulleys except the tensioner.
  2. Place the breaker bar and if necessary the socket, on the tensioner pulley bolt and rotate the tensioner counterclockwise to the released position.
  3. Install the belt and return the pulley slowly to its original position. Do not let the pulley snap back into position as this may damage the belt and pulley.
  4. Check that the belt is properly seated in each pulley.
Oct 11, 2009 | 1998 GMC Sonoma
Tensioner not move what do i do 1999 dodge caravan
Here's how to get a serpentine belt on or off (You'll need to do both). It's easy and doesn't require a prybar.
On:
  • Get a 14mm or 9/16" socket and a long handled ratchet or breaker bar.
  • Get the belt around all the pulleys except the A/C compressor or Alternator.
  • Locate the tensioner pulley. It's one of the smaller ones and is mounted on a spring loaded arm. It's job, as the name suggests, is to keep the belt tight. Get your socket on the center nut of this pulley.
  • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt on the final pulley.
  • Slowly release the tension.
  • You're done
Off:
  • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt off one of the pulley's (A/C or Alternator is best)
  • You're done
Mike
Mar 26, 2009 | Lisle Serpentine Belt Tool & Accessories -...
HOW DO I REMOVE SERPENTIENE BELT?
On one of the pullys you will see what they call a tensioner pully. Its a small pully with a flat surface with no lip to to prevent belt run off and is the only pully that will pivot on a springloaded arm. Also, the backside of the belt will be the side running across that pulley. Look at the arm on that pully and sometimes (depending on the design) you will may see a Square hole. That hole is made to place a 3/8 " rachet drive or breaker bar into it and by pushing or pulling (depending on your position relative to the pully) you will pivet the tensioner pully so that the pulley moves away from the belt. It should pivet in one direction only. Watch the tension in the belt go slack. Then as you keep the pressure on the ratchet with the pulley fully released (when you can piviet it no more) use your other hand and slip the belt out from under the pully. If you do not see a square hole you can will need to use a pry bar and find a location to pry against the pulley arm that will release the tension. This arm is spring loaded so use caution and be safe that you do not slip to avoid injury.
Mar 17, 2009 | 1997 Kia Sephia
Exercise & Fitness Logo
35 people viewed this question
Top Body Solid Exercise & Fitness Experts
Howard
Howard
John
Tom Chichester
Are you a Body Solid Exercise and Fitnes Expert? Answer questions, earn points and help others
