Question about Foxconn Dell Studio Xps 7100 Motherboard Ff3fn 0ff3fn Drs880m01 Socket Am3
Red light motherboard
Computer will not post there is a red light at the top right of the motherboard
New computer build will not POST
Check your hard drive and weather or not you have the drive set to IDE or ACH
Feb 09, 2014 | Micro-Star MSI A55M-P33 Desktop...
Need emachines t3306 motherboard connection diagram
The eMachines T3306 desktop computer, uses the FIC K8M-800M motherboard.
First International Computer, (Inc)
http://www.fic.com.tw/product/motherboard/amd/ficimages/k8m-800m.jpg
http://www.fic.com.tw/product/motherboard/amd/k8m-800m.aspx
Here's the download page for the motherboard manual,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
Column in middle, 3rd file from bottom.
This is a Zip file. A Zip file is a Compressed file. Used to send large amount of information more easily.
Has to be decompressed, or 'unzipped'.
After you click on the blue -> FIC K8M-800M file name, a small window will come up-
Opening K8M-800M_manual.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; click in the empty circle to the left of Save File.
No go below in the small window, and click on OK.
A small download window will come up.
Allow the file to fully download all the way, then DOUBLE-click right on the file name.
(Yellow folder icon with a zipper on it. K8M-800M_manual.zip is to the right)
In the next small window go to the far Left, and click on -
Extract all files.
At the bottom of the next 3 small windows click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name ->
K8M-800M_manual
(Next to the red Adobe PDF icon)
There is your motherboard manual in PDF file form.
For an example;
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
Motherboard installed in computer case, the Front Panel header is at the Bottom/Right.
The Front Panel header is Orange in color. (Page 20)
Two rows of contact pins.
5 pins across the Top row.
4 pins across the Bottom row.
The Top row is numbered ODD.
The Bottom row is numbered EVEN.
Starting on the RIGHT side going across to the Left; Top row,
Pins 1, 3, 5, 7, and 9.
Starting on the RIGHT side going across to the Left; Bottom row,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
Reserved for factory use. Probably a 5 Volt test point.
D) Pins 2 and 4 are for a Power On LED light.
These two pins are used for a Single color, Power On LED light.
Two wire LED light.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
There is ALSO a jumper used for this LED light. More on it at the end.
E) Pins 6 and 8 are for a Power On switch.
To the Right of the Orange Front Panel header, (F_PNL), is the PW_LED header.
[Page 20 to right of Front Panel header. -> PW_LED
(Power LED, 2/3 Pins) ]
3-pin Black header. Sits Vertically.
(The Orange - Front Panel header, sits Horizontally)
This is used for a 3-wire Power On LED light.
Used for a Dual Color - Power On LED light.
One example is if the computer has Turbo Mode, and Normal Mode.
Green color usually for the Turbo Mode, Yellow color of the LED for the Normal Mode.
Starting from the BOTTOM going UP;
Pins 1, 2, and 3. (3 at the Top)
A) Pin 1 is for the Positive ( + ) wire. [Signal]
B) Pins 2 and 3 are for the Ground wires.
Jumper block for the 2-wire Power On LED light, and 3-wire Power On LED light; Page 13 - Set System Jumpers
(Actually it starts on Page 12)
6-pin header to right, of 3-wire Power On LED header.
Has Blue jumper caps on it. Two of them.
(PL_LED1)
http://www.ebay.com/itm/NEW-FIC-uATX-Skt-754-AMD-Desktop-Motherboard-VIA-K8M800-AGP-4x-8x-DDR400-800FSB-/280923928691?pt=Motherboards&hash=item41685ef873
Two rows of 3 pins.
The bottom row is numbered EVEN.
Starting on the RIGHT side going towards the Left; Top row,
Pins 1, 3, and 5.
Starting on the RIGHT side going towards the Left; Bottom row,
Pins 2, 4, and 6.
A) With the jumper caps on Pins 3 and 5; plus 4 and 6; the Power On LED light works as a Single color LED.
B) With the jumper caps on Pins 1 and 3; plus 2 and 4; the Power On LED light works as a Dual color LED.
