Question about Yardworks Broadcast Spreader Walk Behind
What is the spreader setting for applying expert weed and feed
What is the setting for applying weed and feed by expert
I have a scotts easy spreader what is the setting for weed and feed 28-0-3
It depends on the size of the granules. I've seen some that are small and some that are large. Setting to get the rate right depends on that. If you could provide the brand of weed and feed, we might be able to look it up.
May 12, 2017 | Scotts Garden
What setting is used to apply 1/4 lb per 100 sq ft?
BigVin, normally the bag of seed tell what setting to put spreader on for its proper application, If not try it on #4 setting, it all depend on how fast you wind and walk with a hand spreader. Good Luck.
Apr 04, 2016 | Scotts 71030 Easy Hand-held...
Setting for Bayer southern 3-1 weed and feed ?
Hi Mike:
Just an idea....
Check on the package and see if it gives you the settings.
If not, check with the store where you purchased the product and see if they have a guide /instructions available.
Cheers
Mar 02, 2016 | Scotts 76565 Turf Builder Classic Drop...
I have a scots edge guard spreader and need to put on weed and feed at 4 lbs per 1000 sq feet what setting on spreader should I use
Hi Mike:
The setting will depend on the size of the weed & Feed pellets.
The package usually has setting instructions on it.
If all else fails, the rate is 1 lb per 250 square feet.
Mark out an area about 10 ft by 25 ft long.
The spreader cast is about 5 ft, so down and back should use 1 lb.
Set the spreader at a minimal rate and see how far 1 lb goes, then adjust the setting accordingly.
May 22, 2015 | Scotts Garden
I have an Ortho Whirlybird seed spreader. What setting to use for spreading 3 lb/1000 ft of Prozon Weed Beater?
I too have been going crazy trying to find instructions for this seed spreader. Go to Ortho Products online and select chat. Tell the agent the UPC code for it, which is: 71549-08450. They can then email you the one-page instruction sheet for it. Otherwise try this site where I uploaded it: http://pdfcast.org/pdf/whirlybird-spreader
Jun 22, 2012 | Bonide """bonide"" prozone weed beater"
Ez republic broadcast setting for expert gardener St Augustine Weed and feed for southern lawns
The bag should have a phone number for customer support. They would be the ones to give you the conversion rate for your spreader. How many square feet are you treating?
www.naturewestinc.com
Mar 04, 2012 | Earthway Ev - N - Spred Model 2050p Estate...
What is the best setting for weed & feed for the first time? I just bought the equipment I bought a sack of weed killer & feed. I don't have any ideas as to what level of setting I put the...
The recommended settings for your type of spreader should be listed on the package of the bag of weed and feed you have. There should be a rate chart on the bag. If not, put the setting on your unit on the middle setting, that way, you are not using too little and not using too much.
Apr 09, 2011 | Scotts Company SCOTTS SEED EDGEGUARD MINI...
I have an EZ Spreader by Republic pull behind for my lawn tractor and need to know what setting I need to use for applying Scotts weed & feed along with other applications. Where or how do I get this...
Go to this web page to get all settings......
Once there I would save the file and print it out for future use....
http://www.scotts.ca/media/media/pdf/spreader_settings.pdf
Sep 19, 2009 | Garden
Yardworks Broadcast Spreader Walk Behind Logo
381 people viewed this question
Top Yardworks Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Yardworks Garden Expert? Answer questions, earn points and help others
