Question about True Glass Chiller T-24-GC
Tru mug chiller won't get cold
The mug chiller won't get cold
    Novelist:
    Scholar:
  • 187 Answers
Is the compressor running? Is the condenser clean and the fan running? Is the fan inside running? Is there ice on the coil? Those are the first things I would check after I check to see that the plug has power and the temperature control is turned on.
Posted on Nov 04, 2014
My Samsung 4 door refrigerator quit working. The chiller and freezer are working. What could be wrong?
as the freezer section is working , It could be a thermostat for the fridge section
If you have some mechanical and electrical knowledge you could possibly do a DIY repair with a new unit from the service dealer agent spares
The only other option is to load the unit onto a truck and take it to a service agent for repairs
Feb 23, 2016 | Samsung RF32FMQDBSR 32 cu. ft. 4-Door...
Why does my t-24-gc glass chiller keep freezing up to the point the ice hits the fan?
Check the defrost timer. Turn the small slotted knob on the side with a screw driver until the unit turns off. this will force it into a defrost check the defrost heater strip if it is getting hot then replace the defrost timer if not then check with a volt meter to make sure your getting power to heat strip. If you are getting power to heat strip but it is not heating up then replace the heat strip. also before you force it into a defrost check the defrost termination switch with a meter make sure you have power going to it and through it. It will be mounted on the evaporator coil a round therm o disk with 2 wires on it should be a red and pink one. If you have power going to it and not through it then replace it. This cuts power to defrost time if it gets to hot at coil during defrost.
Nov 04, 2014 | True Glass Chiller T-24-GC
How to open the rbc400 rolodex card system
Open?
Don't you just pull the card out and place it where you want it and push it in?
The cards have slots on the bottom to allow the cards to pulled out and popped back on.
Aug 09, 2014 | Traulsen RBC400-5 Spec-Line Blast Chiller
The freezer is running but will not switch off we have replaced the thermostat
loose clamp on,thermostat sensing bulb (c and s)
check position and tighten.
Chiller tray out of position(s) check and reposition
God bless you
Oct 30, 2013 | Frigidaire 20 cu. ft. / 566 liter Upright...
Beko CDA543 F freezer always on?
noise sound like compressor mount are loose or rubber garment fell off that stops vibration or pump is bad internally call warranty get replaced if not a mounting problem of compressor
Mar 02, 2017 | Freezers
My Kenmore Freezer, 5649215011, won't get cold
Yes it is. You probably have a bad capacitor since it probably as been outside for this long. It is subject to aging even when not in use. This should be an inexpensive job.
Feb 13, 2013 | Kenmore 5 cu. ft. / 142 liter Upright...
Freezer gets to cold thermostat won't adjust
Prepare to replace the t'stat. At least it is freezing and you haven't lost anything.
Jan 26, 2013 | Kenmore Elite Side By Side Refrigerator -...
How to troubleshoot walk-in freezer & chillers
Good day,
The first step is to check to see if the fan motors in the evaporator cooling assembly are blowing.
The second step requires the use of compound gauge set. You will need to determine what type of refrigerant the unit runs on and what the high and low pressure readings are when the unit is on and running.
Mar 31, 2010 | Freezers
Return
sounds correct to me.
Feb 24, 2010 | Freezers
Ice/cold room chiller fan noise
bearings in motor bad(new motor) fan blade hitting ice build up many different causes for this
Mar 29, 2008 | Freezers
True Glass Chiller T-24-GC Logo
136 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