For additional questions please post in a Comment
Regards,
joecoolvette
Mar 07, 2013 | Computers & Internet
GT1T-M7 CONFIGURATION DIAGRAM NEEDED
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=897&CategoryID=1&MenuID=16
It is my belief sir that you are referring to the ECS G31T-M7 (Version 1.0) motherboard. If I am incorrect please post back in a Comment.
Scroll down, and click on the Download tab.
(Features / Specification / Download / Support / FAQ / etc)
Now click on Manual.
(Driver / BIOS / Manual)
Scroll down, and click on the NAME of the country nearest yours.
There is the Motherboard User Manual in PDF file form.
For example;
The area of contact pins on the motherboard, that the main wires from the Front Panel go to; is the Front Panel header.
Motherboard installed in computer case, with Processor to the Top, and Ram Memory slots to the Right; the Front Panel header is located at the Bottom/Right corner, to the left of the motherboard mounting hole.
F_PANEL
The Front Panel header pinout is on Page 29, of the PDF file.
There are 4 pins across the Top row, and 5 pins across the Bottom row.
The pins on Top are numbered EVEN.
The pins on Bottom are numbered ODD.
Starting on the LEFT side coming across to the Right side, Top row:
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the LEFT side coming across to the Right side, Bottom row;
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
If the HDD LED is dim when the harddrive is active, switch the wires around.
This is probably a 5 Volt + point, reserved for factory testing.
D) Pins 2 and 4 are for the Power On LED.
(Light. It is a Light Emitting Diode)
E) Pins 6 and 8 are for the Power On switch.
Jumper settings are shown, Front Panel port header's pinouts are shown, etc.
Do you have a specific question? Please post back in a Comment.
Regards,
joecoolvette
Dec 09, 2012 | Computers & Internet
Case hook up /power
http://global.aopen.com/products_download.aspx?sDropDownProd=52
i55HMt-HD / Manual / User's Manual / English / 12/15/2010
Click on small icon above 1127.6 KB
(Icon is a Floppy Disk drive with a Red arrow above it)
There is a small window that opens up.
Go to the bottom under the Mirror Sites heading.
To the right of the country nearest yours click on the blue ftp site.
I'm going to choose USA, San Jose, as an example.
I click on - ftp://ftp.aopen.com
After a few seconds the manual downloads. It is still in the small window. Go to the Maximize icon at the top right corner of the window, and click on it.
(Next to the Red X)
Now hover your mouse cursor down at the Bottom/Middle.
The ghosted out Navigation Guide will appear.
Go to the far right, and click on the Adobe Reader icon.
[When your mouse cursor is above it - Show Adobe Reader toolbar -
appears ]
Use the Plus ( + ) icon at the top of the file to increase the view size,
use the Minus ( - ) icon to decrease the view size.
Go to Page 14 - 2.7 Connecting Front Panel Cable
The motherboard is shown clocked 90 degrees to the right, from how it actually sits in the computer case.
Processor socket to the Top, Ram Memory slots to the Right, white long PCI slot to the bottom;
The Front Panel header is to the Top edge, and towards the right.
[The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header ]
Situated in the computer case, the Front Panel header is along the top edge. It is parallel to the top edge, and is two rows of contact pins.
20 pins. 10 across the Top, 10 across the Bottom.
Pins across the Top row are numbered ODD.
Pins across the Bottom row are numbered EVEN.
Starting on the Right side on the Top row, and going towards the Left;
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19
Starting on the Right side on the Bottom row, and going towards the Left;
Pins 2, 4, 6, 8, 10, 12, 14, 16, 18, and 20.
A) Pins 1 and 3 are N/C. Not Connected (White area)
B) Pins 7 and 9 are for the HarDDrive activity LED.
(Middle two pins in Orange area)
C) Pins 13, 15, 17, and 19 are for a Speaker. Internal speaker for the BIOS Beep Codes.
Pin 13 is for the Positive ( + ) wire
(Gray area)
D) Pins 2 and 4 are for a Reset switch, IF a Reset switch is used.
