Question about la-z-boy.com
Part 15000693-00l fell out from underneath my recliner can i replace it myself
I just want to know if I can fix this myself. I had nothing but problems with the recliner on that end of the sofa
How do i replace 2 3" springs on stratford recliner.
Get Recliner-Handles Sofa Spring Repair Kit for La-Z-Boy ...
? 1:37
www.youtube.com/watch?v=_hHUNVAQsk0
May 28, 2015 - Uploaded by Faith Rogers
Recliner-Handles Brand Replacement Sofa, Sectional, Couch, Love Seat, Recliner, ... This sofa seat spring ...
Replacement Recliner Release Handle For Stratford and ...
www.recliner-handles.com/replacement-recliner-release-handle-for-stratf...
This flapper handle will fit Stratford and Stratolounger recliners and others that ... 3 3/4 X 3 INCH INEXPENSIVE EASY WAY TO REPAIR YOUR RECLINING ...
Oct 31, 2015 | Washing Machines
Why doesn't power button work?
You will have to turn that bulky recliner on its side or even upside down to get access underneath. Inspection may reveal that the real problem is damaged or disconnected wiring but it may turn out that the switch is defective and will have to be replaced.
Sep 06, 2015 | Furniture
Recliner sofa won't recline
Try looking next to your seat cover and the arm rest for a little pull handle. If it is a pushback recline model tried looking to see if the shipping ties are untied underneath. Or try simply pushing back while you're sitting in it with your shoulders.
Mar 18, 2014 | Furniture
ASHLEY 8050025 Rocker Recliner
Refer this problem to Ashley. It may be necessary to replace parts rather than simply repair your recliner
Aug 21, 2013 | Ashley Furniture ASHLEY 8050025 Rocker...
The passenger side chair no longer reclines how can i fix it, i think the spring may have become detached. can i remove the chair and fix myself?
I believe you can, there should only be four bolts holding down the chair, when you git it off look underneath it and you will see the problem. If you have any electrical connections, don't worry the only plug in one way, and there are usually only one. Good luck man. (or woman)
Nov 06, 2009 | 2005 Mazda 3
Metal nail fell into the garbage disposal.
Just above the motor par of your incinerator there should be 3 or 4 small bolts or srews that holds the main motor onto the waste chute TURN OFF THE POWER. Remove these bolts to seperate the motor and you should be able to remove the nail. Please, please make sure the power is off.
May 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Start knob fell off
order a new one from sears replacement parts
May 04, 2009 | Kenmore 43142 Front Load Washer
Stuck in recline
I know this post is old but I figured somebody w/the same problem might come across this. I had the same problem with my Marathon today. I also own a Roundabout & had no problem changing the recline myself. When my husband came home he took a look & fixed it. All he did was put it in the upright postion , held it in place & turned the seat on it's side & pushed up on the base and it clicked! he pushed on one of the corners (but I don't know if that even matters)
Jan 05, 2008 | Britax Marathon
la-z-boy.com Logo
149 people viewed this question
Top la-z-boy.com Computers & Internet Experts
David Payne
David Payne
Are you a la-z-boy.com Computer and Internet Expert? Answer questions, earn points and help others
