Display is blue - Computers & Internet
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 91 Answers
Memory bad or try repair your os. is it xp/ 2000/ 98 ?
Posted on Jun 15, 2009
  • 315 Answers
Sometimes depending on how far it will boot and what version of windows it is. You can hit the F8 key as it is first starting up and get into safe mode. From there you can get into "My Computer" and right click on the "c" select the tools tab and do a defrag and schedule a disk check - check both boxes in disk check - one says "check for errors" the other one say "attempt to repair" This will fix it about 60% of the time!!! Good Luck!!!!
    President:
  • 1,952 Answers
Change the dp
SHARP ALARM CLOCK HAS DIM DISPLAY
Some clocks have a display brightness adjustment.
Jun 25, 2017 | Home
Stop one mac screen from becoming multiple screens
Mirroring displays the same image on each display.
  1. Make sure your additional display is properly connected and powered on.
  2. From the Apple (?) menu, choose System Preferences.
  3. From the View menu, choose Displays.
  4. Click the Arrangement tab.
  5. Enable (check) "Mirror Displays" in the bottom-left corner.
In the example below. the blue boxes represent each display that is connected. The white bar at the top of both boxes represents your menu bar and is shown on both displays when they are showing the same information.
When mirroring, your Mac attempts to match the closest resolution between the primary (or built-in) and secondary displays.
The usable resolution is the closest matching resolution for both the primary and secondary display. If you choose a resolution that is not supported on both displays, OS X reverts to using the closest matching resolution.
Extended desktop With extended desktop, your displays are treated as one, continuous desktop.
  1. Make sure each display is properly connected and powered on.
  5. Disable (uncheck) "Mirror Displays".
In the Displays pane of System Preferences, each blue box represents a display that is currently connected. The size of each box is relative to the current resolution of the display it represents. In the example pictured below, the larger box on the left represents an Apple 27" Thunderbolt Display, while the smaller box on the right is the built-in display of a 13" MacBook Air (Color LCD).
The white bar at the top of the left blue box represents the menu bar you see at the top of your display. Menu bar placement determines which display is treated as the primary display in OS X. To change your primary display, click and drag the white bar from one blue box to another.
You can also drag any of the blue boxes to change a display's represented location. Use this feature to make sure the connected displays match their real world location when navigating your desktop.
As shown below, each display retains its maximum resolution setting as they are operating as individual displays showing a continuous desktop.
lion_choose_max_resolution_.pngPress Command-F1 to toggle between video mirroring and extended desktop
Press Command-F2 to detect displays
May 01, 2014 | Apple 24" iMac Desktop
I'm trying to watch a 3d movie in my blue ray 3d
First off is your TV a 3D TV. If it is you should be able to go into the menu setting (or on the remote) and change the display from regular TV to 3D. Then your 3D blu-ray player should recognize it.
Jul 15, 2017 | Televison & Video
Blue lines on dell lap top inspiron
Check whether blue lines are present in bios screen, if Present then Hardware issue
If Blue line not present in bios screen, Software issue = Restore system back to factory settings
Connect External Monitor, use Fn + F8 to extend display on external Monitor ,
if display is fine on Ext Monitor = Replace LCD Kit
if Blue lines are displayed, on Ext Monitor = Replace Motherboard
Jan 09, 2010 | Dell Computers & Internet
Yellow tint
Hello. Here's the visual key to remember about projectors--LCD panels show their colors like this: RED lcd panel displays cyan onscreen(baby blue); GREEN lcd displays purple; BLUE lcd displays yellow. ( You now know where the displayed dust is!) The problem is most likely a burned blue lcd or polarizer filter in front of the blue lcd panel. This occurs when the dust filter isn't cleaned regularly or properly and heat builds up--yes, enough to "cook" the lcd panel or actually cause a burn to develop on the polarizer. The polarizer is just like a lens in a pair of good sunglasses. It is a small, extremely thin, pane of glass with polarizer material glued onto one side. When burned, it causes a "shadow" effect--that enhances the display of that particular color--in this case, yellow.--Hope I was of assistance!---Rick
Dec 30, 2009 | Panasonic PT-AX200U Projector
Could not play blu-ray disc movie - ? problem w/ display and or ? copyright
to play blue-ray you need to have a blue-ray rom if you have then check if the movie is trully blue-ray, there is not a display problem or copyright.
Nov 28, 2009 | Sony VAIO Notebook
Blue screen on main display
its a hardware problem, its FPC cable is tampered plz get it replaced by Nokia Care or call me at 99999-16148 India
Jun 03, 2009 | Nokia 6085 Cellular Phone
Samsung SP43T6HCX displaying ghost images
May be it is effected with a virus
Apr 20, 2009 | Televison & Video
Blue display
the phone's firmware is corrupted please try update the firmware.
you need serious gear to perform that, so i recommend you to give me a good reate and take it to a phone repair shop that you will never cost you more than 6$ ^^
Mar 26, 2009 | Motorola Mobility C168 Cellular Phone
Computers & Internet Logo
Alun Cox
David Payne
David Payne
