Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
1993 yamaha timberwolf will not start
Replaced starter , battery, solioniod
    Master:
  • 706 Answers
Do you have spark? easy test is to pull a plug wire, hold it close to metal with a stick or other non conductor. DON'T USE A SCREWDRIVER or other metal object. IF you have spark then its a fuel problem, check the tank, remove the fuel line into the carb, getting fuel? If all else fails take your Yamaha to the local dealer for correct repair
Posted on Nov 24, 2014
1993 Yamaha FZR 600 will not start
Hi, Leah before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
My 1993 Yamaha FZR 600 Won Start
What to do When Your Motorcycle Won Start
Yamaha FZR600 1989 1999 Factory Service Repair Manual PDF Download Manuals... $10 cheap
OEM parts for Yamaha
Yamaha FZR600L Owner Manual
May 17, 2017 | 1993 Yamaha FZR 600
1999 Yamaha Timberwolf 250 will not turn over. Took it to someone they said it was stator. Replaced stator and spark plug still wont turn. There's no noise anywhere.
Hi, Anonymous and the usual suspects are:
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
1994 Yamaha Timberwolf 4x4 Electric Start Problems
no fire 96 timberwolf
http://www.mikekekich.com/92-98%20Timberwolf%202WD%20Service%20Manual.pdf
Yamaha YFB250K Timberwolf Owner Manual
Jan 13, 2017 | Yamaha Motorcycles
1995 Timberwolf. When I try to start it, all I get is a click and it will not go into gear. What's wrong?
Hi, Brooke it should be noted that in order to "PROPERLY" diagnosis any electric starter issue it is "IMPERATIVE" that you begin with a fully charged battery 12.5 volts or better and be able to pass a proper load test, and the usual suspects are:
1. Battery terminals have loose or corroded connections.
2. Battery cables faulty due corroded or broken internal wiring at the cable connector especially the "NEGATIVE" cable which needs to be checked at "BOTH" ends.
3. Battery voltage, 12.5 volts or better,to the main circuit breaker to the ignition switch to the security/ignition fuse to the TSM/TSSM module to the engine stop/run switch to the starter button to the starter relay to the green wire that connects to the starter solenoid has dropped more than 1/2 volt.
4. With a voltmeter connected to the battery, the ignition switch in the on position, the kill switch in the run position, the starter button depressed, starter engagement should not bring voltage below 8-9 volts.
If a lower voltage is produced a proper battery load test should be performed with a load tester to validate battery integrity or battery replacement.
5. Faulty starter relay, check continuity.
6. Faulty starter solenoid, check contact plate and shoes for excessive electrical erosion/etching, refurbish as necessary or invert contact plate and use the virgin backside. Check contact shoes for being loose. Replace solenoid if the negative function is still a final outcome.
7. Faulty starter, bench test starter with a 12-volt battery if negative function check, decontaminate and undercut armature commutator segments as necessary, check segments with an ohm-meter probe each one and the segment next to it for shorts. Have the armature tested with a growler and field coils, and brush plate with an ohm-meter for opens, shorts or grounds. Replace brushes if less than .438" It is generally cheaper to overhaul/refurbish a starter motor than buy a new one.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.off-road.com/atv/tech/atv-answerman-your-offroad-atv-questions-answered-52130.html
how to fix starter problems Just clicks yamaha warrior update and starter...
https://www.tradebit.com/filedetail.php/278979958-yamaha-timberwolf-250-1992-1995-service-repair-manual
Mar 05, 2016 | Yamaha Motorcycles
1994 Yamaha 250 timberwolf piston ring replacement
YAMAHA TIMBER WOLF 250 ENGINE OVER HALL ANN ...
? 3:08
www.youtube.com/watch?v=0fypjxwZV40
May 16, 2010 - Uploaded by omar arriaga
HERE IS MY NEW PROJEC PAINTING MY 250 TIMBER WOLFIM REPARING ... back break replacement on Yamaha timberwolf 250cc tutorial ...
Sep 12, 2015 | Yamaha Motorcycles
'92 yamaha timberwolf valve adjustment
Here's the info you're looking for.
1992-1998 Yamaha Timberwolf 2WD and 4WD
Intake: 0.05 - 0.09 mm (0.002 ~ 0.004 in)
Exhaust: 0.11 - 0.15 mm (0.004 ~ 0.006 in)
Jun 20, 2014 | RTO 200cc Full Size Four Wheeler ATV
Gas pouring into the air box .
The 24mm Mikuni carburetor float is stuck to on position.
Replace the float and clean the fuel bowl will fix the problem.
Yamaha Timberwolf 2x4 Specifications Off Road com
Oct 04, 2012 | Yamaha Timberwolf 250 2wd 97 Airbox Air...
Won't start
you have a bad solenoid battery or starter try to ground the starter touch positive to groundwith a rubber ended screw driver if the starter spins you have a bad solenoid
Jun 22, 2009 | 2003 Yamaha YZ 250 F
Yamaha timberwolf wont start unless push started
You have a loose connection to the ignition system . When cranking make sure it is in neutral. and kill switch is in run position. The only thing dropping would sensibly affect is the fuel system or jarring a switch., but with the suspension you have there really is no jarring. So, I would ck the wiring. something is loose.
May 29, 2009 | 2003 Yamaha YZ 250 F
Yamaha timberwolf 4x4 carberator issues
Firstly, if you are not a mechanical person you should never buy a vehicle that does not run.
However, here are some basic tests.
1. Connect a good battery.
2. Remove the spark plug.
3. Turn the motor using the starter motor or kick starter.
4. check for spark by inserting a new plug into the plug cap. (make sure the plug is grounded).
If the motor turns freely and there is spark, chances are good that the motor will run. This does not mean that the motor is in a good condition. Only with the motor running will you be able to know for sure.
You will now have to source a carb and fit it to the 4 wheeler.
Fitting the carb is not too difficult. Check that the intake manifold is not perished or torn, and remember to use the airfilter.
Enjoy the ride !
Jon
Mar 01, 2009 | 2003 Yamaha YZ 250
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
Top Quad Cycling Experts
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
