Question about Chapin Sprayers 61400 4 Gallon Backpack Sprayer
Installing sholder strap
I can't install strap
Install chandler
The silver metal you refer to is a junction box. If you are installing a standard chandelier, a strap is mounted on the two round ears one of which is shown in your video. There is a hole in the middle of the strap and your chandelier attaches to that hole. With the chandelier suspended from the strap, you now have room to make the wire connections. When finished, the wire connections are pushed up into the junction box and the canopy is tighened to finish the job
Jun 15, 2013 | Home
Installing straps
may i know what kind of brand/model did you have right there..?
Jul 29, 2008 | Eddie Bauer 3-In-1 with Latch
Tip
Installing a Pedal Strap onto a Bike Pedal
Video about How to Install a Pedal Strap onto a Bike Pedal
  • This procedure will demonstrate how to attach a pedal strap onto a pedal
    • This is even easier when the pedal is attached to the bike but we did not have a bike available so we are showing how it is done with the pedalremoved from the bike
      • Tip: Soaking the pedal straps in hot water can make the strap installation even easier as the hot water will soften the rubber making it more pliable
  • Start on the inside of the pedal (nearest the pedal shaft) by placing the slotted hole in the strap at the bottom of the tab and pulling the strap up and into place as seen in the video
  • Then with the tab on the outside of the pedal, start at the bottom and push the strap up and around the tab into place
  • This is all that is required to install a pedal strap onto a bike pedal
  • That completes the procedure
Installing Pedal Strap onto Stationary Bike Pedal Video
on Apr 28, 2014 | Exercise & Fitness
The bugaboo frog harness - the end of the sholder straps don't click into the centre harness piece. There are clips at the end of the harness but they don't fit the shape of the centre clip...
There should be plastic rings on both the lap belts for the shoulder harness to clip too. If they are broken off you can buy the same plastic buckles from Mountain Buggy but you have to sew them on! Bugaboo don't sell them as a part, only with the whole seat frame! Here's a pic of a Bee harness (I have not got a Frog pic) it's the same style. macnutz_37.jpg
Oct 10, 2011 | Bugaboo Frog Stroller
I am trying to refit the straps on a britax car seat (For children 9-18kg) but I cannot get the straps attached to shoulder pads positioned so they are on top of the shoulder straps when coming through the...
hi here is a manual for the eclipse version i have a first class and mine fit the same way so assume they all fit like this, if this doesnt work i will try to help further I know how to do it but cant explain in words
click here anyway worth a try
http://www.britax.co.uk/media/142518/11.pdf
Feb 07, 2011 | Baby Gear
I cannot get the straps to tighten anymore.
Without the model/make it is hard to say what your exact problem is but normally the manufacture's site has links to the user guide. I do have three areas you may want to look over: First the sholder straps themselves sometimes have loops or labels attachted. Make sure these are not preventing the straps from moving through the slots. Second have you attachted the sholder straps to the splitter, a metal bar attachted to the adjustment strap, if it exists on your model. Have you attachted them correctly. Third see if the splitter is stuck on something in the back.
Mar 20, 2010 | Baby Gear
I HAVE A CAR SEAT THAT I TOOK APART IN ORDER TO WASH THE CUSHIONS BUT NOW I DONT KNOW HOW TO PUT THE STRAPS BACK TOGETHER
There is normally a splitter in the back, a metal piece with two hooks that is attachted to the adjustment strap. the sholder straps latch onto this. You can locate the appropriate manual here: http://www.coscojuvenile.com/usa/eng/Instructions The pages in the back normally discuss reassembly after cleaning.
Mar 19, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
Need the steps to installing a new car battery in my 2003 impala.
First disconnect, NEGATIVE cable, than the positive cable. Than remove the bolt or strap that is securing battery. Then when you install new battery, Connect POSITIVE FIRST, then negative battery.
Make sure battery is charged before installing in vehicle. It will save lots of tear on altenator.
Jun 22, 2009 | 2003 Chevrolet Impala
I need to know how to replace a stiming chain on a 1993 corvette
show how to install sholder seatbelt on 73 corvettestingray
Jul 27, 2008 | Chevrolet Corvette Cars & Trucks
Installing straps
go to the shop you got it from cant explain over the net safety reasons
andy
Jun 01, 2008 | Eddie Bauer 3-In-1 with Latch
Chapin Sprayers 61400 4 Gallon Backpack Sprayer Logo
24 people viewed this question
Top Chapin Garden Experts
Nick Olsen
Are you a Chapin Garden Expert? Answer questions, earn points and help others