(Purple area)
E) Pins 12, 14, and 16 are for the Power On LED light.
Pins 12, 14, and 16 are used for a Power On LED light that has 3 wires. The LED has dual colors. (Green/Yellow?)
For a two wire Power On LED it is Pin 12, and Pin 14.
(Green area for all 3 pins)
F) Pins 18 and 20 are for the Power On switch.
(Pink or Red area)
Front USB headers are on Page 15.
Front Audio headers are on Page 16.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 23, 2012 | AOpen MX46-533V (91.89U10.061) Motherboard
What do the red diodes D1 - D4 mean?
I do not see anything in the manual about LEDs for D1-D4
Super Micro Computer Inc Products Motherboards Xeon Boards X5DP8 G2 .
However if the motherboard is not posting it could be the RAM. One continuous long beep means that there is no memory detected (D1-D4 may refer to the dimm slots 1-4). You can try booting off of a single stick of RAM, and try different dimm slots to get the motherboard to post.
Jul 15, 2012 | SuperMicro SUPER DP8-G2 (P4DP8-G2)...
E-Machines T3508 PC Desktop Motherboard connecting the wires
The eMachines T3058 Desktop PC uses an Intel D101GGC motherboard.
The plastic front of your computer is the Front Panel.
The rectangular area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
Front Panel header:
This link takes you to Intel Support, and the download page for the motherboard manual, for the Intel D101GGC motherboard,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
On this page click on the blue -
Intel Desktop Board D101GGC Product Guide - English (PDF)
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
{ Took 7 seconds to download just now, with no additional download time needed.
Using medium speed DSL connection }
Ignore the following if you are aware;
At the top of the PDF file is the PDF file page number box, and the Zoom Out/Zoom In icons.
Zoom Out ( + ) enlarges the page view, Zoom In ( - ) reduces the page view.
For myself I reduce the view size to 100 or 75 percent.
The page number box is to the right of the Down Arrow.
(If you do not see this, hover your mouse cursor towards the bottom/middle. When the icons come up, {They were 'ghosted out'}, click on the PDF icon to the far right )
Provided that somehow you cannot download this motherboard manual;
Orient the motherboard so we are both looking at it in the same direction.
Same as it sits in the computer case.
Processor to the Top, Ram Memory to the Right, white PCI slots to the bottom.
The Front Panel header is at the Bottom/Right.
It is a rectangular block of plastic with two rows of pins.
4 across the Top, 5 across the Bottom.
It is numbered Even on the top, and Odd on the bottom.
Starting at the LEFT side going towards the right, on the top row;
There is no Pin 10, just an empty space.
Starting at the LEFT side going towards the right, on the bottom row;
A) Pins 1 and 3 are for the HarDDrive activity LED light. (Orange)
Pin 1 is for the Positive wire ( + )
If the LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. (Blue)
C) Pin 9 is for 5 Volts. Not Used (Black)
D) Pins 2 and 4 are for the Power On LED light. (Green)
Pin 2 is for the Positive wire ( + )
If the LED light is dim switch the wires around.
E) Pins 6 and 8 are for the Power On switch. (Red)
Do not know what wires coming from the Front Panel are the Power On switch wires, Power On LED light wires, or Harddrive activity LED light wires?
Remove the Front Panel, trace the wires to the Power On switch. (Two wires. Probably twisted together. Or all wires are in a single sheath)
Same for the Power On LED light, and the Harddrive LED light.
Need to know where the harddrive, or optical drive plugs in?
Need to know where the power cables from the Power Supply plug in?
Regards,
joecoolvette
Oct 11, 2011 | E-Machines T2893 PC Desktop
Needed to move motherboard to new case because of overheating / ventilation problems - do not know what the power / reset / hdd led leads are for the 9 pin f_panel (new case has each as separate...
Photo of the Asus M2N78-LA motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01421635&dlc=en
This photo also shows the orientation (Direction), that the motherboard is sitting in a computer case.
To the very bottom right is the Front Panel header.
The front plastic panel of the computer is the Front Panel.
