Question about Mamiya 645 Pro 80mm F2.8 N/L Lens
I have a mamiya 645 pro camera I can't remove the old film spool from the camera ? JoAnn
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
Squeeze the two handles on either side of the "120" or "220" label on the film holder to pull it out, then the spool is easily removed.
Posted on Jun 16, 2009
How do you remove the left strap post on a Mamiya 645 Pro?
Not something you can do your self as it involves removing the case. Would be useful to have it serviced cleaned and calibrated. Nice camera, I have a Bronica ETR 645.
company now run from this website
http://www.mamiyaleaf.com/
Looks like these people may be able to help and they carry spares.
Mamiya and MAC Camera repair Parts
Sep 14, 2015 | Mamiya Photography
Mamiya 645- broken mirror stop.
If you find a source, do share. I am looking for the shutter stop to be fixed on my Mamiya 645 Pro TL as well. I saw someone online made one out of metal himself... seems like the way to go, but lot of effort.
Jan 12, 2014 | Mamiya 645 Pro TL Medium Format Camera
I bought a second hand Mamiya 645 Af but as soon as I load a film it shows a error message ERR 01 .... what is that ?
From the manual:
"If the error display is not canceled when the shutter release button is pressed again, insert the Dark slide, half-press the shutter release button while pressing the roll film holder's manual film advance button to wind up the film, then contact your nearest Mamiya agent or service center."
If you need a manual, you can download one from
http://butkus.org/chinon/mamiya/mamiya_645af/mamiya_645af.htm
Aug 04, 2011 | Mamiya 645AF Medium Format Camera
I just purchased a used back roll film holder for my Mamiya 654 Pro TL, and I cannot pull the dark slide out. This dark slide has a blue handle, where my other back's dark slide has a red handle, and...
It's been a while since I used a mamilla 645, so forgive me if this is wrong, but I seem to remember the dark slide would only come out with the camera wound on, ready to take a picture.
Dec 26, 2017 | Mamiya 645 Pro TL Medium Format Camera
Mamiya 645 pro shutter doesn't fire
First thing that comes to mind on this camera is that it's a modular camera. This means the film back can be changed mid roll so there is what is called a Dark Slide between the film back and the body.
The dark slide needs to be removed before the camera will function. Also depending on how "new" the film back is there may be a dark slide holder/sleeve on the back side of the film back.
So you remove the dark slide and slide is into the holder so first you don't loose it and also it doesn't get bent.
Diagram
Jan 09, 2011 | Mamiya 645 Pro TL Medium Format Camera
Mamiya 645 Super mirror locked in open position
My mirror somehow got stuck open too, I removed the power winder and grasped the pins in the middle of the silver wheel underneath used to wind the camera. Turn this clockwise until it stops and shutter is completely closed. Test fire camera after. If it doesn't work make sure you wound it all the way.
Nov 25, 2008 | Mamiya 210219 for 645 Pro/Pro TL/Super...
Just got a 645= shutter "release jammed:, I put in new battery and also missing the crank arm, must have had a motor handle before. its like new, meter in prism works new battery,have old 645 J to...
if the shutter is jammed just off the device,and slightly pull the shutter door with your hand 3-4 times.apply a drop of oil on both the sides.and then on the device.and check it will work.
and for the replacement off the handle you will have to check on the old device that where are locks in the back you just have to remove that locks,also check for the hidden screws in the centre or back of the handle.which may be blocking it to be removed easily.
thanks.
Oct 11, 2008 | Mamiya Cameras
Wind / shutter issue (2nd try to post)
It sounds like there is a problem with the frame counter in the film back itself. Try operating the camera with the back removed and on multi-exp to check the shutter functions.
Aug 10, 2008 | Mamiya Photography
Mamiya 645 Super Replacement Parts
You can probably order direct from Mamiya, here is the contact info: Mamiya America
Mar 26, 2008 | Cameras
Cameras Logo
156 people viewed this question
Top Mamiya Cameras Experts
Marvin
Marvin
Tony Parsons
Tony Parsons
Allen Showalter
Allen Showalter
Level 1 Expert
Are you a Mamiya Camera Expert? Answer questions, earn points and help others
