Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Overheating Our Kenmore refrigerator gets very hot in the divider and around the outside edge of the top freezer. So hot that you can't keep your hand on it! I've vacuumed and made sure connections were okay and fan is working. Any suggestions?
    President:
  • Kenmore Master
  • 2,651 Answers
The fan you should be checking is behind unit , under a cardboard cover , its the condensor fan motor, desined to disapate heat in that section.
Posted on Mar 30, 2014
Testimonial: "Yes I have checked it and it is working."
  • Sherry Savoie
    Sherry Savoie Mar 30, 2014
    Model # 970-429680 top freezer unit
My kenmore I getting hot around the outside edge of the freezer and when the timer gets to defrost it throws the breaker can u help please
the unit wil get hot around the edges as designed. if its tripping your ground fault, then remove that circuit. a refrig should not be hooked up thru a ground fault as it will not work with that circuit.
Dec 30, 2013 | Refrigerators
My LG LSC 26905TT Refrigerator started to heat up around the outside of the freezer side/top and center bar between the fridge and freezer. The freezer is not freezing no matter how high we set it or the...
HI.IF THE REFRIGERATO BOX OR DIVIDER IS HOT ,CHECK THE CONDENSER MOTOR ,FOR RESISTANCE OR CONTINUITY,CHECK FOR POWER COMMING TO CONDENC MOTOR,, IS OK REPLACE THE CONTROL BOARD OR REPLACE BOTH..GOOD LUCK..
Jul 04, 2011 | LG LSC26905TT Side by Side Refrigerator
Why on the outside of the freezer is hot on sides?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
May 21, 2011 | Kenmore 64802 Top Freezer Refrigerator
Divider between the fridge and freezer is hot to the touch, only from the outside the inside walls of both the freezer and fridge is cold, but the outside facing you as you open the door divider is very...
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
Jun 03, 2010 | Kenmore 53642 / 53644 Side by Side...
My samsung rs2630sh is very very hot to the touch
The fan you should replace is called the condenser fan. It's the one that blows air across the outside coils. When it fails, you'll usually notice abnormal heating of the front of the divider between freezer and fridge.
Oct 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire GLRT182SA
If you're talking about the divider between the freezer and fresh food section, check this post
Oct 17, 2009 | Frigidaire GLRT182SA Top Freezer...
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have a Kenmore 5950-2990 side by side. It
its normal they run a line through it its called the yoder loop keeps the moisture off
Jun 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Mar 14, 2009 | Kenmore Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
76 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
