Question about Hoshizaki KM-515MAH-B700PF
Machine is beeping
Machine is producing ice but "beeping" every 10 seconds
    Novelist:
  • 112 Answers
There is a series of beeps. it should beep 1 to 10 times pause then beep again. need to know how many beeps between pauses.
Posted on Mar 30, 2014
3 Beep Warning
Staying in the freeze cycle too long. Usually about an hour. Several things can cause this. Look for water running even if machine is off. Possible stuck float switch. And more.
Nov 08, 2013 | Hoshizaki KM-61BAH 49 Pound Self-Contained...
Ice maker not making ice. When pressing the test button will start to make some and then beep about 3 times, then does not produce anymore ice.
Do not use test button. It test the functions of the board only. You have another issue. Need to know the number of beeps. Usually beeps a certain number of times, then hesitates,then beeps again.
Jul 27, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Ice Machine Beeps every 5 -10 seconds & not making ice
knowing the model and make would help but there are some refrigerator that act that way when they think the door is open.
Dec 17, 2010 | Refrigerators
3 yr. old Hoshizaki km630 mah, Had a hard freeze(24 degrees) at the shop and checked the ice maker that sits outside main bldg. Main water supply line inside that joins the copper pipe to the plastic...
There should be a reset button on your control board inside the electrical compartment.
Turn the system on to ice mode and depress the reset button. This should clear out any and all faults stored in the board and the machine should at least attempt to come back to life.
Look on the outside of the electrical compartment cover. There should be an explanation of what your error code means. I can't remember it off the top of my head. But the list there will tell you what 1 beep every 305 seconds means and the procedures to take from there.
Jan 13, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Beeping 3 times every 3 seconds
The 3 beeps indicates that the unit was in the freeze cycle for 60 minutes. Causes: 1.) Water valve leaking, allowing water to continually enter the system. 2.) Float switch stuck, sending false signal to board. This indicates ice not being produced. 3,.) Low freon level causing long freeze cycle. 4.) Hot gas valve leaking thru causing warmer than normal evap plates=low production. 5.) Expansion Valve not feeding freon properly to evap plates.
Items 1 and 2 are the most common. Number 3 possible due to freon leak in the system. Number 4 and 5 are usually a very rare occurance.
Hope this helps ya.
Sep 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine with constant beeping every 2 seconds
turn it off and on and check the drain line and see if its draining water. some times the check valve needs taken apart and cleaned. the problems corespond to water related problems. usually because its taking too long to freeze. good luck
Dec 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine with constant beeping every 3 seconds
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
Jun 23, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki KM-515MAH-B700PF Logo
57 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
