Question about Sony KP-65WS510 65" Rear Projection HDTV-Ready Television
Can't get past screen that says "Set Parental Control Pin"
There is large white screen in front of desired TV image. This screen says "Set Parental Control Pin" However, it does not permit 4 digits to be entered. So, how do I remove this screen that blocks about 80% of the desired image?
  • 24 Answers
SOURCE: remove parental password on ps2
I think the password most is "0000"
Posted on Jul 24, 2008
SOURCE: I WANT TO REMOVE PARENTAL CONTROL
this is not a soultion but does it have forgot your password click on it and it might solve your promblem
Posted on Jan 19, 2009
SOURCE: young son locked tv parental control
Under the main menu, go to the Parent tab and enter the Master Password: 4357. This will completely clear the present password. You can enter a new one afterward.
Posted on Mar 22, 2009
SOURCE: i forgot the 4 digits pin
Ask your parents
Posted on May 18, 2009
  • 136 Answers
SOURCE: Hi, the digital HD cable signal supplied image
If you are using dishnetwork there is a button that changes the "zoom" on screen...there are 3 settings. The button on the remote says "format"
Posted on Jul 08, 2009
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
42" Plasma LG TV stuck on faint white parental screen.
Sounds that the Tuner and Video IF section to your TV has the fault. Seek tech support. This is a highly skilled work.
Jun 12, 2012 | LG 42PC3D 42 in. Plasma Television
How to deactivate parental control
Hi Ida,
If you don't have the password to deactivate partental control you can do the following:
Power on TV, Press MENU and select "Parental Controls". Simultaneously press the CH+ and VOL+ buttons on the front panel of the TV for 8 seconds.
An on screen box should appear, select a new password if desired or leave blank for no parental control lock.
Hope this helps, Gary
Oct 15, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have a vizio tv and an input locked messages appeared and turned the tv off . Now when you turn the tv on the tv shuts off. How can we fix this? We unplugged the tv and pressed the side . We plugged the...
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the side of the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV
6- Power the TV back on
Apr 27, 2011 | Vizio M370VT 37 in. LCD TV
My "set parental control pin"
May I get the make and model # of the tv to help you more
Feb 22, 2011 | LG Televison & Video
I forgoten my computer parental code
hi,
  1. To reset you TV's parental control
  2. press the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and press the right arrow button on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter any one of the override code listed bellow .
From here, you can turn on and off different rating restrictions, as well as set a new code.
There are two codes for different modes of Apex digital TV try the first one if don't work go for the second one. 6688 , 1225.
No matter what the parental code is set to, the new code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
ok
Jan 31, 2011 | Apex Digital AT2702 27" TV
I lost my operations manual for my DSI and the past user set the parental controls pin code and i can't recall knowing it. I have my inquiry number but I don't have my Operations manual to have the other...
Go to parental controls in system settings. When it asks 'Change Parental Controls settings?' tap yes. When it brings up a numeric keypad, tap the center button, "I Forgot". Next, tap "I Forgot" again. Now you will be shown a screen with a number at the bottom (the 'inquiry number'). Go to http://wii.marcansoft.com/parental.psp on your computer and enter this number in the field marked confirmation number. Set the current date in your timezone and click get reset code. And Voila! Your DSi is now parental control free!
plz rate this solution if you have any problems give me a shout back and ill assist you further ok
Nov 28, 2010 | Nintendo DSi White Console
How to reset password for Parental control or timer? TV shuts off after viewing for about 40 min to an hour.
RCA R52WH73 Television
Press MENU and select "Parental Controls". Simultaneously press the CH+ and VOL+ on the front panel for 8 seconds.
Select new password if desired.
Good luck,
Techjoel
May 11, 2009 | RCA R52WH73 Projection Television
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Sony KP-65WS510 65" Rear Projection HDTV-Ready Television Logo
13 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
