Question about Frigidaire Over-the-Range Microwave
Light on not working except clock and ligh
Small light on with a
Everything works on the microwave, the fan, the lights, the clock except it will not cook. You press start and it runs for a split second then cuts off. If you press popcorn it says error door open.
It sounds like a fuse. With the door fuse blown it will cause the microwave to not operate all all. It is a small thing to swap over. Its a bit like a car fuse. There will be a few different ones but all have a different purpose. Not sure if you are handy or a local electrical handyman can do the job.
Mar 16, 2014 | KitchenAid KHMS2050SSS Microwave Oven
My MW clock is on, ligh goes on, keypad works,it counts down but it does not heating up.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 31, 2010 | Emerson MW8991SB Microwave Oven
No power to unit except for clock and light
you can have different problems. power supply issue or control board issue, you will need a tech
Dec 19, 2010 | LG Microwave Ovens
The microwave turns on but does not get hot. The light is on, the the clock, the timer and everything works, except that the food does not get hot. I tried to heat up some water and doesn not change its...
you need to remove the outer cover,then carefully discharge the high voltage capacitor with 2 insulated screwdrivers or an insulated jumper wire,then test this and the high voltage diode and the internal ceramic fuse for continuity
Nov 15, 2010 | Amana ACO1860 Microwave Oven
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
None of the buttons are working; unplugged and
Depending on the model its down to the keypad
Feb 12, 2010 | Panasonic Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Frigidaire GLMV168CS1 Microwave - Sensor Error
If you are handy take it apart. Somewhere inside is a small switch that the door activates. Switch might be broken or a small plastic actuator might be broken. What do you have to lose at this point except time?
Jan 09, 2009 | Microwave Ovens
Microwave stopped working
Generally, you get something unless the fuse inside is blown. There is generally a fuse inside the unit when you remove the button package. First, make sure that the outlet you have is good. Plug something else into it and see that it works.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
The Microwave stopped heating
Probably magnetron failure- needs to go back to the dealers, this is a major job, may be cheaper to replace the oven
Aug 17, 2007 | Samsung SMH7159 Microwave Oven
Frigidaire Over-the-Range Microwave Logo
41 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
