Question about Cell Phones
Diamond antenna CP5
Hi do you have details of the matching network in base of the CP5 antenna please?
Antenna - Uniden Bearcat BC 895, antenna broke off at the base. Can still put it in the hole, then it seems to work. Will I need to replace the antenna, or is there another solution? Thanks.
no best to replace the antenna, they are not expensive. radio shack carried replacements once not sure about now, but other companies carry better antennas than the one that came with your scanner. Diamond, Comet, Smiley, and others.
Jan 10, 2014 | Radio Communications
No network coverage
Hi this problem could happen when:
1-your antenna is not attached correctly because your phone crashed or dropped
2- Your antenna switch IC has problem (because dropped or dust or COLD SOLDERING)
3-your matching circuit after the antenna(1 inductance 1 capacitor) cutting off
4- your PA (power amplifier) IC has problem
5-your RF circuit totally is gone
take your cell phone to a certified nokia shop to repair it
kind regard
Apr 17, 2013 | Nokia C1 Cell Phone
HI I NEED TO UN LOCK MY HTC DIAMOND SO PLEASE HELP ME FIND MY UNLOCK CODE MY IMEI NUMBER IS 357568012310707
To get Your HTC Diamond Unlocked from the Network lock,you can reach here Superunlockcodes get the Unlock code at low cost and Unlock it from Network Lock,..
Jul 23, 2011 | Cell Phones
Poor radio reception.I've tried a new aerial mast,no improvement. CD player sounds fine. Any ideas? (Passat Est.2003)
Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 1 Subject: Model(s): Group: Number: Date: AM Radio, Poor Reception 1999, 2000 91 99--07 New Golf, New Jetta, Aug. 2, 1999 New Beetle, Passat Condition AM reception is poor. May be caused by: ? An incorrect antenna mast installed for the antenna base equipped with the vehicle ? Poor ground at the antenna base or radio ? Poor battery ground to chassis or engine ? Poor antenna cable connection at Radio ? Corrosion at the antenna coaxial connectors at radio or antenna Service Vehicles are equipped with either a Bosch or a Clarion antenna base mounted on the roof and (for shipping purposes) the appropriate matching mast is located in the luggage compartment. If radio antenna masts are removed from vehicles and stored until vehicles are sold, there is a chance that an incorrect mast can be installed at the time of delivery. Note: Mismatched antenna mast and base will cause poor AM radio reception. The antenna base and mast can be identified visually as follows: (Cont. on Page 2)91-A260 requires gloss finish antenna mast 57mm 49mm Bosch 91-A261 requires matte finish antenna mast 61mm 41mm Clarion 91-A262 Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 2 Bosch antenna ? Base (although oval) is more circular in shape (approx. 57mm x 49mm). ? Made in Germany stamped on underside of base. ? Two screws on underside of base are unpainted. ? Requires gloss finish antenna mast. Clarion antenna ? Base is more oval in shape than Bosch (approx. 61mm x 41mm). ? Two screws on underside of base are painted. ? Requires matte finish antenna mast. If antenna mast matches the antenna base correctly: -- Check antenna coaxial cable connections --arrows-- for corrosion and clean if necessary (DO NOT apply stabilant). Passat coaxial cable connection for radio is under the carpet on right side of tunnel near shifter. -- Ensure that coaxial cable is firmly seated in radio (Passat cable connection, see previous step). -- Check ground at the antenna below roof Nut --4-- (torque = 7+1 Nm) must firmly secure antenna to roof). (Cont. on Page 3)Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 3 -- Check ground for radio behind radio on cross member (On Passat models as of Nov. 1998 beginning VIN: XE285000 ground for radio is on right side of center tunnel). -- Check engine compartment ground, left side, below battery tray; frombattery GND to body. -- Check engine/transmission ground on transmission, near engine block. -- If all grounds and antenna mast are OK. -- Replace antenna and coaxial cable assembly
May 06, 2011 | Car Audio & Video
Low signal for the network
Here are 10 tips to help improve your wireless network. Please refer to this website artile for detailed explanitation of each tip.
http://www.microsoft.com/athome/setup/wirelesstips.aspx
1. Position your wireless router, modem router, or access point in a central location
2. Move the router off the floor and away from walls and metal objects (such as metal file cabinets)
3. Replace your router's antenna
4. Replace your laptop's wireless PC card-based network adapter
5. Add a wireless repeater
6. Change your wireless channel
7. Reduce wireless interference
8. Update your firmware or your network adapter driver
9. Pick equipment from a single vendor
10. Upgrade 802.11a, 802.11b, and 802.11g devices to 802.11n
May 05, 2011 | Computers & Internet
WILL NOT CONNECT TO WI-FI
If your trying to get on the internet with a wireless connection.and running WINDOWS,(many problems with LINUX) .and I am assuming you DO have a wireless router all set up and configured to broadcast the signal (not hidden) ....first we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
try resetting the router (disconnect the power to it for a few minutes) next --be sure the wifi switch is enabled on the netbook---next---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
follow this is a link to a troubleshooting flow-chart-Do check it out
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If you continue to have problem..indicate at what point in the flowchart it is getting stuck
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this
Jan 01, 2011 | Computers & Internet
Hi i m looking for gps software for my htc diamond to install
visit www. google.com go to search option and type gps software for htc you get the relate site and then download it
Jul 22, 2010 | HTC Touch Diamond Smartphone
Cant send SMS with my HTC Diamond it always says that i shoul check my sms center number and when i do so, it cant read the settings from the network??!! any advice?
Hello friend,
Yes..for this issue it would be best that your contact you carrier because your network might be blocked or locked. Your carrier can send signals to your phone and fix this issue from their base.
Mar 06, 2010 | HTC Touch Diamond Smartphone
Problem while matching CB
You need to understand how to tune an antenna and how the antenna works.
read this article
How to tune your antenna
and here is a list of causes for high SWR
Oct 28, 2009 | Cobra 29 LTD CB Radio
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/589307-02,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