The area of pins on the motherboard that the cables, (Wires) from the Front Panel connect to, is the Front Panel header. ( F_PANEL )
The Front Panel header, is the black rectangular shaped plastic block, that is sitting vertically on the motherboard.
Has two columns of pins.
4 on the left side, 5 on the right side. Makes it look as though there is a pin missing, at the top left corner.
I'm going to number the pins.
Pins on the Left side starting at the Top, going down;
Pins 1, 3, 5, and 7.
Pins on the Right side starting at the Top, going down,
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the Power On switch. (Power On button)
B) Pins 5 and 7 are for the Power On LED light.
Pin 7 is for the Positive ( + ) wire.
(If the LED light is dim, reverse the wires around)
C) Pins 4 and 6 are for a Reset switch, IF a Reset switch is used. (Reset button)
D) Pins 8 and 10 are for the HarDDrive activity LED light.
Pin 10 is for the Positive wire. ( + )
(If the HDD LED light is dim when operating, switch the wires around)
Pin 2 at the top Right is NOT used. (NC. Not Connected)
I am looking at a motherboard manual in PDF file form, for the Asus M2N78-LA motherboard.
Regards,
joecoolvette
Sep 03, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
I have the Targus amb04us wireless mouse. The mouse lights up when I turn it on, but my computer isnt showing a connection. Plus, the connector in the USB port isn't lighting up.
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
if you need more help with this post a reply
hope this helps you
Aug 30, 2011 | Computers & Internet
I took the front off the e machine w2888 desktop but did not notice the three wires was not one plug, what order and colored wire up or down. Their is a pwr led, pwr s/w, hdd led wire. Thanks Jerry
The eMachines W2888 uses an Intel D845GVSR motherboard.
This is the download page for the Intel D845GVSR motherboard manual, (Product Guide),
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
Left-click on the first file name in blue -
Intel Desktop Board D845GVSR - Product Guide (PDF)
This is a PDF file. The computer you are using has Adobe Reader on it, which uses PDF files.
After you click on the above file name it may take up to 30 seconds before the first page comes up.
[ Took 4 seconds to see the first page come up, just now. File was fully downloaded ]
At the top of the PDF file is the page number box. It is to the right of the blue Down Arrow.
This is the page number I will be referring to, and may not be the actual page number of the manual.
Go to Page 11.
This shows an illustration of the motherboard looking down at it from the top.
The letter S points to the Front Panel header.
[The plastic front of your computer is the Front Panel.
The area of pins on the motherboard that the cables (Wires) go to from the Front Panel, is the Front Panel header ]
Looking at the motherboard with the Processor to the top, Ram memory slots to the right, and the white PCI slots (3) to the bottom, the Front Panel header is located parallel to the bottom right edge of the motherboard.
(The illustration has the motherboard sitting on it's right side.
Not the direction it is sitting in your computer.
In your computer the motherboard is sitting as described above )
Now I would like you to go to Page 31.
This illustration shows the various internal headers on the motherboard.
The letter C points to the Front Panel header. (J9G1)
Note that the pins in the Front Panel header are labeled with numbers.
(Pinout)
There are 4 pins across the top.
There are 5 pins across the bottom.
Starting from the Left side of the motherboard, going towards the right, across the Top of the Front Panel header;
Starting from the Left side of the motherboard, going towards the right, across the Bottom of the Front Panel header;
Page 32: Front Panel Header
A) Pins 1 and 3 are for the HarDDrive activity LED light. (HDD LED)
B) Pins 5 and 7 are for a Reset switch, IF used.
Pin 5 is for the Ground ( - ) wire.
C) Pin 9 is for a 5 Volt wire. (It's probably Red in color, IF used)
D) Pins 2 and 4 are for the Power On LED light. (Light Emitting Diode)
E) Pins 6 and 8 are for the Power On switch. (The Power On switch is located inside the plastic Power On button assembly)
F) Pin is N/C. Not Connected.
Regards,
joecoolvette
Jul 10, 2011 | E-Machines eMachines Desktop PC
Foxconn Dell Studio Xps 7100 Motherboard Ff3fn 0ff3fn Drs880m01 Socket Am3 Logo
35 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
