Question about ASUS Computers & Internet
Asus 1501 stuck dvd
Stuck dvd in drive slot
How to install a ASUS burner
In a PC, simply open a drive space on the computer, insert the drive by sliding it into the slot and screw it in place. On the rear of the burner are two connections. One is for the Power attachment and the smaller one is attached to motherboard.
That's it.
Oct 29, 2013 | OEM Systems Asus Drw-24b1st Dvd / Cd...
Hi, I have ASUS P4B-M mother board based computer. I just wanted to know if I will be able to connect a SATA DVD drive in this motherboard. If yes, where is the slot? Regards, Vijay
That mother board does not have a SATA port on it, but you can get an adaptor/controller to install it to one of the other slot types
Jul 02, 2011 | ASUS P4PE-BP Motherboard
Dell Inspiron 1501 plays cds but not dvd's
Your DVD drive may be set to a region code that is not compatible with the DVD disc.
For information on changing the DVD region code, please click on this link :-
http://www.fixya.com/support/r3559135-playing_dvds_from_other_regions
Jan 24, 2011 | Dell Inspiron 1501 Notebook
Slot drive is not opening..............
If the dvd-rom drive is stuck you can use a paper clip end to open it. Insert the paper clip end into the small hole located somehwere on the front of the drive. This should push the drive slot open. If there is no disc stuck try re-booting the computer an see if the drive closes on it's own after the re-boot.
Sep 08, 2009 | Dell XPS One Desktop
ASUS F3J DVD drive problem
Make sure the new drive is the same size as the old one (physically the same size) and that you swap out the front door as well as the back door screw connector so this way the drive fits in the slot properly.
Aug 22, 2009 | ASUS F3Jc-AP141C Notebook
How do I connect Burner to IDE cable?
Yeah its a SATA and you need a SaTa controller to put into your computer you cannot connect this via ide
May 23, 2009 | ASUS DRW-2014L1T DVD-RAM Burner
Stuck DVD
there should be a small pin hole in the draw of the dvd, put a pin r paperclip in the hole and push to manually open it.
Sep 16, 2007 | Samsung DVD-VR330 VCR and DVD Recorder
Computers & Internet Logo
41 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
