Question about Business Objects BusinessObjects Enterprise (KNOWLEDGE)
BO Error (DMA0007)
Attempting to refresh reports. Getting the following data providers have not been successfully refreshed. Query 1 with PVP VIN V1 (DMA0007)
    Problem Solver:
  • 12 Answers
This error - DMA0007 is generally a connectivity issue, or you are attempting to refresh a report that uses a local dataprovider , e.g. an Excel workbook.
Which version of Business Objects are you using?
How are you refreshing the report.. manually / via infoview / scheduled in XIR2 or via BCA?
Posted on Jul 07, 2009
Error code c0000005
The Unhandled Exception Error (C0000000005) is caused by a number of different things. It seems to be a kind of catch all for those errors that BO doesn't have a more specific error message for. You can upgrade to higher service packs to get this message less often but it still occurs even within 5.1.5. Here are a number of causes and potential resolutions.
1. Part of the Business Objects NT profile becoming corrupt.
Remove the following registry key:
Go to registry key HKEY_CURRENT_SOFTWARE/Software/Business Objects/BusinessObjects/5.0/USERNAME User Prefs
Something under here becomes corrupt. This can happen in many circumstances, but in particular where a low spec machine (e.g. 64Mb - this should ring alarm bells) is trying to open a 'large' report - sometimes as little as a couple of Mb. When USERNAME signs on to BO again, the key is recreated with the correct values.
2. Refreshing a report.
In fact, the refreshing completes and you see the message 'Disconnecting...'. This is BO, signing out from the database which it has been getting data from - normally you wouldn't see this unless BO is going slow. The fact that you see this, then get the bug is again a PC resource problem. Try it on a faster better specified machine to prove this.
Tidy up the report, remove unused variables, formulas as well as objects from the different queries. Encourage the user to purge the report, so when they pick it up next time the PC doesn't use much resource opening it. Sound them out on scheduling the report and getting the final result sent to them.
3. Importing universes
Another reason for C0000005 is a bug specific to the version of BO we have, 5.1.2. This is the problem with importing universes. Basically, each changed version of the universe has a counter which is incremented each time you save and export. Something goes wrong with this counter so BO is not happy to get the new universe. Mostly this is solved by deleting the existing universe from the C:\ drive and then forcing and import. There is a fix (which I have never got to work) which is to import and export twice. Don't forget about Tools/Universe - you can try and force an import from here. This was supposed to be fixed in 5.1.3.
4. An old or corrupt dll
If you look at the information given when you get the unhandled exception error there is a bit of hex and references to a bunch of dlls. Occasionally, one of those dlls is a duff version - try tracking that down. Also, could have problems with duplicate version of dlls, same file, e.g. ociw32.dll in more than one directory.
5. Miscellaneous resolutions
Try a full reinstallation of BO. i.e. deinstall, make sure no trace of files, folders and registry entries before reinstalling. Reduce the graphics acceleration level via control panel - not a problem on this site, but worth knowing about.
May 07, 2013 | Microsoft Windows XP Home Edition
Software Exception c0000005 (Memory Exception Violation) In tally erp Please give me solution
Jan 24, 2011 | Microsoft Windows XP Professional With...
Getting blank page with the below mention message after login
Try to contact them via support service using this link:
Yahoomail Support Service
And don't forget to include these details:
Host Name: p304.my.kr1.yahoo.com Yahoo! ID: banka_bspl Error Type: (UDB:1) Date/Time: Fri, 01 Jan 10 18:46:56 +0900
Jan 01, 2010 | Yahoo Mail
REFRESH ERROR MESSAGE
Sounds like you have a hacked cable box such that you are trying to view PPV and Premium Channels for free? If this is the case, your cable provider has shut down the device remotely, and wants you to 'get legal', as it were.
The error basically says: "If you want this box to work on this cable system, please call your cable provide such that we can activate it and charge you some $$$"
Mar 04, 2009 | Sony KP-57WS500 57" Rear Projection...
When trying to refresh a Business Objects error... DMA0007
If changes have been made to the universe it may well be that in Deski you're using a local copy of it,
I would first advise exporting the universe to the repository (cms ) and having another go in Infoview just to ensure that the same copy of the universe is being used.
If it still fails, you will need access to the Business Objects server as it could well be that the connection on the server is either missing, incorrect or using a different version of middleware.
The fastest way to check on the server, is to launch Deski directly on the server and import the report > refresh it and see if you get the error.
If so then we know that it's a connectivity issue.
Sep 11, 2007 | Business Objects BusinessObjects...
C0000005 'EXCEPTION-ACCESS VIOLATION' call stack at module... error
This is either due to a corrupt report or a bug - depending on the version of BO that you're using.
To rule out a corrupt report, if you rebuild it does the error still occur?
Sep 10, 2007 | Business Objects Computers & Internet
Computers & Internet Logo
2,135 people viewed this question
Top Business Objects Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Business Objects Computer and Internet Expert? Answer questions, earn points and help others
