Question about Toyota Hilux
Torque spec for harmonic balancer crank bolt Toyota 3l 2.8l diesel?
Harmonic balancer crank bolt
  • 701 Answers
SOURCE: torque specs for toyota tercel
Hello vienotkelly: The correct Main bolt torque is 42 foot pounds. The connecting rods torque to 29 foot pounds. The torque sequence for the head bolts and the correct way to tighten the bolts are attached to this reply. Thak You for using6bd0ae1.jpg FixYa. Roger
Posted on Apr 15, 2009
terseo
  • 92 Answers
SOURCE: torque specs for 1998 tercel 1.5L
Main Bearing Cap Torque-42 Ft. Lbs.
Head Bolts Step 1-33 Ft. Lbs. Step 2- Additional 90 Degrees
Rod Bearing Nuts-29 Ft. Lbs.
Hope this helps
Posted on Sep 20, 2009
  • 5 Answers
SOURCE: Head bolt torque specs?
I really really really hope you turned the bolts an additional 90 degrees after torquing to 22 Ft-lbs. Otherwise, you may be taking that head off again.
Best of luck,
David
Posted on Mar 15, 2010
SOURCE: toyota 4k torque settings
torque setting for crankshaft,head,rocker,
Posted on May 06, 2011
jeepguyracin
  • 2433 Answers
SOURCE: i need too know the torque specs on head bolts and crankcam 2.4 engine
on a 2002 2.4 engine head bolts are 'torqued to distance'.
First, install all the bolts, and, in a sequential fashion, starting at the innermost, working outward, torque all bolts to 70 N-m/806 kgf-cm/58 foot lbs.
Next, mark the front side of each head bolt with a dot of paint. Retighten the cylinder head bolts 90 degrees, starting at the inner 2, and working outward.I dont thin anything has changed on this engine since then.
Posted on Mar 19, 2013
Testimonial: "thanx a bunch head bolts are 12 points i need too know what size 12,13mm "
WHAT IS THE HARMONIC BALANCER TORQUE SPECS FOR A 2002 2.7L DODGE INTREPID?
This is for a 5.7 Ram
the torque should be 150-180 ft lbs. anywhere in this range is good.
http://www.fixya.com/cars/t8915727-need_know_torque
Register at this website to get all the torque specs.
http://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f8037c5e2
Aha, I took me 30 minutes, but here you go. The secret was the change of search query wording to;
2002 2.7 DODGE INTREPID TORQUE SPECS crankshaft damper
(198) Install damper center bolt. Tighten center bolt
while holding the damper with Special Tool 8191 to
170 N•m (125 ft. lbs.) (Fig. 76).
http://www.dodgeintrepid.net/18-general-discussion-second-generation/61664-so-your-2-7-ready-some-100k-repairs.html
WHAT IS THE HARMONIC BALANCER TORQUE SPECS FOR 2002 2 7L DODGE INTREPID...
Jan 11, 2017 | 2002 Dodge Intrepid
Torque specs for the harmonic balancer on a 1994 buick roadmaster
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Oct 18, 2016 | 1994 Buick Roadmaster
1995 GMC Suburban 6.5L diesel crankshaft harmonic balancer bolt tourque?
from 98 GM manual crank balancer bolt 270Nm or 200' lbs
crank pulley bolts 50Nm 0r 37' lbs
Copied from this site;
Harmonic balancer torque value Diesel Place Chevrolet and GMC Diesel Truck...
Hope this helps.
Feb 24, 2015 | GMC Cars & Trucks
Torque spec on my harmonic balancer on my ls-1
1999 chevy Camaro 5.7
Crankshaft Balancer Bolt (Installation Pass-To Ensure The Balancer Is Completely Installed)
240 ft.lb Crankshaft Balancer Bolt (First Pass-Install A New Bolt After The Installation Pass And Tighten As Described In First And Final Passes) 37 ft.lb Crankshaft Balancer Bolt (Final Pass) 140 deg
Oct 12, 2014 | LIS 52650 Harmonic Balancer Installer
Torque spec for 1RZ harmonic balancer
how can i set a toyota 1rz engine on timing
Jul 19, 2012 | Cars & Trucks
I am in need of the torque settings on a 92 cresida twin over head cam 3L for the harmonic balancer, timing belt tensioner and cam pullies.
if you call auto zone they will be able to give you the torque specs. and the pattern... or you can go to the library and look in the chilton or haynes manuals...
Mar 19, 2010 | 1992 Toyota Cressida
Lost bolt for harmonic balancer what size is it? Why did it come off?
I have seen this and you can be glad if the balancer didn't move and damage the crank or t-belt area. Get another bolt and torque it correctly.
Jun 06, 2009 | 1994 Toyota Pickup
Toyota Hilux Logo
141 people viewed this question
Top Toyota Toys Experts
Thomas Perkins
Thomas Perkins
Rabbit Brains
Rabbit Brains
Stan Ford
Are you a Toyota Toy Expert? Answer questions, earn points and help others
