Question about Tri-Tronics Tritronics Pro Control RL Receiver
I need to change the ni-cad battery in my tri-tronics pro control rl
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
I just bought the Lithium - ion batteries for replacement for my 18.0 volt ni-cad battery. when I put it (ion battery) in the charger (ni-cad charger) no lights come on. what's up?
Lithium Ion batteries don't charge the same way ni-cads or ni-mh do. You need a lithium ion specific charger to charge them. (Some chargers do multiple types.)
Apr 22, 2012 | Ryobi Multi-Volt Battery Charger
Question about john deere bulldozer that has a radio control 9.6v rechargeable Ni-cd battery pack 800mAh. how long does it need to totally charge?
Hi.
Since this is using Ni-Cad battery system, I would charge it between 12 - 16 hours to ensure a full charge has been accomplished.
The original owners manual may say quite alot less, but Ni-Cad batteries are notorious for taking a long time to fully charge.
Too bad it doesn't have a li-ion battery...those only take about 4-6 hours for a full charge, and thats only if they are totally dead!
I hope this helps you out.
Good luck to you, and have a good day!
Jun 20, 2011 | Computers & Internet
Hi there, I have a MiproACT-707 TM, which i use while teaching aerobics classes. After working perfectly for about 10-15 minutes - it stops working completely. This happens with brand new fully charged...
Hi, I would first ask if you are using a Ni-cad rechargeable battery system, these are not optimum performers for such a high drain microphone as probably the one you're using. Especially if the mic. takes a single 9 volt battery ( the average ni-cad 9 volt is about 200 milliamp hours, not a lot. If so-try switching to nickel metal hydride ( Ni-Mh ) these are better for high drain devices and do not develope a " MEMORY " effect ( which will cause rather sudden power loss ) memory effect can happen to almost brand new batteries as well, all it take to incur this is to charge a Ni-cad before it is totally dead. good luck, and thanks for choosing FixYa-Prodzilla
Apr 20, 2011 | Mipro Audio Players & Recorders
I need ni-cad battery specifications for Acoustic Research AW-721 headphones. I bought replacement ni-cads but they don't charge when the headphones are placed on the headphone cradle/charger.
The AR AW721 headphones require 3 AAA NiMH batteries, not Ni-Cad. The original batteries are 1.2 volt, 550 mAh. I replaced mine with Energizer 850 mAh AAA batteries, which work well and actually last longer per charge than the originals.
Sep 20, 2010 | Acoustic Research AW-721 Consumer...
Switch and bateries
Makita makes two 12V Ni-Cad pod batteries: Battery 1222/2.0Ah (PN: 192598-2) and Battery 1220/1.3Ah (PN: 192681-5). Makita's universal charger (PN: DC1804) will charge any Ni-MH or Ni-Cad pod or stick battery from 7.2V to 18V.
Aug 18, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
I COULD NOT RECHARGE MY BATTERY
might have have a dead cell. NI-cad have memory you have might have expired the memory. try drain it completely.then recharging it.
Jul 10, 2009 | Red Lion Bx0000 Sealed Ni-cad Battery 4...
How do I change the Battery in My Norelco T3000 Beard Trimer
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Jul 06, 2009 | Norelco T770 Beard Trimmer
Need help with my digital camera
Are you using Ni-MH batteries? Most other batteries including Ni-Cad just dont have the punch that the Ni-MH has amperage wise. You could try Lithium batteries, but many devices are explicit on the battery type.
Feb 11, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Camera won't come on and lens doesn't retract
If you bought ni-cad batteries then you may have recharged them incorrectly and they do not have a good charge. Try fresh non-rechargable batteries.
If you bought ni-cads, buy nickel-hydride next time. They do not have a "memory" issue like Nicads.
I think the key here, though, is that it was dropped....
Jan 06, 2008 | Nikon Coolpix 2100 Digital Camera
Tri-Tronics Tritronics Pro Control RL Receiver Logo
49 people viewed this question
Top Tri-Tronics Electronics - Others Experts
Are you a Tri-Tronics Electronics - Other Expert? Answer questions, earn points and help others
