Question about Uniden BC370CRS Base Scanner
Uniden bc175xlt scanner has no sound help
No sound
Manual for Uniden Bearcat Scanner BC120XLT
  • Hi, I can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 22, 2011 | Uniden BC370CRS Base Scanner
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
No sound from my new Uniden UBC72XLT radio scanner
Your best bet is to send it to Uniden for factory certified repair. They may charge a little more than your local electronics shop, but they will use the correct parts and give you a quality repair with a factory warranty. You can contact them here:
http://www.uniden.com/repair/repairform1.cfm
Bill B
Apr 29, 2010 | Uniden BC72XLT Handheld Scanner
Error ID = 0xC00D11BA, Condition ID = 0x00000000
Your sound card might be in use by another application.
0xC00D11BA: Cannot play the file
Windows Media Player cannot play the file because there is a problem with
your sound device, such as a sound card or sound controller. You may
encounter this error message for one of the following reasons:
Your sound device is in use by another program. Quit other programs that may
be using your sound device, and then try to play the file again.
Your sound device is not functioning properly. To troubleshoot the problem,
see the Sound Troubleshooter in Windows Help or refer to your sound device's
documentation.
You do not have a sound device installed on your computer. Install a sound
Apr 10, 2010 | Microsoft Windows XP Professional for PC
Unbearable noise after every radio message - squelch doesn't help
Doesn't sound like you're doing anything wrong. Either the scanner is defective or your locale is using some kind of oddball system that's causing the noise. Take it back, show them what it's doing. If possible, try another scanner in the store and see if it does the same thing. You should be entitled to a refund, exchange, or full credit towards a different model . . .
Jan 20, 2010 | Uniden BC72XLT Handheld Scanner
The squelch will not turn down?
Sounds like your squelch pot is either shot or disconnected. If you're electronics handy, you can troubleshoot it yourself and replace the pot if necessary. You can also send the scanner to Uniden for repair. Follow the link below for troubleshooting help or to contact Uniden regarding repair.
BillB
http://support.radioshack.com/support_electronics/doc68/68646.htm
Jan 19, 2010 | Uniden BC340CRS Base Scanner
Looking for a manual for a uniden bearcat 30 chanel scanner
Uniden scanner manuals can be found at the following location:
http://www.uniden.com/index/manuals_results.cfm?cat=3
Just click on the model of your scanner and download it.
Hope this helps!
Jan 03, 2010 | Uniden BC248CLT Base Scanner
Hi i just got a scanner but .. my dog eat the
If the coffee hit just the manual and not the scanner, you can download and print a replacement manual by following the link below and get on with your scanning. If the scanner went for a swim you've likely fried (or boiled) some critical circuitry, and the scanner will need professional help. You best bet for that is to contact the product support folks at www.Uniden.com
Here's the link to the manual:
http://www.uniden.com/pdf/BC92XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.Radioreference.com
Dec 23, 2009 | Uniden BC92XLT Handheld Scanner
How to program a bc 560xlt bearcat scanner. Thanks, Les. lorlick@yahoo.com
hello there: here is a link for you that will help out ok
best regards mike
How to Program a Uniden Bearcat Scanner BC 140 | eHow.com How to Program a Uniden Bearcat Scanner BC 140. Programming a Uniden Bearcat ... How to Program a Bearcat 5 Scanner. How to Program a BC 560XLT Scanner ...
www.ehow.com/how_5009391_program-uniden-bearcat-scanner-bc.html - 57k -
Aug 24, 2009 | Office Equipment & Supplies
Uniden BC370CRS Base Scanner Logo
63 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
